Question about RIM BlackBerry Pearl 8100
Security options Hi there, could you please help with setting temporary security - mean sometimes I don`t want people to see my number (comes as private - for business purposes). Any solutions? Many thanks
  • 3 Answers
This one is easy! Thise setting are in the phone section. Just go into the phone, go to options, go to general options, and restrict your identity.
Posted on Jul 18, 2008
Want to wipeout my blackberry to factory setting help
Please do remember to perform a complete system backup before you proceed with the wipe. You never know when you will need to recover some of that data in the future.
1. From the Device Options menu, select Security Options.
2. Click General Settings.
3. Click the blackberry button, and then click Wipe Handheld.
4. If you wish to erase all third party applications, click the check box.
5. Click Continue, and then type blackberry .
To make it clear,here's a video to know exactly what to do.
Thank you for visiting FixYa...
Aug 23, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
My EMI No. is 352009046411554 for Nokia E63 . Please send me master security code. Thanks SHYAM SINGH DHONI
The Default code for this type of model is 12345,If you forgot or you didn't know the security code,Unfortunately,there is no free codes or free software calculator for new security phone.the only way to recover your security code is by using a gsm gadget by reading the existing code and it is possible to bring it to any mobile service center.
Thank you for visiting...
Jul 20, 2011 | Nokia E63 Cell Phone
Error 01 I did **** control et al and even so
The information your browser stores is sometimes incomplete or corrupt. Deleting your browser's cache and cookies will often fix Gmail issues.
For instructions, please select your browser below:openm Internet explorer click on tools>internt option and then delete cookies, Temporary files and clear history then click on ok and exit out of internt explorer and the relaunch it and it will fix the issue.
May 09, 2010 | Google Talk
Im trying to set security on belkin n router
Hi...if your router has WPS capability, such as a special button to set up wireless security, then to use it your client computer/device must also be WPS enabled.
If it is, there are usually two options to configure WPS security: the push button method, or the PIN number. The push button method usually requires that you press the WPS button on the router, then within a set time, press the equivalent button on the computer (eg laptop, or whatever device it is). The PIN number method requires a PIN to be entered into the client computer. The PIN can sometimes be found on a sticker on the router.
Your manual should help with the details, but see this page for some more info.
http://kbserver.netgear.com/kb_web_files/n101691.asp
If you don't have a WPS enabled computer or don't want to use it, you can set up security manually. Please come back to Fixya if you'd like help with this.
Dec 29, 2008 | Belkin Wireless Pre-N (F5D8230-4) Router...
Cant figureout how to set a password to a d-link router
Hi…I’ll try and lend a hand. There are several ways to set up wireless security on this router. However, I’ll help you set it up using the manual method.
Important note: use a wired (Ethernet) connection to the router to set up wireless security.
There are four main steps:
1) Login to your router.
I’m sure you have done this already, but here it is again for clarity. Type the router address in the address bar of a web browser. For this router, it is http://192.168.0.1
Select ‘Admin’ from the dropdown box, then enter your password IF you have set one – otherwise, just leave the field blank and press return.
You should then see the configuration screen/user interface.
2) Change the router password.
If you HAVEN’T set a password, this is a good place to start. Go to Tools >Admin option. Set and confirm a password for ‘Admin’, and note it down. Also, set and confirm a password for ‘User’. Click ‘save settings’ when finished.
Make sure these passwords are not easy to guess, or a neighbour could log into your router and view/change all your settings.
3) Change the SSID (router name):
Go to Setup > Wireless Settings. You should see an option marked ‘Wireless Network Name’ or SSID. Change this from the default, ‘dlink’, to anything you like –as long as you can remember it. It is case sensitive, and you can use up to 32 letters – but don’t use something that could identify you, or your location. Click ‘save settings’ when finished.
4) Enable encryption
Still in the 'Wireless Settings' menu option, you should see the ‘Wireless Security Mode’ section. Under the 'Security mode' dropdown you have a number of options for encryption. WPA is safest....I would pick WPA-Personal.
You should see a dropdown box marked WPA Mode – select Auto. Leave Group Key Update Interval at the default of 3600s.
Under Pre-Shared Key you should enter a long password, or passphrase, between 8 and 63 letters/numbers long. This can be any series of letters/ numbers, or you can use a phrase with numbers ( eg - 456HappyhOLIdaystoyou8899). It is case sensitive.
Note down the passphrase carefully. You will need this to connect wirelessly. (The WPA shared key may also be called the network key, PSK, pre-shared key or passphrase). Click 'Save settings' when finished.
That's it, you have done enough to secure your network, and can close the screen.
There are further security options to enable if you wish, but these three are the most important.
When you next connect wirelessly, you'll see the router with its new name in your 'available wireless networks'. When you attempt to connect, you are asked for the WPA shared key you set in Step 4. If all goes well, you can then save this and will connect automatically in future.
Hope this helps you. Please come back to Fixya if this doesn't work or if you need help with any of it.
Dec 22, 2008 | D-Link DIR-625 (790069292637) Wireless...
CANNOT ACTIVATE KP.ORG/PASSWORD
i have temporary password but can not activate it
Nov 21, 2008 | Computers & Internet
Unlock Nokia 6070 Security Code
Please help me unlock my phone or please give me the default number to resett the security code
Jul 01, 2008 | Nokia 6070 Cellular Phone
Resetting Security Code
Hi! Vikky how are you! i think you are fine...Try this #0111*0000000#REMOVES SIM LOCK ^2767*688# UNLOCKING CODE feel free 4 asking further assistance rate me as fixya....
Jun 19, 2008 | Nokia 1100
How to break security code
Phone Security Code:
This locks the handset, as opposed to the sim card. You can also set some handsets to only accept a “new” sim if the phone security code is entered.
Master Reset Code
Sometimes known as the Master Code, this allows you to unlock a handset if you have entered the Security Code wrongly too many times.
For mathyn IMEI 010972008260174 Mastercode 5255056051
For mc hot IMEI 359838011209921 Mastercode 1600246040
For Guest IMEI Type *#06# to get it. Mastercode ??????????
For emanuelgaby IMEI 354528013559796 Mastercode 7367245612
This is the code needed to reset the Security code, nothing else, and it’s for your phone only. You type in the security codes (any) until the phone request the Master code; when it does, leave your phone still, don’t use it for 15 minutes, then type in the Master code.
Mar 20, 2008 | Nokia 1600 Cellular Phone
Securing router
hi,
Go to your network properties and at TCP/IP go to its properties.
go inside "advance" and then go inside the "Options menu".
Now enable the TCP/IP filtering and set to "permit only" enter the TCP/IP numbers of the workstation that you have... apply it to the three boxes (TCP, UDP and IP Protocols)
Hope this helps... Goodluck!!!
Mar 05, 2008 | Linksys Wireless-G Broadband Router
RIM BlackBerry  Pearl  8100 Logo
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
