Question about Panasonic PT-AE900U Multimedia Projector
I have a PT-AE900E & have developed lines running vertically down the screen evenly spaced apart. What is causing this??
  • 1 more comment
  • Stuart Leach Jul 17, 2008
    The screen when loads doesn't show the lines, only when watching DVD? Is it the motherboard??
  • rmille38 Aug 20, 2008
    I now have the same problem. After replacing the original lamp, I watched 1 movie and the screen was perfect. The next time I turned the projector on and watched a movie, the evenly spaced vertical lines appeared. This is not the input because it also shows up on the blank (blue) screen as the upper-right input message (HDMI, PC, Video, etc.) shows the same pattern. Seems like every other vertical line is now out or severely dimmed rendering anything unwatchable. Not sure what component is driving this but I know it's not the lamp as I put in the old lamp that was noticeably dimmer than the new one (after 2500 hours) but still had the vertical line problem. Any thoughts? (out of warranty period) Thanks.
  • homer70 Sep 08, 2008
    I have the same problem. I was on vacation for two weeks and since then I have evanly spaced vertical lines in color magenta. they are there no matter what kind of input signal is chosen. I think it has nothing to do with the lamp, but I want to make sure, before I spend money on a lamp and then it is something else.
I had the same problem. I put on eof those cheap little grey plug adapters that turn the three prong plug into a two prong plud (eliominatinghte ground wire) and it solved the problem.
Posted on Sep 01, 2008
  • 115 Answers
If these lines are coming with the input signal then you have to check the Cable connectors.
If these lines are coming without the signal then check the panels and service then recheck.
Regards
Viren
Posted on Jul 17, 2008
Lg55lv4400-va 55" flatscreen tv has developed a wide flickering vertical flickering stripe down the screen. any Ideas ?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 03, 2014 | Televison & Video
Lines on display, numerous horizontal, 3 vertical
This problem is caused by a defective LCD display. It is a common problem too. The only way to repair it is to replace the LCD display.
Dec 20, 2012 | Garmin nuvi 1450 GPS Receiver
I have a Sony KF-42WE610. It has developed evenly spaced lateral lines across the picture (double the lines for Hi Def). Looks like a tube television that needs the vertical hold adjusted. The screen...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jul 11, 2017 | Televison & Video
Hi, my Samsung LE26r73bdx has developed three grey circles (2inch diameter) evenly spaced on left hand side of screen. These are spaced vertically along the left edge. These appear to be growing slowly. ...
Oct 18, 2017 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
I have a vizio p42hd TV. It has thin red vertical lines evenly spaced about 3/4" apart throughout the viewing area.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
HOPE THIS WILL HELP TO FIX IT.....
May 18, 2011 | Televison & Video
Green lines running vertically down the screen spaced evenly
ok lets see...
simple..
if you can see your menu whit no lines perfect is the Video Board .. this is divided in 2 ... analog board and digital board.. you need the DIGITAL BOARD..
http://www.discount-merchant.com/1070511-HD50LPW175-p/1070511.htm
and if you cant see your menu it's the DMD BOARD
http://www.discount-merchant.com/DIGITAL-LIFESTYLE-B-ZRAT3C-1-Digital-Video-p/1111547.htm
Jan 26, 2010 | Samsung 50" Slim-Depth DLP HDTV
Vertical lines across screen on my panasonic tv PT-61LCX65
Try setting a portable fan aimed toward the cooling vents on the back of the set. If this eliminates or reduces the occurance of the lines, this means a circuit that controls the off/on of individual pixels has developed a thermal problem. This circuit is ordinarily loacted on the main circuit board and is likely to degrade further. You might inquire at the Panasonic service center if they have an exchange program in place and they will probably be able to confirm my suspicions.
Aug 09, 2009 | Panasonic PT-61LCX65 61" Rear Projection...
Panasonic PT-50LC14 has evenly spaced vertical blue lines aproximately 1 cm apart
it's not the light engine it'sd the bulb, replace that first, then clean it all out then go from there........
Nov 07, 2008 | Panasonic PT-50LC14 50" Rear Projection...
White lines equally spaced 1" apart.
This is probably caused by the small signal board. It controls and decodes the picture information before it is sent to the display panel. It can be fixed by a quailified technician and if you contact philips (this is who makes magnavox) they will tell you the closest certified technician. Hope this helps.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Samsung WS32Z429T
This looks like it could be a problem with leakage of the 60Hz vertical scan frequency into the picture this is also called 60Hz hum. What usually causes this is poor filtering on the power supply or decoupling capcitors in the vertical section have begun to malfunction. This problem is easy to fix if you have the equipment to isolate the problem, I would suggest that you take this set to a TV repair shop to have it analyzed and repaired.
Sep 22, 2007 | Samsung WS32Z308P 32" TV
Panasonic PT-AE900U Multimedia Projector Logo
506 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
