Question about Hitachi Deskstar 7K80 Hard Disk 80GB, 7200RPM, ATA-6, 2MB Cache, Desktop, 20PACK (HDS728080PLAT200A3021020PK) Hard Drive
Bad Sector on Harddisk
I have to Remove the bad sector from hard disk and i need the disk manager of deskstar now what should i doo?
  • 129 Answers
Set defrag to run at boot up and it will resolve any bad sectors you have, and will write a new boot registry for you.
Posted on Jul 20, 2008
D620 machine so slow i think its going to crash
if your machine responding very slow possibility in your harddisk repair of hard disk for bad sector (bad sector causing your speed problem and hanging of pc)
repairing of hard disk many tools available on internet you go any one of them
May 19, 2012 | E-Machines eMachines Desktop PC
Describe your samsung sp0822n how to removing a bed sector in hard disk
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer hope this helps
May 07, 2011 | Samsung (SP0822N) 80 GB Hard Drive
Compaq Desktop won't boot up.
Do you have your Vista installation disc? If so, you can boot from that and then run the Windows RE troubleshooter, which should be able to test your hard drive and maybe even try to repair it.
May 27, 2010 | HP Compaq Presario SR2010NX PC Desktop
I have bad sectors in my hard disk what should can i do?
There is nothing you can do about bad sectors. The Hard Drive itself, with its associated electronics, automatically maps these bad sectors and doesn't use them any more. So, the answer to your question is "NOTHING". Bad sectors may eventually make your Hard Drive unusable, and if your bad sector count is growing quickly it's time to do a complete backup and replace the drive.
Mar 30, 2010 | Computers & Internet
How to remove bad sector in HDD ???
If you are a professional you can use two programs or softwares to remove bad sector from any hardware.
1. Hard Disk Regenerator
2. Spin Write
100% guaranteed it will work to repair them or some time remove bad sectors from hard disk and your hard will work so better and fast like a new hard disk.
Good Luck
Dec 16, 2009 | LaCie (300770) 250 GB Hard Drive
How to remove bad sectors laptop hdd
Sir,
Bad sector removing is difficult task to remove /find. u can't solve bad sector harddisk. first go to run and type CHKDSK and check how the disk was or % of bad sector. the chkdsk command will solve badsector automatically. if not solves better to buy a new one or using the hdd with bad sector it not a problem
Jul 11, 2009 | Computers & Internet
Hard disk Bad sector Problem
Bad sectors is a sure sign of bad problems down the road. I recommend Backing up all you data and replacing the drive as soon as possible. The drive is failing. Hope this was helpful.
George
Jul 16, 2008 | Computers & Internet
Pxe-e61 media test failure. i have managed to get the computer into safe mode but will not run in normal mode why is this and how can i fix it?
This issue is often caused by either an incorrect setting in bios or a bad boot device, such as a bad hard disk drive. To resolve this issue, run scandisk to check if the hard drive have develop a bad sector. Double click mycomputer and right click drive C: and select properties,tools,check now and check the the two options in the check this option windows and reboot your computer. During the reboot of computer the scandisk is check your harddisk after the scandisk finished scanning you can read the result if you see the bad sector or cluster found it's mean that your hard drive is damage in you need to replace it to correct the error. But if no bad sector found try to remove the software or hardware that you installed before the problem is occured go to control panel then add and remove software. if you have a registry scanner software like pctools registry mechanic try to run it to fix the problem in the registry.
Apr 16, 2008 | Computers & Internet
Harddisk fault
Hello!
Just try scandisk, Right click your c: and then properties, in tools menu, click check disk or scandisk.
may this help.
melnavz
Mar 03, 2008 | Compaq Presario 5000 PC Desktop
Bad sectors in hard disk
Search in google.com for program BAD SECTOR REPAIR
Feb 28, 2008 | Computers & Internet
Computers & Internet Logo
290 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
