No av signal from dvd player to tv ?
Could you please tell me what would cause this problem , i have sound but no picture from my dvd payer my tv is a RP philips 43pp925/79 ?
Many thanks
Shane
    Habit-Forming:
  • 166 Answers
First check scart lead is plugged in correctly and squarly at DVD and TV ends
Posted on Jul 18, 2008
What channel do I set the TV on so that the dvd will play
Hook audio/ video cable from dvd player to AV input of tv and select that AV input in tv to watch dvd playback picture.
You will see yellow jack (for video signal output) and red-white jacks (for audio left-right output signal) at rear of dvd player, plug AV Cable and hook it in AV input of tv, make sure yellow pin connected in yellow jacks of dvd and tv.
Thanks.
Feb 18, 2011 | Sony DVP-SR200P DVD Player
Hi i have an alba tv , im trying to connect a dvd player. I have connected the scart leads etc.I can not get onto the av channel so i can watch a dvd. Please help
Firstly, please make sure you have connected the SCART cable correctly. This should be connected to a SCART OUT socket on the DVD player to one of the SCART IN or EXT sockets on the rear of the TV.
If you have correctly connected the SCART cable the TV should automatically switch to the AV channel when you switch the DVD player power on or insert a disc.
Switch your TV on, then switch the DVD player off and then on again. If the TV does not change to the AV channel you may have the SCART cable connected incorrectly.
Not all TVs automatically switch to the AV channel when the AV device is switched on. On some TVs the AV input is on channel 0 or 99. On other TVs the AV input is not assigned to a specific channel. On these TVs you need to look for a button marked "AV", "INPUT" or "SOURCE" - either on the TV remote or on the buttons on the front of the TV. The easiest way to do this is to insert a disk into the DVD player and start it playing. Then press the "AV" "INPUT" or "SOURCE" button (whichever one you have) repeatedly until you find the signal from the DVD player.
Please check your connections and try using the "AV" "INPUT" or "SOURCE" buttons. If you are still unable to watch your DVD player, please post back with the following information:
1. Model number of the Bush TV
2. Brand and model number of the DVD player
3. If you are using any remote other than the ones supplied with the TV or DVD player, the brand and model number of the remote.
I will then be able to tell you exactly how it should be connected and which buttons (if any) you need to press to access the AV channel.
Hope this helps. Happy New Year!
Regards,
BElectric
Jan 01, 2011 | Televison & Video
Trutech tv - no sound, but have picture
Check if you would have the same if you use a different signal source. Another DVD Player, a playstation or other AV devices. The source or the TV may not be understanding each other, one may be sending analog signals while TV is only recognizing digital.
Oct 10, 2009 | TruTech PVS31170S1W 17 in. LCD Television
I have a 32" LCD TV that I can't seem to get any of my DVD players to work on. Keep getting error message "no video signal" but They use to work. help
How do you have your DVD player hooked up to your TV(i.e. composite, s-video, component)? Some DVD payers and TVs have menus to switch inputs and if you somehow switched off the input your players are connected to, you'll get a "no signal" message.  First try hitting the input button on your TV or the Input/connection option in your TV's menu.  If that doesn't work try hooking up the DVD player(s) with the composite Cable(yellow), the component(red,green,blue) and S-Video(black/round) at the same time. If you scroll through your TV's inputs you should get a picture on one of these connections and the TV should display which one. The display will usually be in the corner of the screen.
Apr 27, 2009 | Televison & Video
How do I conenct player to tv
  1. Yellow wire is picture and the 2 red is sound
at the dvd player plug in the picture wire by av out, at the tv plug the yellow wire in av in.
The sound is the same sound out at the dvd player look for a L R this means left and right at the tv there should under av in next to the picture wire you pluge the soun in
hope this is clear to you
Jan 04, 2009 | RCA DRC220N DVD Player
No picture
Look under your tv settings for the pal ntc settings if you are using the av wire, if not please tell my what yoiu are using, also mak sure that youve pluged the av wire in the yello conecter av out on dvd/vhs and @ the tv AV in
Jan 03, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Color Issues
this sounds like a connection problem. are the scart or av leads ok whatever you are using ? if so then the most likely cause is the signal interface inside the tv. try connecting with a different connection system
Dec 13, 2017 | Samsung TX-P2730 TV
LG video/vcr. I can hear the movie sound track playing but there is no picture. The video screen says"Pscan" - I can see no button on the remote or video
your AV leads are probably connected wrong,you need send signal from.......to on the yellow lead
ie from dvd player TO telle,using AV inputs on telle,then swith telle to AV 0r 2
Jul 15, 2008 | Televison & Video
No picyure
you havent connected the av leads properly,red and white are for sound and should go from audio out on tv to audio in on sound system,
yellow lead is for picture (aka video) goes video out on dvd player.to video in on TV
basically you need sent video signal from......to
normally have to use AV inputs,so u need turn telle to AV1 or 2
Jul 07, 2008 | Durabrand STS92 System
NO sound and NO cable signals
Is your tv connected to your cable box through HDMI, AV, or component?
_____________________________
If its through HDMI then your cable carrier needs to load updated frimware in your box to communicate properly with your 2005 tv. The firmware loaded in your cable box needs to be "reverse compatible" for first generation HDMI from your 2005 tv. If your using AV or component hook-up and there's no sound then re-check all of your audio settings within the tv's menu. Also recheck the cable-wire your using and proper input/output ports.
ON your dvd player, is your tv connected through component, AV(rca) or HDMI?
If its through "component" then you need an extra audio cable to and from the DVD and tv.
May 07, 2008 | Akai LCT2060 Television
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
