Question about GE 27GT616 27" TV
Unknowing fuse greeting all.. My DAEWOO TV fuse is blown up. I wnat to replace it but I don't knwo which fuse I can use because my blown fuse is lost. I don't know which type I can use. please help me. Thank you.
  • GE Master
  • 5,138 Answers
Go to a parts or supply house aks for 5amp fuse ,if after putting in new fuse and if set blows it again then you have somthing else that has shorted.hori output, diode or fuse resistor.
Posted on Jul 20, 2008
    President:
  • 1,284 Answers
In most cases on the board under the fuse the rating will be listed IE: 4A, 5A etc.
Posted on Jul 19, 2008
Dash vents and defroster
as always check all fuses in cab and engine bay boxes.
fuse # 7,11, 13. & 22.. the names are in the glove box operators guide, lost the guide? its free.
2005, Daewoo. the car with 8 names. its really a Daewoo.
what vents, there are many, name one. (parked or driving fast?)
Does this post mean the blower is dead,? and on HIGH
surely you'd notice the blower, dead silent?
my best guess, is one of 4 fuses blown.
Nov 18, 2013 | 2005 Suzuki Forenza
Samsung LN55B640 LCD TV blowing fuses
when the fuse always blown, it could be a shorted component at the power supply board or the main board was affected during lightning where in some of the component get burned then cause a shorted line.if you don't have an idea in any electronic repair just leave it to the trained technician to do the works. hope this can help you thanks for using the fixya.
Jul 18, 2012 | Samsung LN55B640 LCD TV
I Have 2004 43' inch Daewoo model DSJ-4710CRA will power on but cuts right back off any fixes?
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.
Mar 30, 2012 | Daewoo DSJ-4710CRA 47" Rear Projection...
The 125v 8 amp fuse in the back of the tv is blown and the tv wont come on. could this be the only problem and where can i find this fuse. i have tried several locations and can not find one
Hello, an 8 amp fuse that is blown is more than likely an indicator of more serious problems, but if you wnat to try another fuse make sure you get the same amperage as the one that came with the TV(8A-250V), try radioshack they still carry some replacement electronic parts.
Nov 18, 2010 | HP LC3760N 37 in. LCD HDTV
Daewoo rotating base
You can visit Daewoo online or call them at 877-393-7823 or 973-249-3448 to find parts.
May 24, 2009 | Daewoo KOR-630A Microwave Oven
DAEWOO TV
If youe tech inclined you can open the unit and see if the fuse is blown if you are uncomfertable on doing that then your going to need to take it into a repair shop.
Apr 21, 2009 | Daewoo DTQ-27S5FC 27" TV
Cigarette Lighter
try a fuse tester to see which fuse is blown
Jul 22, 2008 | 2002 Daewoo Lanos
TX-R3079WHX/XAA Blown fuse
greetings from belize make good checks in your power supply replace your voltage regulator it has an short which is activated after accumulating heat.change the horizontal transistor.and the bias diode the feeds to the B+ to the flyback.if that does not solve the problem replace the flyback.your problem is intermittent so you cannot check voltage just replace components matter of fact replace all the components in the power supply you can buy a kit from www.dalbani.com in miami florida.good luck.
Dec 27, 2006 | Samsung TX-R3080 30" TV
Televison & Video Logo
78 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
