Question about Fisher and Paykel Dishwashers
F&P Nautilus model 920 Dishwasher
Hey guys,
replaced a front panel and handle on a dishwasher as above
the latch was different so i unscrewed the original and when trying to
attach the new 1 the bolts went right thru i.e the nuts im guessing that were attached had moved they were not fixed . would any1 recommend self taping screw even though the wall thickness is only about 1 mm or is there a better way to do it ??
  • jajajajaja Jul 18, 2008
    thanks 4 ya help a friend reminded me of a nutset which is used using a pop rivet gun as your suggestion above .
    so dishwasher repaired thanks for the suggestions . the biggest concern was the ammount of space from the hole to the top of the casing but all was well
  • 833 Answers
That is certainly an option. Be sure the screw you use is plated or stainless and not so long as to cause a dent in the other side.
A second idea is to get plastic wall anchors used for gypsum wall board and insert them into the holes in your sheet metal. You can then install screws that come with them to complete a repair. Metal ones will also work but you do have depth issues and there are installation problems you'll likely encounter.
Obviously, you can also remove the panel cover and use appropriate fasteners to complete the repair...but here's another idea:
There is an item made by a company called Harbor Freight which will install a SAE threaded sleeve (not metric) made of aluminum into sheet metal. It comes with various sizes of sleeve. It works like a pop rivet tool. Find it here: http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=1210
Posted on Jul 18, 2008
GE dishwasher model GLD5868V15SS handle loose
This model comes with two types of doors. One with a single panel with integrated control on top or a two part door with control unit in front. The handle varies.
If you have a single door panel with handle bar across from right to left then you need to carefully unscrew the back panel screws and free up the front panel. the handle is screwed to the front panel from inside. Once you tighten carefully put the back door panel in and tighten. Take photos along the way to make sure you get back where you started. Also unplug dishwasher before working on it.
If you have a two part door with front control then handle and access to it is different. See diagram on this website for blow up of the panel and location of handle (part 713).
ESCUTCHEON DOOR ASSEMBLY Diagram Parts List for Model GLD5868V15SS GE...
You can magnify the image or take a full screen view for clarity.
Aug 29, 2014 | Dishwashers
Door latch
The safety latch needs adjustment or is loose or worn out if you open the door on door side top you would be able to feel the the safety switch with your finger click on and off it should click very easy if not replace it make sure Dw is off or disconnected.good luck
Oct 14, 2013 | GE Nautilus 24" Built-in Dishwasher
Soap dispenser will not lock closed
This happened to mine, too. there was a wire wrapped around the latch that needed to be unwrapped and then retaped to the rest of the wires. Had to unscrew the front door and then could find the problem.
Mar 20, 2010 | GE Nautilus 24" Built-in Dishwasher
Need to replace front door panel
Not sure, but I think these guys can help you. www.applianceart.com. They specialize in dishwasher doors.
Feb 14, 2010 | GE Nautilus 24" Built-in Dishwasher
Leaking dishwasher
i had a ge that leaked in front, needed to replace rubber door gasket....
Nov 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Front door panel, stainless for GE dishwasher
Ebay has a guy selling stainless panels, cut to size; search dishwasher stainless panel
Jun 09, 2008 | GE Nautilus 24" Built-in Dishwasher
Fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Mar 19, 2008 | Dishwashers
DISHWASHER WILL NOT POWER ON AND THERE IS POWER TO THE OUTLET
more than likely the door catch switch or the on off button, check these 2 first
Oct 13, 2007 | GE 24 in. PDW9880LSS Stainless Steel...
Dishwashers Logo
181 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Gere knutson
Blake
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
