I cant connect or find a code to set up my Sony RDR-HXD760 hdd dvd recorder to my audiosonic tv?? all cords and aerials in right, still no signal on any AV station?€??
  • d_n_shaw Jul 20, 2008
    Its antenna..foxtel and dvd players hook up fine.
  • 979 Answers
What is your source signal; Antenna, Cable or satellite?
Posted on Jul 20, 2008
  • Michael Borelli Jul 20, 2008
    Okay. Be sure that the antenna connects to the recorder first, and then it's output goes to your TV. The DVD will connect to one of your "Line in" connections on the back of you TV, and will require you to select "Source" to switch in between the two. If that's the way you have things connected right now, I'd say you have a set of bad cables, (unlikely) or a defective device...accordianman
Connect sony dvd to samsung tv
There are five ways to get the video and audio signals from the DVD player: HDMI, Coaxial, Audio/Video, S-video and Component video, which way did you use?
Jun 07, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Can't tune in tv with dvd freeview.it states ext link problem
If you've connected the DVD to the TV via HDMI or SCART you shouldn't need to 'tune it in', just select the HDMI or SCART input. If your TV is also a Freeview device and you want to tune it to Freeview, where you have the aerial connected to the DVD recorder, you need to also connect the DVD recorder to the TV via an RF cable or aerial flylead so that the aerial signal passes through the DVD recorder. It's all in the instructions
Oct 16, 2013 | Panasonic DMR-EX75EB-S DVD Recorder/HDD...
Sony RDR-HXD560 with terrible picture quality
to get the part you need to go to the company to check what the problem is then if you will have to change circuit board you can get it right from them.
May 31, 2010 | Sony RDR-VX560 DVD Recorder/VCR
Connecting my laptop to DVD recorder and recording onto the recor
You FIRST need a way to get the Signal, INTO the laptop, you need to get a USB to TV/Video Dongle, Now using this and the software that came with it, as well as other software, You Hook up the OUTPUT from the DVD Player, to the Video Input on the USB Dongle, Either, Component (Best) or Composite, (OK) Video, and AV Audio, and set to "Record" on the PC, and "Play" the DVD and then the PC will "Record" the incoming signal from, the DVD player, to the HDD in the PC. Once digitised, and saved it can be manipulated, any way you want.
Now if you want to do the REVERSE IE: Take a signal FROM the PC, to the DVD, then you simply setup the DVD as a Second monitor, use a TV to set it all up, once it is all working on the Laptop and TV, simply swing the Output, away from the TV's Input, to the DVD's Input,and select record, the PC, will then output whatever, to the screen, and whatever is displayed on-screen, will be recorded by the DVD's hard drive.
You First though must setup the PC to have multiple monitors, it is best to get the most up to date drivers and install them in the PC. FIRST. Go to this MS link below it shows you how to set u,setup as CLONE mode, I think will be best, also don't set initial resolution too high to start, set it to say 800x600 32 bit, to start, and work up, until your TV complains and stop. As related once setup, swing the PC's output to the DVD, and record.
http://support.microsoft.com/kb/307873
May 08, 2010 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Connecting DVD recorder to TV and SKY box
A simple solution - aerial input socket error - wrong socket!!
There are too many choices on the DVD record/play machine. When the plug came out - it was pushed back into the wrong socket.
Nov 30, 2009 | Sony RDR-GX300 DVD Recorder
Sony DVD recorder RDH-HXD760
I am experiencing exactly the same problem. I think this product/model is a lemon. The stated issue of a faulty optical lens could be true in that I have had untold failures during playback (skipping chapters) especially of rental dvd even after disk cleaning etc. I guess I will need to have my set fixed (only if I can get warranty) or buy another product (possibly not Sony this time). Sometimes I wonder if these conditions are planned to occur in support of the economy. Phill W.
Jun 17, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
I cant get new RDR-HXD990 DVD recorder to record to the harddrive
We sought assistance from someone in the neighbourhood and they were able to assist us with easier instructions than the long winded directions in the manual.
Apr 18, 2009 | Sony RDR-HX510S DVD Recorder/HDD Recorder
DVD recorder won't start up properly
model number :RDH-HXD760. The problem is it won't start up correctly. The welcome message stay on and nothing further happens.
I have replaced all the caps( C105 400V 120uF and 2 of 10V 3900uF no needs) in power supply. It back to work !!!
John Chew
Apr 08, 2009 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Connecting and recording sony hdtv, rdr-hx780 recorder,sony dream system
I have the same system, except for the TV, I have a project (that part doesn't matter).
From your Sat. go straight to your AV receiver
Again from you Sat. (all of the AV outputs are all live), go out from either 1 or 2 and go to your recorder Line 1 in.
From you AV receiver go to your TV.
All you have to do is hit record and you will record whichever channel you are on. I am having difficulty getting it set up as a PVR, but will figure it out sooner or later.
Hope this helped.
Oct 20, 2008 | Sony RDR-GX300 DVD Recorder
Sony rdr hx510
i think its your tv. Have you got a widescreen tv?  when i changed my old tv for an lcd the problem disapeared
May 07, 2008 | Sony RDR-HX510S DVD Recorder/HDD Recorder
Televison & Video Logo
151 people viewed this question
Top Televison & Video Experts
