Question about Wacom Intuos3 Graphic Tablet
New Wacom Intuos 6x8 Graphics Tablet with a Serial connection (using a USB converter) work with Vista?
Hello, I have an Old giant wacom tablet( UD 1212-R) I bought a USB converter for (Belkin) for my new Vista Laptop.. ZERO luck there .
So I'm a little Leary when i was told I can use my New 40.00 Belkin converter with Vista if I buy a serial Wacom Intuos 6x8 Graphics Tablet.
What do you think? please
  • 1 more comment
  • davlon Nov 05, 2008
    I have the same problem. Surely someone has found a solution? I am desperate.
  • Potmakeur Dec 11, 2008
    Can't get my old wacom ud1212r tablet to work on windows xp prof
    Anyone know how?
  • Anonymous Mar 15, 2014
    RUNTIME ERROR
Searched for ages to find a driver for my giant wacom (UD-1212-R) on Vista 64. As of this moment there isn't one, and it looks like they are not even going to bother. But if there are any geniuses out there........
Posted on Nov 05, 2008
  • john waddell
    john waddell Oct 28, 2013
    not to technical .myself.dontreally know? sorry not much help got to go. tah bye .
Where can i get a wacom bamboo tablet?
You can buy them new from places like Amazon or directly from Wacom. Just to confuse you more-- it used to be Bamboo, Intuos, and Cintiq. Now the entry level tablets are the Intuos, the mid-level has become the Intuos Pro, and then the Cintiq.
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=wacom+bamboo
https://store.wacom.com/us/intuos-pen-touch/
Feb 25, 2015 | Wacom Bamboo Computers & Internet
Where can I get a replacement USB cord for intuos 4 wacom tablet?
depends on the connector, looks like it could be a standard usb cable.
if it looks like this, standard usb cable.
There is also a micro 5 pin, used on most new cellphones.
or it could be a mini usb used for most cameras.
All pretty standard, one should fit. Good luck!
Apr 18, 2013 | Wacom TABLET INTUOS 4 SMALL PEN TABLET
Wacom Intuos 3 problems
Hi Bengref
Just talked to WACOM USA about a similar (but not exactly the same) problem with my Intuos 3. One of their procedures was;
go to the ALL Programs directory,
go to the the WACOM TABLET directory
open the WACOM Tablet Properties window
click on the "About" button
while holding down the CTRL key, click on the "Diagnose" button
click on the "recalibrate" button
Another procedure
go to the All Programs Directory
go to the WACOM Tablet Directory
click on the :WACOM Table Preference File Utility"
Under "My Preferences" click on remove
Good Luck
BobS
May 19, 2010 | Wacom Intuos3 Graphic Tablet
WACOM GD-0608-U and Window 7
I had the same good results. Just clicked on Intros and Windows 7 to download the driver fro my model GD -0608-U tablet
Jan 17, 2010 | Wacom Intuos A4 Graphic Tablet
Wacom intuos3 pen is not working
A few hours ago Wacom released a new driver 6.1.2-5 for the Windows 7/Vista/XP operating systems. I was having the same problem. Hopefully this will be a permanent fix!
http://www.wacom.com/downloads/driver-detail.php?id=200
Nov 19, 2009 | Wacom Intuos3 Graphic Tablet
ERROR message "A Supported Tablet was not found on the system"
I have encountered this message a few times, usually if I have tried to plug'n'play the tablet. A restart with the tablet connected usually fixes it for me, but I would suggest removing the driver and software and reinstalling them, making sure you have the most up-to-date version- freely available from wacom.co.uk (though I note you have the latest versions so just reinstall those).
I think, however, your problem might be something to do with the following note from wacom:771c281.png Do you know if you are running a 64-bit setup? There may be a workaround even if you are, so do let us know.
Oct 28, 2009 | Wacom Intuos2
Have the graphire 3 tablet, Not working well.
Wacom tablet not plugged into your computer with the USB cable.
Go to Add/Remove Programs, (Start>Control Panel>Add/Remove Programs), and -> Remove
the Wacom software.
Restart your computer.
After Windows XP has fully loaded again, install the Wacom Graphire 3 CD, in your CD/DVD drive. Reinstall the software.
If you had to reinstall your Windows XP operating system, you may have corrupted some of the Wacom tablet's drivers. (Hence the shaky stylus cursor) Removing the Wacom software, and reinstalling it will repair.
Now plug the Wacom tablet into your computer.
You should see the, "Found New Hardware", pop-up out of your taskbar tray.
Jul 16, 2009 | Wacom Graphire3 White 6X8 USB (cte630pe)...
Bit of a problem installing Wacom Intuos2 with serial converter
you can check in the internet for the new driver and u can install like in XP and you dont find send the model number and the name and i will check for u
Nov 22, 2008 | Wacom (PTZ930AC) Graphic Tablet
Wacom serial power to usb connection
If your table has a USB connection and requires a powered USB port, then don't waste your money or time. If it's the other way around and the table is powered from another source, the converter will likely work.
Jul 19, 2008 | Wacom (PTZ930AC) Graphic Tablet
Serial to usb wacom tablet problem
I just got Vista and it killed my Intuos2 w/serial to usb also, but here's a half solution:
Download Wacom driver 4.78-6 http://www.wacom-europe.com/int/downloads/driver/driver.asp?lang=en. Make sure you remove any other Wacom drivers, tablet, and reboot. Install 4.78-6 driver and select serial port when the choice pops up. Plug in your tablet with the serial to usb adapter, wait a few seconds and click retry. Complete the install and reboot.
Your Wacom tracking should work now, but certain things might not work like pressure sensitivity and you'll get annoying error "reinstall driver" pop-ups.
I think you can aslo buy a PCI-serial card for your computer and skip the serial-usb adapter since Vista doesn't support the adapter for Wacom tablets.. but I'm not sure if there's a working Vista serial Wacom driver either.. or ever will be. The age of XP and Legacy support is at an end my friends.
Dec 03, 2007 | Wacom (PTZ930AC) Graphic Tablet
Wacom Intuos3 Graphic Tablet Logo
1,089 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
William F. Bryant Jr
Level 1 Expert
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
