Question about HP Computers & Internet
Input2:HD15 keeps coming up on my computer - HP Computers & Internet
  • Jeff Pankow May 11, 2010
    When do you get this error message?
    I do not believe that this would have anything to do with your hard drive or your motherboard.
    HD15 is the standard 15-pin analog connection for a computer monitor.
    Input 2 would refer to the second input into your video monitor. I would anticipate that your monitor is throwing the message. Which leads me to my next question: What is the make and model of your monitor?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 95 Answers
Hi
Your hard drive was in place with a different motherboard. That motherboard had a different chipset, different features, different drivers, and when your computer boots up it is looking for an entirely different motherboard and starting to load an entirely different set of drivers. So by redone I was asking if it had been reformatted and the operating system reinstalled.
You see, it is not just as simple as popping in a different mobo...because all motherboards are not the same. Even Pentium-based boards are not the same. I have seen the same situation many times, and in some cases like yours the computer will go through this repetitive cycle of rebooting because of the change. Try booting up in safe mode (do you know how to do this?) and see if you can get to the desktop. Typically, I usually reinstall the OS, apps, and files....and the problem is usually solved. Jyothish
Posted on Jul 18, 2008
You very likely have aquired a Sony flatsceen with an input control on the panel.The input button allow you to have three monitors connected to your PC and by using the "input" control ,you can switch from one monitor to the other-mostly used in Microsoft Games like flightsimulator where you want 3D imaging.Iwould suggest you try the "Input" button for the correct input signal.Regards
Posted on Jul 21, 2008
2 Suggested Answers
  • 53 Answers
SOURCE: iNPUT2: HD15 keeps coming up on my screen. i cant
more information is needed for this question to be answered properly
im going to guss that this is your conection cable from video card to your monitor
try disconecting and reconecting the cable making shur that the cable is firmly conected at both ends
its posible that part of the tower case is preventing the full insertion of the cable into the socket
cut away 1/8 inch of the ruber shielding around the pc side of the cable so that it can fully be inserted into the conection
check that the pins on the male conection arn't bent or broken off
also run your closed hand down the cable itself checking for cracks cuts or breaks in the cable
if any problem is seen replace the cable if any pins are broken off check the femal reciver for the broken of part of the pin so as to not damage anothere cord
good luck
Posted on Feb 25, 2010
Is there a cable available to view on TV via RCA plugs?
I am not going to say no for sure but 90 percent sure there is not. The problem is you would have to scale the signal down to a composite signal. Now that can be done but at a pretty hefty cost and that is if the cable is available to come off of your tablet. From there it would have to go from 1080P to HD15. Then you would have to have a HD15 to composite scale converter. Then go to the tvs RCA input. The scale converter, the right one, is going to be about 200 bucks.
Mar 21, 2016 | Mach Speed Trio Stealth G2 Tablet -...
Motor runs but no mist comes out on EV-HD15
If there is water in it, it sounds like the ultrasonic unit failed.
Dec 05, 2014 | Sharper Image EV-HD15 Cool Mist Ultrasonic...
My monitor says: "No input
First, are you using the VGA cable (cable with 15-pin on each end), or DVI cable?
It can be that the PC is not sending out the video signals, or loose cable connections, please check that first. You can also try this monitor with another PC to narrow down the problem.
Please post back what you find for further help.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: http://interliquidparts.com/
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 07, 2011 | Sony Computers & Internet
I want to change my 15 pin vga cable to my monitor
There are two types of cable set up with VGA monitors. The newer ones have a cable that is detachable at both ends. In other words the cable can be unplugged from the monitor and the computer. These, of course are easily changed. They can be purchased at places like Best Buys,
CompUSA, TigerDirect.com. Below is a listing on Ebay for a replacement for about 8 dollars including shipping.
SVGA-VGA-HD15-/280624443642?pt=LH_DefaultDomain_0&hash=item41568530fa">
http://cgi.ebay.com/Male-to-Male-15ft-PC-Monitor-Cable-Cord-SVGA-VGA-HD15-/280624443642?pt=LH_DefaultDomain_0&hash=item41568530fa
If you have the type of cable that is permanantly mounted to the back of the monitor, then you would have an extensive operation to replace the cable and it would likely be more expensive than the monitor was in the first place to replace it.
Hope this helps,
Best Regards,
Mark
Feb 03, 2011 | Computers & Internet
INPUT2: HD15 keeps coming up on my screen. i cant get through it. do i need to buy new input2: HD15 cable? the monitor is sony make and the hardrive is fujitsu siemens computer make
good luck
Feb 24, 2010 | Computers & Internet
I just got a 37 inch flat screen. I had it working with my direct TV box. My son pushed a button on the remote and now it will not connect to the direct TV. I need some help.
You will need to look for your input button on the tv or the remote and look at the back of your tv to see where your wires go!!!
You would make sure that the wires go to (input 1) are input2
Then you put your input on input1 are input2 and your wires in input1 are input2 on the back of the tv.
Feb 17, 2010 | Insignia 37" LCD Flat-Panel HDTV
I turn on the desktop and the monitor only says no input signal input2: HD15 go to power save what do i do?
Did you try to use two monitors and put this one on input two? If so, reboot in safe mode and set the settings right by going to Control Panel->Display->settings. There select the No 1 monitor and then reboot.
Oct 11, 2009 | Office Equipment & Supplies
INPUT2: HD15
Seems to be some problem with your monitor not with your computer. Check monitor settings.
Oct 01, 2008 | Computers & Internet
Breakout cable usage
PROFESSIONAL REPAIRER OF:
* cd-vcd-dvd-ld player.
* colour tv, Lcd/plasma tv.
* projection tv.
* prologic AMPS
* Grill/microwave oven's
* Digital proffesional camera.
* Digital camcorders.
* LCD/Digital projector.
* Hi-Fi music system.
* FAX machine.
* printer/scanner/copier.
* play station (PS1-PS2).
* X-BOX360.
DIAL..........: 9820380682
Oct 15, 2007 | Panasonic TH-42PWD5UY 42 in. Television
Computers & Internet Logo
1,001 people viewed this question
Top HP Computers & Internet Experts
joecoolvette
joecoolvette
Brian Sullivan
Brian Sullivan
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
