Question about Packard Bell Easy One Silver 2120 Notebook
MY LAPTOP STARTS SHOWA BLUE SCREEN THEN CLOSES DOWN
PACKARD BELL
  • 115 Answers
It seems like the Ram is faulty.
Viren
Posted on Jul 17, 2008
Our packard bell easy note te69kb laptop is stuck on shutting down screen as if it didn't close properly when last used
I suspect there has just been a windows update and it is confused. If it won't close down, hold the power button down until it does and than re boot. The issue should clear.
Mar 25, 2016 | Packard Bell Computers & Internet
Installed memory
It could be a bad memory module or just not properly seated in the slot. Does it work when you remove what you just added?
Nov 26, 2013 | Packard Bell EASYNOTE MV35202 COMPATIBLE...
Packard bell laptop wont power up.
You need to check your charger first. Use a voltmeter to make sure that the output matches the prescribed output.
Oct 01, 2013 | Packard Bell Computers & Internet
Model: Packard Bell Easynote GN45 - Display has "shifted" to the left; thick black chunk down the right hand side of the screen. Display at top of screen also appears at the bottom of the...
Test the laptop using an external monitor
If this works fine, then the issue is with the screen, or possibly the vga cable. I notice this is referred to as a compatible screen, was this obtained new, or is it 2nd hand. Although most 15.4 screens fit most 15.4 laptops, some do not display correctly, this might be your problem. If you know the screen to be good I would suspect the connection at the back of the screen
If this still shows issues with an external monitor, you have a problem with your graphics chip on the motherboard
Jan 22, 2011 | Packard Bell EASYNOTE GN45 COMPATIBLE...
Packard Bell laptop 4 way split screen
yes,when it switches on click on start windows normally
Apr 14, 2010 | HP Computers & Internet
Packard bell easy note tj65 will not power up
the short cable running from the power button to the main board has probably snapped where it passes over the RH hinge. remove the screen surround to gain access to the power on switch area and check. it would seem to be a common fault with the packard bell
Mar 07, 2010 | Acer Computers & Internet
My packard bell easy note laptop keeps flashing off,i have to put the top right back then slowly forwards again so it works
There is a ribbon cable connecting things together.
Sometimes they crack.
Sometimes they are in the hinge area and may be able to be replaced
but would be expensive at a shop and a bit technical.
There could also be dirt or a sugar liquid like pop or coffee spilled inside the on/off or hinge switch (a little switch that is pushed when the laptop closes, usually near the jam or could be inside casing.) and this could be causing a short.
Probably ribbon cable, may not be able to be replaced! without replacing screen. Here's hoping for you. This is generalized information and not P.Bell specific..
Need more info as to whether is just screen or whole laptop going off/on.
Good luck, hope this helps some.
Feb 23, 2010 | Packard Bell iMedia SL 9553 (P660401806)...
6 screens showing on laptop
If you have the correct type of mouse on Windows XP and the scroll wheel clicks, this is what you have done click it again to return to the normal desktop. I think that you will find that you have the BSOD (blue screen of death) have you recently installed new memory or installed a USB device like a memory stick.
If you hit F8 on startup and then start the windows with last known good config this might start up correctly. If this fails then could you let me know what one of the blue screens says.
Enter Safe mode and then install this reg tweak to disable BSOD and then restart you should be able to read what the screen says.
I believe that this is something that has been developed in Vista to make it easier to see you minimized windows.
LOL
Oct 06, 2009 | Packard Bell Easy One Silver 2120 Notebook
No bootable cd in AT API CD-ROM - Packard Bell E2315
Shut the machine down. Start her up As soon a POST comes up[the black and white screen] start holding down F8 You will get a screen come up with varios options. use uodown arros to Start on last known.. that worked Press return.
May 28, 2007 | Packard Bell Easy One Silver 2101 Notebook
Packard Bell Easy One Silver 2120 Notebook Logo
61 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
