Question about Hotpoint Washing Machines
Hotpoint 1100 aquarius stopped spinning - Hotpoint Washing Machines
  • rapo Mar 23, 2009
    my 1100 has stopped spinning, it sounds as if it is trying to and the motor is turning the belt sporadically which is not enough to turn the drum. any ideas would be appreciated. thanks. rob.
  • the_stephste May 15, 2009
    I have a Hotpoint Aquarius which now will not spin
I just had this problem. What had happened was the power connector to the motor had shaken out (a white block on the back of the motor, accessible through the machine's top panel).Pop the connector back in, with the power turned off, and glue the block in place. Turn the power on and you should be good to go!
If that's not sorted it, your motor brushes might need replacing. This is easily done, and there are articles on the net to help.
Posted on Jun 29, 2009
Check the coupler
Posted on Jul 18, 2008
Hotpoint Aquarius 1100 WM63 Not Spinning Clicking Programmer
I would suggest you check the brushes in the motor, as it sounds like they are worn out.
Replace them if they are less than 3 or 4 mm long
This would give you the symptoms you are describing.
Please rate my solution.
Thankyou.
Feb 09, 2010 | Hotpoint Aquarius WF000 Front Load Washer
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Aquarius 1100 - door won't open
lift lid of top reach to front and pull the wire cable up to the door latch make sure u unplug machine first
Sep 07, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint Aquarius 1100 WM63. fills with water...I dont think it is heating water...rarely rotates and spins (saw it once in early stage of J prog only) seems to fill and empty but no rotate or spin....
if it fill with water then stops it is the ellement the machine first fills turns the drum then heats up the thermostat cuts in and the it emptys rinses and spins so if it does not get to temp it will stop or continue to wash forever
Jun 27, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Can you please give me part number, price & delivery on an on - off switch for a Hotpoint washing machine WF215 1100 SPIN AQUARIUS. Thank you, hamolloy@gmail.com
Try these sites for spares, what you asked for is available here:
RepairClinic.com espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 01, 2009 | Hotpoint Aquarius WF215 Front Load Washer
Hotpoint aquarius 1100 bangs while spinning
Several possible reasons for this. M/C not level, causing it to move about.
Overloading of m/c.
Loose concrete balance weight, there is one at top and one at bottom.
Suspension spring broken or unhooked.
Suspension leg loose or broken.
Main drum bearings worn, to check this, turn drum by hand and if it feels noisy or rough , then bearings have gone (expensive repair).
There are other possible causes, but these are the main reasons.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius 1100 spin WMA31
I have just had the same problem too, i fixed it by reattaching the belt and making sure that the belt at the motor was flush with the edge of the motor spindle, right at the end, it looks dodgy, but it works
May 29, 2008 | Hotpoint Washing Machines
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
216 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
