Question about Lexmark Office Equipment & Supplies
LEXMARK X5470 PAPER JAMNED INSIDE PRINTER,UNABLE TO REMOVE.CAN I PURCHASE INSTRUCTION ON HOW TO DISMANTLE.
    Novelist:
  • 158 Answers
Try forcing a sheet of paper or thin cardboard through the paper path in the direction the paper feeds. This may push out the jam so you can reach it.
Posted on Jul 18, 2008
    Sergeant:
    Champion:
  • 246 Answers
Sorry in this kind of printers can't use the cardboard paper .
Posted on Jul 22, 2008
Rint,copy,scan or fax on my x5470 lexmark all in one. I unplug and restart compture and the fax still says paper jam check rollars dont see noughting.
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Dec 09, 2011 | Lexmark X5470 All-In-One InkJet Printer
PAPER JAM - CAN'T FIND THE PAPER. IS THERE A WAY TO REACH PAPER WITHIN MACHINE?
Open the printer cover and access the cartridge area. You should be able to see the paper jam. Carefully remove the paper and avoid tearing it. Any torn paper left inside the printer could cause future paper jams.
May 01, 2011 | Lexmark X5470 All-In-One InkJet Printer
I don't see a paper jam, but that is the error i keep getting. it will let me print or copy anything. the printer i have is a lexmark x5470
Leading cause of paper jams is debris/foreign objects that have accidentally fallen into the paper feed area.
2. Grab a flashlight and look inside for any debris.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris that could cause this error or problem.
6. If cartridge area is clear, close the cover.
7. Unplug and re-plug the printer into the power outlet to reset it.
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
Apr 26, 2011 | Lexmark X5470 All-In-One InkJet Printer
Ink leakage inside printer lexmark x5470
Try cleaning as much of the ink as possible. If still unable to get most of it out you may need to have a profesional cleaning done by a technician.
Jun 03, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper doesn't feed
Hi, The problem could be an object inside the Auto document feeder that could be blocking the path of the paper or preventing the feed roller from feeding the paper. You can try the following, Turn off the printer, unplug it from the power cord, then remove the paper and then turn the printer upside down and shake it a little bit, sometimes this will help remove any objects inside the printer.
Feb 05, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper will not feed into printer, even with hand pushing on paper. rollers do not grab the paper.
My lexmark x5470 printer is jammed inside and I cant seem to be able to open it in order to get the paper jam out of it. Any suggestions?
You can try the following. Press and hold the check mark untill you hear the printer turning the rollers. That will cause the printer to try to feed a paper sheet. If that does not pulls the jammed paper out then you will probably have to find a way to remove maybe using some long nose pliers.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark 5400 printer, paper not feeding, help
You can try the following. Remove all paper from the printer and turn printer off. Try opening the printer as if you were to remove the ink cartridges and check for any paper jammed in the printer. If there is a paper jammed try to remove it. if there is no paper jammed in the printer then try the following remove all paper from the feeder and flip the printer upside down and shake it a little. Sometimes things will fell inside of the paper feeder and will block the paper path thus causing the printer not to be able to pull the paper.
Jan 15, 2010 | Lexmark X5470 All-In-One InkJet Printer
I have a lexmark x5470 printer, which does not pick up the paper corectly. The paper is pulled into the printer from one side only, i get an error message telling me the printer is out of paper.
Sounds like you may have something stuck inside, unhook it and turn it upside down and shake it, I bet something will fall out and then it should work.
Jun 20, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper stuck while printing on lexmark X5470
You might have a little paper stuck inside your printer or just clean the pick-up roller with alcool and try it again.
Mar 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
171 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
