Heating icon on remote will not come up - Heating & Cooling
The lcd has a pcb problem you will have to get a uni remote to operate
Posted on Jul 18, 2008
How to unlock gree ac remote
To lock and unlock Gree remote control press '+' & '-' simultaniously.
Jun 26, 2012 | Heating & Cooling
I installed a 2 ton Mr.Slim today. On the remote I could not find the sun icon for heat. I seen all the rest icons. So I couldn't try it on heat. It did work on a/c. And every thing else seemed to work OK....
No by mistake, cool only remote has been packed with you set.Or remote icon problem. Please contact your supplier to replace heat and cool remote. Thanks.
Jan 28, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
Ram Problem
RESOLUTION To clear the RILOE NVRAM and eliminate the error message, reset the RILOE using one of the following methods:
On servers running Microsoft Windows :
  • Reset RILOE through the Management Agents icon in the Control Panel:
    1. Click Start, Settings, Control Panel, Administrative Tools.
    2. Click on Services.
    3. Stop the HP Insight Server Agents.
    4. Click on Start, Settings, Control Panel.
    5. Click on the HP Management Agents icon.
    6. Click on the Remote Insight tab.
    7. Click on "Reset Remote Insight Board" (reset option will be grayed out if the Server Agents are still running).
Or
  • Reset RILOE using the Remote Insight Setup Utility in the Control Panel (pink icon).
On servers running other operating systems and as an alternative method for servers running Microsoft Windows :
  • Reset RILOE by powering off the server and unplugging the external power connection to the RILOE board and the external power connection to the server.
A permanent resolution is not planned as the Remote Insight Lights-Out Edition (RILOE) is end-of-life and out of production.
Jan 22, 2010 | HP Compaq ProLiant DL380 G2 Server
What is the button to heat up my room?
Open the cover on the remote, to the top left (usually) there is a single button which if pressed repeatedly, changes the mode settings. This can also be seen by changing icons on the display. The first is an ice crystal, second tear drop, third a triangle with a moon, fourth is a sun. Press until you have the sun icon in the display area. Then close the remote and using the up arrow and down arrow buttons select the temperature which is comfortable for you.
Nov 17, 2009 | LG LS-L1210CL Mini Split Air Conditioner
What do the mode icons on remote control for Mitsubishi Air Con mean? Thank you.
change from what operation you want the a/c to do like fan only or cool only or heat only(if it has heating) or auto if you want auto change between heat and cool
Aug 01, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Akai airconditioner AC-KS24HRC Changed batterirs in remote can not get heat mode icon on remote therefore no heating.Still under warranty but can not find Akai repairer Newcastle N.S.W. Australia...
I had the same problem. Check the remote control section of the manual. When you change batteries the screen flashes the hot and cold icons alternating. press a utton when the hot one is on and it will activate the heat+cool mode.
Jul 15, 2009 | Heating & Cooling
Mitsubishi PAR-F27MEA AC controller icon meanings
hi.welcome to the mitsubishi worl of airconditioning.thay are great units to have.ok let me explane this for you.
the sun is for heat mode
the snow flake is for cooling mode
rain droplet is for dehumifiy the air if its a humid day.i hope this helps you.you have to choose the modes on the remote for the unit.then the unit will do the mode you choose on the day.
Jun 09, 2009 | Heating & Cooling
Problem understanding Icons on Remote control
The snow flake icon is for your cooling, the sun icon is for heating, please rate this as it will help us if this was helpful to you, thanks,
mr.grzz
Jan 23, 2009 | Continental CE-AC75271 Ductless Mini Split...
What does the sun Icon mean?
The sun likely means it is heating, snowflake would mean cooling.
May 28, 2017 | Heating & Cooling
Centrex air conditioner
Here are some icon that may help you.
COOL- this icon cool your room.
Dry- this icon control the humidity in your room but limit the coolness in your room (24deg C).
Fan- this icon run for fan only.
Heat- this icon heat your room.
Mar 11, 2008 | Heating & Cooling
Heating & Cooling Logo
143 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
