Question about Packard Bell Computers & Internet
How do you open up UC1 µATX case off an IXTREME 6004 to replace a duff dvd drive do you need to take the PSU out. Have the side off but cant see how the drive comes out
Found away of removing Front cover.. so was able to remove Dvd drive to upgrade to Lightscribe & faster unit
Posted on Jul 17, 2008
Not getting any video from a msi 880gma-e55 integrated video motherboard
This may sound simple, but make sure the monitor is set to correct input. Many are auto detect, but you never really know.
You could also check BIOS for onboard video. Disable if you have an add-on video card. Enable if you don't
Reseat the video card if it an add-on.
Jan 08, 2013 | MSI Computers & Internet
Won't power on
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be
faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical extension or fan lead can cause you problems
computers need power and data travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all power and data leads make sure they have secure dust free connections
cd/dvd floppy drives need to have current go through make sure these drives are working
check you CPU make sure its securely seated and has thermal grease
hope this helps
Jul 09, 2012 | RaidMax Tornado ATX238WRP Black SECC Steel...
What name is given to a power supply whose case has the following features: ATX Mid Tower, ATX, Micro ATX compatible form factor, 2 Extenal 5.25
If you need a PSU you need to do a google search to find the exact match.Micro ATX,ATX, and ATX Mid as the name are the size of the PC case.
Apr 18, 2012 | Computers & Internet
I bought a cool master case and put everything together right but when i push start i get fan whirl off the psu and nothng more. how do i solve this?
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
don
Feb 25, 2011 | Cooler Master Centurion 5 ATX Mid-Tower...
Computer is not booting up. Usual blue light over power switch is red.
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help
don
Feb 15, 2011 | Thermaltake Wing RS 101 Case + 430W PSU:...
Power supply unit gets power as light on the back shows but pc wont turn on. Have tried differnt PSU and pc turned on but have had unit checked and they said the PSU is working fine. Cant fit standard PSU...
Try this to get it at-least back on with your PSU that fits in the case. open up your computer case, locate your power supply. With the AC cord still plugged in , unplugged the connectors to your motherboard from the PSU and wait about 10secs. Then replugged them in. This should power on your PC.
Also, You wanna check around where the PSU connects to the motherboard and make sure there is no damage. No burning,Discoloration anything that could be potential damage.
Hope this works atleast to get the PC booting up.
Jul 28, 2010 | Bestec ATX-1956F (ATX1956F) 200-Watt Power...
Bad DVD/CD Drive
ok to be clear you want to change the dvd cd rom drive corrct? here how to first thing first take of both sides of the computer (im telling how to for 99'9% of comuters not specifcly yours) there will be 2 screws on each side of the drive take these out now 2 ways to remove from here it will 1 slide out the front or 2 it will be stuck from the from becouse the farsade is holding it in (remember to take both cables out the back of the dvd rom drive) if its 2 then then there will be 2 ways to go from here if there is a lot of space at the back then take it out there if the box with wires is in the way there are 4 screws holing it on take these out and move but dont take all the wires out of everywhere the box of wires (psu) then take out old dvd rom drive and replace it put the psu back in and screw it in then screw in the dvd rom and wire it back up your done turn on the computer it will go to windows and install new device if howver there is not a lot of room and removing the psu wont help then you need to remove the farsade at the from (front cover) ther eis normaly 6 clips at the side push these to remove the farsade and pull ou the dvd rom and replace it that way hope this helps i can provide further info if needed just ask
Mar 17, 2010 | Gateway DX482201 (PTGA002002) PC Desktop
ATX-300GU PSU: 32V around Q4/Q5 circuit
could just be the regulating power transistors are burned out or one of their biosing components, there a few meaty capacitors that may be causing a surge, but the safe thing to do would be to start with a new one, the reason is, modern drives are so sensitive that you could blow their circuitry and then lose the harddisk! All the best - the Yeti
May 17, 2009 | AOpen Power Supply: ATX-300GU (PS4300GU)...
Need physical dimensions of HEC HP585D 585W ORION HP585D ATX
No, given your old PSU's dimensions the HEC PSU would be too large. It sounds like you have a micro-ATX case.
Apr 06, 2009 | HP HEC HP585D 585W ORION HP585D ATX 12V...
No power
reg desktop computer ? 4 screw on back unplug it out buy new one atx style for latest computer sum use mini small power to fit in smaller cases micro atx let me know more info
Jan 06, 2008 | Gateway Media Center 610XL PC Desktop
Computers & Internet Logo
192 people viewed this question
Top Packard Bell Computers & Internet Experts
Alun Cox
carey w mason
carey w mason
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
