Question about LG WFT1071TP Top Load Washer
LG Top Load Washer
My washing machine is leaking at the front bottom. What could be the problem.
Where can l buy top load washing machine filters.I currently reside in pretoria.
  • Anonymous Mar 16, 2014
    hw programme lg top load washing machine
  • 38 Answers
This could be a drain hose loose or broken if the leak only occurs during rinse. If it leaks all the time, could be a broken outer drum or worn tub seal.
Hold inner drum and turn bothways. If it turns bothways, you have a bad bearing, and hence, a bad tub seal. If it turns in one direction only, bearing's good; but tub seal could still be bad.
Posted on Jul 23, 2008
Washing machine top load leaking water bottom model # LXR7244JQ1
The pump is near the front, bottom of the machine. You need to unplug and unhook it from the water supply. Then get a wet and dry vacuum and remove all the water from the machine by using the vacuum on the drain hose. Then you can lay the machine down to get to the bottom of it and you can replace the pump. http://www.partselect.com/ModelSections.aspx?ModelID=709279&ModelNum=LXR7244JQ1&mfgModelNum=&ManufactureID=3&Selected=TVCOCCCE&Position=6&mfg=Whirlpool&Type=Washer&Mark=4
Jul 10, 2014 | LG WM-2277HW Front Load Washer
I have LG wm-2277HW Front Load Washer, when I pour bleach into the bleach dispenser I see it disappearing as fast as I pour it in,and I see it coming out the front bottom the washer (the same side) where...
Remove the screws on the back of the top and lift the top off. Pour water into the bleach dispenser and watch to see where the leak is coming from. Post back your findings.
Dec 07, 2012 | LG WM-2277HW Front Load Washer
Door latch wont unlock LG WM2455 Front Load Washer
You can also gain access from the back by removing the back panel...The top on this washer can also be removed..Remove the dispenser cover...Take a putty knife..Insert it in between the top cover and the cabinet ..Push in the tabs located 4 inches in from the sides.
Oct 20, 2012 | LG WM2455 Front Load Washer
Leaking under machine
If it's leaking you need a new door seal. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5520777
Taking it off is kind of hard. You have to take the top off, the door lock off, and the front off, and the screws out of the bottom on the drain filter. Make sure it's not leaking from the bottom by putting water in the tub. Check to see if the gasket is torn on the inside by removing the spring ring with a flat head. Find your way to get it back on after replacing this part. The rings are tricky.
Jan 19, 2012 | LG WM-2277HW Front Load Washer
I have an LG washer front load WM2032HW. It won't
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 26, 2011 | LG WM2042 Front Load Washer
LG WD-12124RD How do I remove the front panels?
Hiya,
most machines now open from the back you will find 2 or 3 screws/bolts at the top holding on the top section if you un screw those then slide the top back slightly it should unclip allowing you to take off the top this should expose some more screws or bolts that will be holding on the front & sides, if your machine is leaking from the front you could have a leaky door seal too so you may want to check that before starting to take it apart.
Hope this helps
Apr 23, 2010 | LG WD-12124RD Front Load Washer
Water draining out of the bottom of washer
CHECK YOUR WATER INLET VALVES FOR LEAKS BY REMOVING THE TOP OF YOUR FRONT LOAD WASHER. IF LEAKING REPLACETHE PART.
Dec 09, 2009 | LG WM-2277HW Front Load Washer
LG WFT1071TP Top Load Washer Logo
298 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
