Question about Cameras
Sea water and sand in camara - Cameras
    Sniper:
  • 53 Answers
And you want to get them out ? use a vacuum cleaner. But your camera is most likely damaged.
Posted on Jul 17, 2008
My daughter says there is a toy that is a ball that bounces on the water. Is she right?
Yes she is - the Waboba surf is a great toy. It's brilliant fun in the pool and in the sea with all the family as it's a ball that actually bounces on the water.
Check out this info about it;
http://www.amazon.com/Waboba-Surf-The-Ball-Bounces-Water/dp/B004RGU0SK/ref=pd_sim_sg_6
Feb 28, 2013 | Toys
Can I use sea sand as a substrate in my aquarium?
You should not use sea sand. Sean sand is often contaminated and will pollute the water in your tank. The small shells and tiny pieces of coral mixed into the sand will inevitably raise the pH level of your aquarium.
Aug 28, 2012 | Aquaculture Fish
We removed all the wood trimming/doors inside our Catalina 30 sailboat. We want to do a clean/revive type job on it. The wood is teak. How do we proceed?
if the teak is bare teak --- a light sanding with a sanding block should be good and then follow that with a good rub down of teak oil ( sea-fin teak oil is a good brand ).
if the teak is finished teak --- and you want to remove the old finish and sand out any stains(?) then you will need to use a more aggressive sand paper and finish off with a lighter sand paper,, clean up with acetone, use a good tack cloth and start applying varnish -- the best varnish that I have ever used is a brand called ' Epiphanes ' and you will either want to use a ' matte ' finish or a ' gloss /semi-gloss ' finish. personally I have found the 'matte ' finish to look better and it brings out the true beauty of the teak itself. ( make sure you follow the sanding instructions between coats as this will give you a nice smooth and sharp look ).
enjoy the water ---
c...
Jan 04, 2011 | Boating
Whirlpool dishwasher 1 year old model adg 7560/1 - green start light flashing and beeping - will only do rince cycle
I have exact same problem with mine. Had Engineer out to tell me it requires new motor. The total cost would be €260. He blamed sand in water as we live near sea. By the way mine survived for 2 1/2 yrs with fairly gentle use
Dec 19, 2010 | Dishwashers
I let my camara fall in the sea their was no
Sorry but saltwater is the worst thing after fire or total crushing that any electronic device can be exposed to. Salt causes physical and chemical damage which is near impossible to reverse. You might not have seen any water inside the camera, but it only takes a tiny amount to destroy a digital camera.
Your camera may look ok, but it's a write-off. It's impossible to remove all residual salt which will continue to corrode circuitry inside the camera. Any tiny pockets of trapped saltwater are eletcrically conductive and will cause electronic faults, any condensation which occasionally gets into all cameras just dissolves trapped salt to effectively become seawater.
The only hope would have been to immediately remove the battery and memory cards and then to immerse the camera in de-ionised water, but even then the camera would likely have been ruined. Leaving it to dry out for two days has simply ensured that remaining salt deposits are now buried deeply within the components and absorbent materials used in the camera.
Sorry to disappoint you, but your only hope is that the camera was insured against accidental damage. Even then, the insurer may refuse to pay by arguing that your camera was put at unnecessary risk by not being in a waterproof housing.
I hope that my reply has still been of use to you; please don't forget to rate my answer.
Jun 22, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
My husband took our camera to Iraq and got sand lodged into it. Now it won't work. What do I do? I have "NO" fix-it abilities
Hi there if you camara attacked by only sand then i suggest you remove the camera cover & use a brush for cleaning the sand from camara power supply point, curcit board, battery places & power on/ off swutch places. I hope your problem will solve after these process. Thanks.
Apr 02, 2010 | Kodak EasyShare Z730 Digital Camera
Mi camara v1253 kodak prende y rapido se apaga.
La camara de KODAK tiene ese problema mucho no compres Kodak compra Nikon i tira la Kodak porque ese problema no se pude arreglar cuest mas el arreglo que la camara.
Sep 21, 2009 | Kodak EASYSHARE V1253 Digital Camera
Cameras Logo
205 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
