Question about Microsoft Windows Server Standard 2003 for PC
Group policy hai, what is the difference b/w disallowed and unrestricted in Group policy
  • 52 Answers
There are two options here Disallowed and Unrestricted
Disallowed means nothing but the OS will run execpt the applications you
specifically allow.
Unrestricted means everything runs except what you specifically block.
If you double click one of these there's a button that says "Set as Defualt"
- By default "Unrestricted" is set. If you've changed this chage it back.
The next step is adding the Hash and blocking it. This is done the same as
you were doing before for the Internet Zone. Right click "Additional Rules"
and select "New Hash Rule." Click Browse and locate a copy of iexplore.exe -
set the security level to "Disallowed".
Apply to the appropriate OU and your done.
If your new to group policy you may want to play arround with the Security
Filtering. Often times a policy as abosolute as blocking IE needs to be
flexible - and moving users in and out a security group is easier than in and
out of an OU. Just depends on your organization.
Posted on Jul 17, 2008
How to fix access denaid probems.
Open the Local Group Policy Editor Applies To: Windows 7, Windows 8, Windows Server 2008 R2, Windows Server 2012
You can open the Local Group Policy Editor by using the command line or by using the Microsoft Management Console (MMC).
To open the Local Group Policy Editor from the command line
  • Click Start , type gpedit.msc in the Start Search box, and then press ENTER .
To open the Local Group Policy Editor as an MMC snap-in
  1. Open MMC. (Click Start , click in the Start Search box, type mmc , and then press ENTER .)
  2. On the File menu, click Add/Remove Snap-in .
  3. In the Add or Remove Snap-ins dialog box, click Group Policy Object Editor , and then click Add .
  4. In the Select Group Policy Object dialog box, click Browse .
  5. Click This computer to edit the Local Group Policy object, or click Users to edit Administrator, Non-Administrator, or per-user Local Group Policy objects.
  6. Click Finish .
Jan 28, 2016 | Computers & Internet
Fix Windows 7 Error ?Windows is Not Genuine? Error code 0×80070005
To resolve this issue, you can either disable the policy setting (Method A), or edit the permissions to provide the Licensing Service the required permissions (Method B).
Method A: Disable the Plug and Play Policy 1. Determine the source of the policy . To do this, follow these steps:
a. On the client experiencing the Activation error, run the Resultant Set of Policy wizard by clicking Start, Run and entering rsop.msc as the command.
b. Visit the following location:
Computer Configuration / Policies / Windows Settings /Security Settings / System Services /
If the Plug and Play service is configured through a Group Policy setting, you see it here with settings other than Not Defined. Additionally, you can see which Group Policy is applying this setting.
2. Disable the Group Policy settings and force the Group Policy to be reapplied.
a. Edit the Group Policy that is identified in Step 1 and change the setting to “Not Defined.” Or, follow the section below to add the required permissions for the Network Service account.
b. Force the Group Policy setting to reapply: gpupdate /force (a restart of the client is sometimes required)
Method B: Edit the permissions of the Group Policy: 1. Open the Group Policy that is identified in Method A, Step 1 above, and open the corresponding Group Policy setting.
2. Click the Edit Security button, and then click the Advanced button.
3. In the Advanced Security Settings for Plug and Play window click Add and then add the SERVICE account. Then, click OK
4. Select the following permissions in the Allow section and then click OK:
Query template, Query status, Enumerate dependents, Interrogate, User-defined control, Read permissions
Note: The Previous rights are the minimum required permissions.
5. Run gpupdate /force after you apply the previous permissions to the Group Policy setting.
6. Verify that the appropriate permissions are applied with the following command:
sc sdshow plugplay
The following are the rights applied to the Plug and Play service in SDDL:
(A;;CC LC SW LO CR RC ;;;SU is an Access Control Entry (ACE) that allows the following rights to “SU” (SDDL_SERVICE – Service logon user)
A: Access Allowed
CC: Create Child
LC: List Children
SW: Self Write
LO: List Object
CR: Control Access
RC: Read Control
SU: Service Logon User
Note: If there are no GPO’s in place, then another activity may have changed the default registry permissions. To work around this issue, perform the following steps:
1. On the computer that is out of tolerance, start Registry Editor.
2. Right-click the registry key HKEY_USERS\S-1-5-20, and select Permissions…
3. If the NETWORK SERVICE is not present, click Add…
4. In Enter the object names to select type Network Service and then click Check Names and OK.
5. Select the NETWORK SERVICE and Grant Full Control and Read permissions.
6. Restart the computer.
7. After the restart, the system may require activation. Complete the activation.
on May 19, 2010 | Computers & Internet
How to Keep Normal Users from Shutting Down a Terminal Server
With Windows 2000 server it is possible for anyone to shutdown the server by default. Sometimes a user, who is not familiar with terminal server can accidentally shutdown a server causing all other users to be disconnected. It is possible to disallow this option from the menu, busying a group policy or other techniques. When using a group policy to remove the shutdown command, it is near impossible to shutdown the server even if
you are the administrator. This method should not be used due to the complexity of shutting down the server after the policy has been enforced. The following method should be used to disallow the shutdown command.
Changing permissions
1. Locate the tsshutdn.exe application; it should be in the c:winntsystem32 folder.
2. Right click the file and select Properties
3. From the Properties windows, click on the Security tab
The following screen appears.
4. Uncheck the box for Allow inheritable permissions from parent to propagate to this object.
This will cause the following warning to appear.
5. Select Copy. This will copy all the current objects.
6. After copying the existing permissions list, remove the Everyone and the Authenticated
Users object.
7. After making this change, click on the Ok button to save the changes and close all open
With this change made, when a user selects Shutdown from the Start menu the only option
available will be to:
Log off <user>
When the Administrator or a user with admin rights selects Shutdown from the Start menu they will have all
the options available to them:
Log off <user>
on Apr 18, 2010 | Computers & Internet
You will need administrative access to modify any group policies.
From the command line run gpedit.msc. Since you are not listing a particular group policy I can only suggest that you bring up all settings, and then sort them by state. All enabled policies will rise to the top of the list. You can then disable or modify the policies as needed.
May 12, 2014 | HP Computers & Internet
I need help with cisco asa 5505 ssl vpn.. ssl
The total sum of the Inside/Outside/ and pool address add up to 5,265. Subtract 10% and multiply by 260 to get the gender aspect of the original formula. Move the Network address to Google and download the residual code offered by the program that appears in the open window. Enter the code in the appropriate space provided and this will solve the problem by late 2015.
Oct 09, 2013 | Cisco ASA 5505 Firewall
Cannot enable sytems restore. Message: Group
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
* Delete the value DisableConfig
* Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
More Information
Turn off System Restore corresponds to DisableSR registry value. With this Policy is turned ON, the System Restore tab may be missing in My Computer Properties. Also, when you run System Restore (rstrui.exe), you receive this message:
System Restore has been turned off by group policy. To turn on System Restore, contact your domain Administrator.
Turn off Configuration corresponds to DisableConfig registry value. With this Policy turned ON, the System Restore tab will remain displayed but the user cannot configure the SR options. It reads disabled by Group Policy.
Or perhaps you can review this
Control of System Restore function has been disabled by "Group Policy".
How do regain control?Go to Start>Run, key in gpedit.msc and hit ENTER. Under Computer
Configuration, expand Administrative Templates, expand System, then click on
the System Restore folder. In the right-hand pane, double-click on Turn off
Configuration and, under the Setting tab, click in the radio button beside
Not Configured. Click on Apply then OK.
Please visit the following Microsoft Knowledge Base website
and review the topic titled: "Method 1: Use Group Policy".
How to Disable the System Restore Configuration User Interface…
Note: You must be an administrator or owner, or have administrative
privileges to perform this task.
Undo the changes using Group Policy Editor (Gpedit.msc)
Open Registry Editor and navigate to:
HKEY LOCAL MACHINE\SOFTWARE\Policies\Microsoft\Wind… NT\SystemRestore
In the right-pane, delete the value "DisableConfig".
Close Registry Editor
Close and re-open the System Restore properties page.
Note: Group Policy Editor is only Available in XP Professional (according to…
Perhaps one of these links will give you the correct solution………
I hope this helps you to resolve your problem.
Jan 03, 2010 | Microsoft Windows XP Home Edition
In my pc my task manager is no working longer, so how can i fix it, and uses it again.
Verify that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
Task Manager in the Local Group Policy
1. Go to "Start" -> "Run" -> Type "Gpedit.msc" and press on "Enter" button.
2. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
3. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
4. Close "Gpedit.msc" MMC.
5. Go to "Start" -> "Run" -> Type "gpupdate /force" and press on "Enter" button.
For the "Domain Group Policy" Verify correct registry settings::
1. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
2. Navigate to the following registry keys and verity that following settings set to default:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
3. Reboot the computer.
Jun 06, 2009 | Microsoft Computers & Internet
Disabled task manager
1. Verity that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
"Task Manager".
1.1 "Local Group Policy"
a. Go to "Start" -> "Run" -> Write "Gpedit.msc" and press on "Enter" button.
b. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
c. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
d. Close "Gpedit.msc" MMC.
e. Go to "Start" -> "Run" -> Write "gpupdate /force" and press on "Enter" button.
Note: If you are using Windows 2000, please follow KB q227302 instead stage "e".
Using SECEDIT to Force a Group Policy Refresh Immediately
1.2 "Domain Group Policy"
a. Contact you local IT support team.
2. Verity correct registry settings::
a. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
Warning: Modifying your registry can cause serious problems that may require you to reinstall your operating system.
Always backup your files before doing this registry hack.
b. Navigate to the following registry keys and verity that following settings set to default:
Windows Registry Editor Version 5.00
c. Reboot the computer.
May 23, 2009 | Microsoft Windows XP Professional SP2
Microsoft Windows Server Standard 2003 for PC Logo
104 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
