Question about HP VP6310 Multimedia Projector
Power Issues I have a HP all in one projector/DVD EP9012, and I'm having problems with the power. The kettle lead has to be jiggled in the socket on the back of the projector. This takes a while, but eventually you hear a small pop and the lights come on on the top of the unit. Once the power is on the kettle lead can be fully inserted into the back of the unit. I t6hought this may be a connector issue. I've tried different kettle leads and they all do the same. the actual socket in the projector seams ok. as mentioned once powered up it doesn't have any issues. its just the initial power up, is like starting a tempremental car. Any Ideas?
Have a tech check the unit. This could be the High voltage unit.Once this board is replace, the unit should work
Good luck
Posted on Jul 18, 2008
I have Projector HP EP9012. When i turn on my projector it turns off in 5s and the red light for temperature starts blinking. Its not the lamp as the lamp indicator is green and i also replaced it with a...
check to see if there is a filter for the lamp, there may also be a sail switch that detects air flow and this might not be working.
best regards Falco
Nov 04, 2013 | Office Equipment & Supplies
No signal found on Sharp LCD projector
test all power and data leads that attach to your hard drive the leads from your
(motherboard to your hard drive) Sata make sure they have dust free secure connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as a faulty fan lead can cause you problems a computer needs all of the power and data to travel through every working device and to
have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove the graphics card to clean the socket replace it
restart the computer the found new hardware wizard should activate
hope this helps
Jul 15, 2012 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Replacement power cord for my h/p lasejet printer
If you just need a replacement power cord then you should be able to use any similar 'kettle' plug computer power lead from a system unit, monitor etc.If you actually need a replacement power supply including the power transformer block which converts the mains voltage to the DC voltages required by the printer, then you will need to look at on-line companies who provide such parts.See http://www.aliexpress.com/store/100504/202932004-359117582/Original-AC-Power-Adapter-Charger-for-HP-Deskjet-F380-All-in-One-printer-00086.html for one such company which also shows the power lead socket.
Dec 20, 2011 | Office Equipment & Supplies
I just moved my Acer 19" monitor and everything went off. I checked all the connections but it is not turning on. any suggestions?
Check the VGA lead, it is possible that when moving the monitor, you damaged one of the pins that connects in the socket on the monitor, remove the lead and also inspect the socket if there is a broken pin inside it remove this and try a new vga lead.
If no pins are broken and / or the power is not even reaching the monitor, check the kettle lead, look for signs of damage to the rubber / plastic plug and the socket on the monitor (assume this one is fed directly from the mains?), If you have been unfortunate enough to have damaged one of the pins that is in the socket you will need a TV repairman to fix this.
Check also the condition of the lead itself, for breaks and whether the fuse in the plug has blown.
After that, your problem will need to be looked at by a qualified TV repairman, as the fault must lie on the board itself
Jul 26, 2011 | Acer Computers & Internet
My electrical water kettle does not heat water...how to solve the problem?
Check the kettle at another socket to ensure the socket isn't the problem.
Replace the fuse in the plug.
If the power flex is removable from the kettle, check the terminals in the connector havn't become burned.
The chances are that the element may have burned out in the kettle and in this case it probably isn't worth repairing.
Mar 11, 2011 | Sunbeam Microwave Ovens
I have lost my power lead that goes into my DVD.Where may I puchase one please
Hi
Assuming it is a standard lead, either a kettle lead type or a figure of 8 type lead (more than likely this) you can purchase one of these from any of the major supermarkets or any electrical retailer
regards
TechSupp12
Dec 12, 2010 | Bush DVD2038 DVD Player
Our HP 21 Digital projector has a green tint when we turn it on. We have a new computer and the monitor displays correctly. The HP21 is a 2004 model.
Hi it sounds like you have a ne missing on the VGA feed to your projector, try using a composite lead to see if it is the same it should be ok also you can try using the menu see if the white is white when menu is pressed if it is then it is the lead, it possible could be the VGA socket but i have never seen a faulty socket so unlikely.
Marc Engineer
Jun 14, 2009 | HP Digital Projector sb21 Multimedia...
Optoma DV10 Issues
change the lead that came with the system to another one, i am not sure if it was the new cable or the step down in the amp that I used, but it did the trick
Dec 10, 2008 | Optoma MovieTime DV10 Multimedia Projector
Looking for power supply cord for emachines model no E15T3g 12v--2.5A
if this is a 3 pron socket the it is a standard cable
kettle lead / european power cable
May 20, 2008 | Computers & Internet
Not powering up: Sony VPL sc24
TRY TO CHANGE THE CONVERGANCE IC
Oct 31, 2007 | Televison & Video
HP VP6310 Multimedia Projector Logo
59 people viewed this question
Ben Johnson
