Question about Dishwashers
Smeg DI612CA integrated door springs open, catch won't hold when trying to close door. Have removed before and reset catch. Same problem now seen again. Likely that I need new catch unit, or could problem be electronic?
  • 277 Answers
SOURCE: Broken Door Spring
hi you can do it if you have good hands open the cover side of the broken arm with the spirngs understand how the Mechanism works (in\out) and what went worng and hopefuly fix it or replace the springs that died good luck
Posted on Mar 26, 2006
MicrowaveSvc
  • 9086 Answers
SOURCE: Replacing the door catch
If you're talking about a hook-like device that sticks out of the door and goes into a hole in the chassis of the microwave (or any other internal part of the door for that matter) you'll have to take the door apart. Brands and models vary, but some use screws which are obvious, and others use hidden hooks similar to the ones in the drawing I've added to this post. If you can post or e-mail photos of the area where the part goes, we may be able to translate our experience with other brands to yours.
Posted on Jan 30, 2007
  • 121 Answers
SOURCE: Brand New Machine, can't open the door
Threre should be instructions on what you need to remove, but where is this black plastic located, and wher eis the screw positioned?
Posted on Nov 07, 2007
IFIXALL
  • 868 Answers
SOURCE: SMEG SA420X
Not too common at all.Tough call ,you really can't hold the tenant at fault,replace the over priced clock and inform the tenant that the next one THEY will have to pay for.
Posted on Jun 02, 2008
huuum
  • 750 Answers
SOURCE: Smeg Dishwasher DI612C
Hello Friend,
Welcome to fixya.
I'm Huuum and happy to assist you,
Try this remedy.
When we have an error code this is the remedy.
This can reset the system.
First turn it off.
Cut power to the washer at the breaker and wait a 5 minutes then restart it.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Write back right away and let me know that it worked and solved the problem .
Bless You
Please remember to enter a rating here when you finish!
How old is the appliance?
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old refrigerator
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your refrigerator,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old (three years for top-freezers),
paying for a repair makes sense.
Note that refrigerators under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your refrigerator is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new refrigerator.
Data also shows that it doesn't pay to fix a less-expensive top-freezer refrigerator
six or more years old or a bottom-freezer or side-by-side eight or more years old.
Thanks to better recycling programs, less than 10 percent
of a refrigerator you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Bless You
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Posted on Sep 23, 2008
Bosch integrated microwave doesnt start/close
Door latch settings are out because door slamming and abuse of unit
Dec 02, 2013 | Bosch Microwave Ovens
How do I change the outside door latch on a smeg integrated washer/dryer
Go to www.repairclinic.com and enter WDI12. With luck, you will be presented with a list of common repair parts and may be able to view a generic Smeg video showing disassembly
Jun 20, 2017 | Smeg WDI12 Front Load Washer / Dryer
I am try ing to refit the oven door on a SMEG DUC08CSS but the spring catch will not stay in the lock in position to allow me to reinstall. How do I do this once the door has been removed?
I put the handle of a small screwdriver in both side to hold it open until I get it started then remove them so you can put the door down the rest of the way.Hope this makes sense.
Jun 23, 2011 | Ovens
Broken catch
what has happened is that the ridiculously flimsy plastic that the catch spring pushes against has snapped off. I tried getting it plastic welded but still too weak finaly I took off the door unscrewed the transparent central part(remembering to keep the little black plastic rod at the top that operates the microswich when the door closes then snapped off a piece of hacksaw blade about15 mm long and put it where the plastic had been. I carefully lifted the end of the spring over the blade and while holding it screwed back the transparent part so that it held the blade in place. Works really well!
Jan 14, 2010 | Smeg WDI12 Front Load Washer / Dryer
Cant get oven door back on
Oven doors are made to lift off for routine maintenance but there might be problems if the spring load hinges are not disabled before pulling the door off the body.
There should be a catch which holds the hinge in the open position but if it is the release position (i.e. the state in which it is in for normal use), the I would expect the hinges to snap into the closed position when the door is removed from the body.
To rectify this, hold each spring loaded arm in the position it would be in the "door open" position and move the catch into the position which prevents the arm springing back when they are released.
It should now be possible to fit the door to the cooker.
When the door is fitted, release the catches.
Dec 17, 2009 | Whirlpool RF3020 Electric Kitchen Range
I am a quailified Gas Safe regirtered engineer who has a problem with a Smeg Range A1.1 oven door hinge reciever. We have been in touch with Smeg direct and asked for the required information as to the...
HI ,I have just managed to remove hinges from a smeg a1.1 range. to get hinge out you have tohook up a small holding catch on the bottom bar and thenforce open the hinge, the topbar thencatches on the small catch which then holds the complete hinge open .The whole assembly can then be pulled out. The holding catch is only about 1" long but is easily flicked up with a screw driver Paul 07776 438 408
Oct 26, 2009 | Smeg A1A.1 Gas Kitchen Range
I have a hotpoint few12 washing machine and have just replaced the interlock door lock as door locked indicator kept flashing even though door was closed,sometimes happened mid cycle,and had to open...
hi
check the spring on the door handle/catch,the easiest way to check this if you close the door and it indicates that the door hasnt locked,push the inner part of the handle towards the machine,if it locks then the spring is worn.(this is more commen than the interlock).
Aug 03, 2009 | Washing Machines
Put back smeg oven door
Yeah I was stumped with this for a short time as it isnt imediately obvious.
The bottom of the two brackets has a flip up catch, place these in the upright position and with some force hook the upper bracket into these catches (please ensure you keep your face and hands away from the direction of the spring)
Once you have the two brackets held open offer up the door at exactly 45 degrees (notice the notch on the underside of both lower brackets) locate this notch on the door hinge hole studs.
Once this is done and your certain it is in the correct postion lower the door from 45 degrees to 90 degrees, put some pressure on the door slightly past 90 degrees and carefully fold down the flip up catches that are holding the upper brackets.
Jan 28, 2008 | Smeg SE250XUK Stainless Steel Electric...
Apr 21, 2007 | Smeg DWI614 Built-in Dishwasher
Dishwashers Logo
137 people viewed this question
Top Dishwashers Experts
