Audiosonic 34 cm colour tv/dvd - 2 years old and everything has gone green - watchable but annoying. is this the end of the unit so soon ?? thanks
Model no 1420
Posted on Jul 04, 2012
  • 4 Answers
Your color wheel has most likely gone bad....
Posted on Jul 18, 2008
Audiosonic km1412d no colour in tv / dvd just black&white
Check in menu for video options, Select pal, NTSC or whatever your country is transmitting. If auto option is available best to set it there. Check also sound options like I, BG, or DK and set again to your transmission,If you have a settop box make sure on other tv it is displaying coulour. saom also have sound and video options. Try to connect dvd with av cables and see if coulour is there. if still B&w get repair technician
Aug 11, 2009 | Televison & Video
Screen keeps turning green
My Panasonic Plasma television started doing a green screen also. When it does it to me, is when I use the Last button or the Fav button. This is with Charter Communication. If I go back and forth, to various stations, then one station will turn green. So by trial and error, I found that when I clicked on a station, the screen would turn green. I had to push the Guide button, then the guide would come up, then push the Exit button, to get rid of the Guide, and then it would be on the station you wanted. If that does not work, then I have to just turn the TV off and turn it back on. It is rather annoying, however, as long as I can get rid of it, I can deal with it, instead of always turning the TV off. I don't know if this happens with all TV's or just Plasmas. If it does, I will not get another Plasma, if it happens with all TV's, maybe it is the remote, or the cable company. I just don't know.
May 16, 2009 | Panasonic TH-50PH9UK 50 in. Plasma...
Screen gone yellow and green
I have a 21'' NEC TV Screen and it about 3 year old. the colour has gone to yellow and green color and the red etc
May 10, 2009 | Samsung PPM42S3 42 in. Plasma Television
Bush lcd 24 inch tv
REPLAXCE THE DEGAUSING P.T.C
Oct 24, 2008 | Bush 5693D 24" TV
Audiosonic DVD player no sound
Try using a diferent rf cables.I would suggest that red,white and yellow colour coded RF cable is still the best.(yellow for Pictuer,White for sound and red also for sound(surround).
had similar problem than i cahnge the cables and found out that it worked with that cable...
thanx,
FIJI
Jun 21, 2008 | Televison & Video
Audiosonic Tv
Try hitting the RETURN button - that is the one with two arrows chasing each other just above the DISP button. This turned off the FACTORY text on my Audiosonic KMC TH68.
Apr 01, 2008 | Car Audio & Video
Color problem with TV
Are you getting Green or purple or pink patches all over the screen?
This could be a problem of Degaussing. Have you placed any Magnetic source near the TV recently? Some Tape recorder or walkie talkie or a Speaker, etc? The Magnetic field created by any of the above sources can cause coloured patches over a colour TV screen.
It also happens if you shift the TV from one location to another.
The third possibility is that the Picture Tube's Red Output stage gone faulty. Unless you are a trained Solid state Electronics Technician, there is nothing you can do. Better go for a trade in.
Feb 22, 2008 | Panasonic CT-27G21 27" TV
Colour problems
check for open resistor R302 on the CRT board. 150 ohm 1/8 watt SMT resistor, located at the base of Q305
Feb 11, 2008 | Televison & Video
Recording DVB on this DVD recorder?
Have sorted this problem now, I purchased a SCART DVB TV Unit from Freecom, this did not work at first connection, but I then realised that it had to work as RGB into the SCART plug on the DVD, once I set the unit to RGB, all was fine.
I can now record Freeview on my DVD fine.
I do however have one prblem which this will not overcome, that is the addition of yet another remote control !!!
Byeeeeeee..
Nov 30, 2007 | Pioneer DVR-220 DVD Recorder
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Televison & Video Logo
97 people viewed this question
Top Televison & Video Experts
Electro Med Services...
