Question about Canon PowerShot SD500 / IXUS 700 Digital Camera
How to Fix the lense E18
Please someone help
  • 188 Answers
If you are technically compitent, then its simple. Open the camera and remove the optical assembly. furthur carefully open the lense assembly apart. Remove the motor and the gear assembly so that you can move the barrels manually. carefully check for any friction in the movement. If its moving hard, take every barrel apart, clean them with some hard brush, refit the assembly. Now check the focus motor.normally fine sand or dust get accumulated on the grease at the shaft of the focus motor. clean it check for any damage the the flex ribbion cable of the lense assembly. If you can do all this carefully then reconnect the optic unit to the main board, fit it , switch it on and you will find it working.
Posted on Jul 22, 2008
Camera powered on, lenses extended, then got an E18 error message. Won't take pics, lenses won't retract. Tried charging battery, no difference. Powers up, powers off, that's it.
Canon E18 error happens when the lens gets stuck while trying to extend.
There is a step-by-step tutorial (with pictures) for fixing this yourself on this website, which is too long to re-post here.
You can also try tapping the USB port lightly against a hard surface, and using compressed air to blow out the area between the camera body and the lens turret.
If you can't fix it yourself and decide to send the camera back for repair, be warned that Canon has horrible customer support and response time. You might want to consider replacing the camera instead.
Oct 25, 2009 | Canon PowerShot S410 / IXUS 430 Digital...
Dropped my cano a520 with lense out and now I get
E18 error is common error if the lens is broken already
bring your camera to the nearest repair center
Aug 21, 2009 | Canon Cameras
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
E18 error
Greetings sandrak2,
As frustrating as it might be, I would suggest directly returning to whatever repair shop you had it serviced by and demanding they redo the fix. It is not acceptable for a unit to be sent in for service and return not properly repaired. I would suggest doing this as soon as possible.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 18, 2008 | Canon PowerShot A70 Digital Camera
E18 ERROR SNAPPED RIBBON CABLE ON REPAIR ATTEMPT CAMERA WONT RUN NOW
Hello Dear,
You are requested to take the camera to the Canon Care Centre, but only if the Ribbon cable is removed from its locked it can be reinserted but if it is torn off, even after setting the zoom lense of your camera the Digital Zoom will not work and you will have to use the camera only with Optical Zoom.
Regards,
Manoj Joseph
+91 9352008418
Jun 03, 2008 | Canon PowerShot S2 IS Digital Camera
E18 lens will not come out
E18 Error Fixed Canon PowerShot A520 My lense would not come out and would give me the E18 error and shut down.
I just pressed the power button on and held it down while extending the telescopic zoom lense. It made a horrible sound but the next thing I knew the lense extended out and the camera worked again!
Apr 07, 2008 | Canon PowerShot SD200 / IXUS 30 Digital...
After E18 fixes...lense got in..but does not come out
You can just head to darntoothysam.com and search for "E:18" without the quotes. You won't see your model listed, but you can buy any one of those model repairs and follow the steps to get your A510 fixed.
Feb 26, 2008 | Canon PowerShot A510 Digital Camera
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 | Cameras
E18 Message - Beeping.
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
My lens wont fully extend
My sister's camera was having the same trouble and after trying a few different things, i came across a solution that fixed her camera. Her error said "lense error, restart camera."
I held down the shutter button for a few seconds, then i held down the power button as well. I tried it once or twice and then it worked. I hope this helps!
Mar 29, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot SD500 / IXUS 700 Digital Camera Logo
110 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
