Question about Car Audio & Video
Radio loosing signal - intermittent. fuzzing sound accross all channels.
    Scholar:
  • 143 Answers
Turn the RDS on, this will then re tune itself to the signal.
if you have a VW audi or Ford you may need a amplified aerial feed.
Posted on Jul 18, 2008
The radio recieves great rf power works rodger beep works throws a good strong signal on other radios has a new mic but no modulation
Is this new mic wired for your radio? just because it fits the socket doesnt mean its right. Did the old mic do the same thing reason why you got the new one? just sounds more like a loose wire at the jack where the mic plugs in? has that connector ever been loose or needed tightened at any time?
Jan 03, 2013 | Galaxy Radios DX-44V 40-Channels Base CB...
Intermittent High pitch squeals
other than check your wiring for rubbed spots or loose connections, I don't know. maybe try swapping parts one at time with your buddy. maybe your headset?
Jul 09, 2010 | Kenwood FreeTalk XL TK-3101 (15 Channels)...
Lafayette LR-775 Receiver left channel problems!!1
This sounds like a pre-amp transistor breaking down or a defective coupling capacitor. Without seeing the unit and tracing a signal, I can't say for sure what the exact problem may be. This should not be a major expense though. If you are getting output tot he speaker, just crappy sound, the output section is most likely working correctly. Plan on a parts expense in the $10-$30 range for this repair.
Dan
Mar 09, 2010 | Audio Players & Recorders
Ok, I have a 1993 Dodge Ram 350 Van. Radio will come on then has signal drift. no Display, won't scan channels, can't change channels??? I.m just wondering if it is a problem with the PLL circuit. (Phase...
it is time to replace the radio and you can get wiring harness adapter over at best buy for about $20. you can also get the hardware at the same time. they are very easy to install with these parts even if you have never done this before. if you want a stock radio, i think you will find that it is 2-4 times the cost of a replacement radio.
Nov 08, 2009 | 1993 Dodge Ram 350
Car headunit fuzz in speakers.
my first thing to check would be the ground to the stereo. if your ground wire is loose, you will get that odd sound at most volumes. if that doesnt solve it, then you can go to a car audio store and buy an inexpensive noise filter that you splice into the power wires for your stereo, and that usually eliminates the radio noise.
Aug 04, 2009 | Car Audio & Video
Intermittent low to medium power output from radio, any ideas
The problem is not your radio.One of your connectors -pl259- is dis-solder or open.Could also be a loose antenna connection or an open coax that when you move it,makes contact.
Jul 14, 2009 | Cobra 200 GTL DX 4-Channels Base CB Radio
Radio automatic search
when your radio is on a certain channel the only thing it does is try to pick up that certain channel. say you go threw a tunnel or around the side of a hill. or in a residential neiborhood. the radio has a lot of interference from other things trying to pick up the same signal. there is nothing you can turn off or anything. as long as your getting a good sound on a certain channel leave it there,, when it don't pick up so good your loosing your signal and need to find a station that is closer to were you are. good-luck ray
Nov 09, 2008 | 2001 Audi A6
Car Radio, Casette Player and CD Player not working
Hello Lei,
It sounds like the antenna has came loose from the back of the radio and the wiring harness is loose.
Make sure you have a good ground going to the radio, or this will cause a short and make the radio do strange things, the fact you sometimes get a signal tells me the radio is in working condition.
Sep 22, 2008 | 1997 Ford Expedition
Picture shows snow and fuzz on channels JVC AV-32980
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
Mar 27, 2008 | JVC AV-32980 32" TV
Car Audio & Video Logo
130 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
