Question about Sony Playstation 3 (PS3) Console
Ps3 wont read disks
My ps3 for some reason has stopped reading all disks, everything else works fine, just wont read games or dvd
If YOUR WARRANTY IS UP. taking the ps3 apart is easy as long as you have the rght screw drivers. getting the plate off is the hardest part. there is a hex screw under the warranty sticker. after removing the screw, simply slide the plate down and it will pull off. then there are about 8 philips head screws on the casing itself. after removing these screws the top is hinged on the front side of the system... lift the back untin it is at a 90 degree angle and and remove the flat wire that goes to the SDcard slots by lifting the black flapwith your fingernail, then the top is removed. at this point the disk drive is no longe fastened by any screws of clips. pull the plug from the left side toward the front out to diconnect that set of wires. then there is a big flat silver strip connected to the bottom of the drive. once again lift the black flap to release this you are ready to open the drive itself. there are 2 silver screws on the bottom rear of te drive and 3 black ones at the front. you will need a very small philips head screwdriver for these. then the gray casing will come off. thelense is not exposed yet. there are still 5 or 6 tiny black screws on the top of the drive that will remove the black plastic case THERE ARE 2 TINY WIRES COVERED BY TAPE BE VERY CAREFUL NOT TO PULL ON THESE WHEN TAKING THE BLACK COVER OFF
. now the lenseis exposed. simply clean it with rubbing alcohol and q-tips and reassemble the machine. BE SURE NOT TO GET ANY OF THE WIRES PINCHED WHEN SETTING THE DRIVE BACK IN PLACE AND DONT FORGET THE LITTLE METAL GROUND ON THE RIGHT REAR OF THE DISK DRIVE. ANY ?S E-MAIL ME AT
Posted on Apr 03, 2009
Same thing happened to mine, I had to go to the store it was purchased from and have them re-create a receipt and call Sony to have them forward me a shipping box so I can send it to them for repair. More than likely its the disk drive going bad from what I was told.
Posted on Jul 17, 2008
Ps3 wont read ps3 game disc
It may be inside the ps3 console and it may be broken you have to either clean the disk or get a new ps3 but try contacting a game stop or going to a local game stop to ask for help you might be able to fix it
Sep 01, 2012 | Video Game Consoles & Games
My ps3 wont read any disk compatible with the ps3
My PS3 stopped reading my PS3 games last month, but it was still able to read DVDs. I looked it up online and learned that it usually happens when you smoke a lot around your PS3 while it is running and a film builds up on your blu-ray lens. I followed this YouTube video and had it playing my games again fine. Hope this helps.
Mar 14, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 (PS3) Console: disks are not reading. The ps3 is working fine oth...
This is quite a common problem with the PS3 and is caused by a problem with the laser on the Bluray drive which is malfunctioning and can no longer 'see' or read the game disk properly.
The PS3 uses a dual laser system. This consists of either a dual refractor type lens or two entirely seperate lenses depending on which pickup is fitted to your particular system. One laser is for reading ordinary DVD disks and PS2 disks and the other for Bluray and PS3 games.
The symptoms you describe are quite typical of a failure of one or both of these lasers.
For more information on how to resolve the problem please have a look at this FixYa Tip on the subject.
Many thanks for using FixYa
May 18, 2010 | Sony Playstation 3 (PS3) Console
When i updated my PS3 for the new Call of Duty it stopped reading the disks. It worked fine b4 the upload but now it wont play any of d games i have. Whats d craic, how do i sort this
It might just be coincidence that your blu-ray drive has packed up at the same time as the update. Ring up Sony and tell them this and you could get a new console for free if your in the warranty.
Nov 12, 2009 | Sony Playstation 3 (PS3) Console
PS3 problem - Wont recognise or load PS3 game disks
swich back and forth between the ps2 game and ps3 game or just keep putting in the ps3 game until it reads it. your laser is probally going.
Oct 05, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont read my game disc;it reads and plays everything else fine,what came i do,Please help!!!
my ps3 come ,i was playing my game at the end of the game it froze iturn it off and when i cut it back on and put in 1 of my video game.dvd .cd and there was no display is it broken
Jul 02, 2009 | Sony Playstation 3 (PS3) Console
Ps 3 wont read discs
You need to replace the lens, but try to clean it first.
You can find out how to clean the lens on you tube.
Jun 06, 2009 | Sony Playstation 3 (PS3) Console
Wont read disk
PS3 is The amazing device by sony but it has some common problems like Disc read Error etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Dec 06, 2008 | Sony Playstation 3 (PS3) Console
That would be the BluRay diode in the laser assembly. There are 2 diodes that emit the light for the laser. One is red which reads everything but BluRay and PS3 games. The purple laser diode reads the BluRay and PS3 discs. You will need to have the laser replaced or call Sony to get a box to send it in for repair or replacement. Thanks!!
Nov 09, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
147 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
