Do you know how to reset the web username/password for the ricoh IS200e?
We had someone who set the scanner up but didn't tell us the password.
I have had a look on the settings on the scanner and i can't seem to find out how to change it or reset it without loosing the current settings...
Thanks
Default login: scanner
default password: password
Reset device to factory defaults:
press Clear modes key
press numbers 107
press Clear/stop key and hold it for 3 seconds.
You will enter to service menu. In the service menu choose "Format ROM disk" and press key 1 several times.
The device will be reset to factory defaults. You can now use default passwod and username.
Ya, same problem.
I have the same problem with is200e scanner, any solutions?
I'm also facing the same problem with PSC433dc image sanner IS200e
I need to reset my web/user interface password... IS200e
Was there a solution?? Can I reset the scanner to factory defaults? If so how?
