I have a 46" RCA lcd flat screen tv and i cannot get it to turn off. There is no picture or sound but the green light on the front will not shut off. I've tried unplugging it for over 8 hours and every time i plug it in the lights still on and i can't turn on or off any suggestions?
Send it in for Svc. It sounds like your control module if defective.
Posted on Jul 18, 2008
Tv screen has gone black but still have sound when you shut the tv off and turn it back on the screen comes up but it flashes and goes black again
Hi Bob, The link below is a YouTube video showing how to fix a RCA television(DIFFERENT MODEL) NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
RCA 46LA45RQ tv repair No picture no power troubleshooting
May 01, 2016 | RCA L46WD250 46 in. LCD HDTV
My RCA 46 LCD has no picture or sound but the blue lights on?
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 02, 2015 | RCA Televison & Video
RCA 46LA45RQ tv turns on with sound and after 1 second the picture goes out. The blue power light stays on and the audio, but no picture.
Back-light inverter board fault. Replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magzine" will make surf easy Pull up older posts. Surf the site with patience.
Apr 17, 2014 | RCA 46 46LA45RQ LCD TV
46 rca model 46la45rq comes on for just a second then the screen goes black and it only plays sound! what needs to be replaced
Sounds like you have a backlight problem. To verify this, turn on the set and dim the lights in the room. Take a bright flashlight and shine it on the screen. Do you see a faint picture?
Jan 14, 2013 | RCA 46 46LA45RQ LCD TV
Sony KDL-46XBR4 purchased in 07. When turning set on, the Blue "Sony" light comes on and the Green "Power" light comes on.... No Sound, No picture, No menu options available. ???...
Open the tv and look for blown capacitors. These will be easy to see as they will have popped tops on them (not flat). Once you find the problem capacitors you will need to replace with the same uF value and a higher Voltage value as capacitors are rated "up to" the value listed on the side of them. EX: (in the tv) 1000uF 10V....(replace with) 1000uF 35V
Please rate if this helped :)
Mar 09, 2011 | Sony KDL-46XBR4 46 in. LCD Television
Ur controller board it dead,the one in the middle bottom of LCD screen.It a small square board.Replaced this board should have sound and picture back.Tries websites, to buy a refurbish Controller board for the replacement.
Apr 13, 2010 | RCA L32HD31 32 in. LCD HDTV
Rca L32hd31 lcd no picture blank screen.
Your mainboard is damaged, replace it and that will solve your issue.
Jun 06, 2009 | RCA L32HD31 32 in. LCD HDTV
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
Televison & Video Logo
Top Televison & Video Experts
