Question about U.S. Robotics 1 x 10/100Base-TX WAN, 4 x 10/100Base-TX LAN - Broadband Router Get everyone online at the same time...
Router gets disconnected
Hi
my problem is, when i switch off my router and then again switch it on after some time it takes time to connect to the net or some times it automatically gets disconnected from net
  • 417 Answers
you can try to unplug the power cords and phone jacks to all your cordless landline phones in the house from the wall and see if that makes any difference, sometimes those interfere with the routers wireless connections, and wreaks havoc, if thats it try to change the channel on your cordless phone or get a different brand of cordless. If your internet light is going on and off in sequence with your modem internet light you might have a connection problem, depending if your cable or dsl, if your dsl make sure you have noise chockes on every phone or you will get that sparatic internet problem. If your cable, make sure all your tvs are connected securely or try and undo all the cable from every tv except the modem and work your way back to the bad connection untill you find the problem.
good luck
J
Posted on Jul 17, 2008
My router is connected to my desktop for a wired connection, but my network will only allow my laptop to connect to the network wirelessly. Another laptop, my Wii, and my iPod Touch all get an error...
Solved: Belkin G+ Mimo Wireless Router Issue Hi All
Ever since i bought this Belkin G+ Mimo Router, i've been having this problem, but couldn't find the time to take it back (or too lazy, whatever). :P
Trouble is, frequently when surfing the net, the router disconnects, for no reason. It happens almost everytime i go on youtube, and just some random sites i go on, will cause the router to disconnect. Can't seem to find the answer anywhere else, so i took it upon myself to register and ask you guys. Have no clue what the problem is, was thinking maybe a port issue, but since the router is uPnP i don't see how, besides, could that even cause it to disconnect? Anyway, any help is appreciated.
Jan 05, 2011 | Belkin Wireless G+ Mimo Router
Many time net disconnected
Your router has small NAT table and when this table overflows, router hangs and Internet connection disconnects. You can solve router disconnects with Router Commander software. This software accelerate your router using dynamic NAT feature and other technologies that speed ups router and prevent it from disconnecting. You can get it from www.routercommander.com . Good Luck.
Oct 17, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
How to tell your net gear router is no longer working correctly It connects to the internet throuigh the modem I am plugged into port # 4 and I have tried port # 1. At any given time I loose connection and...
HI jamesbigble. To see if I understood your problem correctly. You are using a computer thru a router. And the router is connected to a modem. After a while all the lights on the router are lit. And then you have to unplug it and plug it in again and it will work for a while right? Well, if that's the case, that's the router for sure, you need to replace it. If you see something like that happening to the modem, well the same answer for the modem. If any modem, router or switch have all the lights lit, it means some serious problem. Maybe hardware/power or firmware issue. In case you dont want to spend money, I would recommend go to the netgear website and download the latest firmware for your router and try it. I hope this helps. Please dont forget to rate and write positive feedback for our fast-free support today. Thank you :D
Apr 30, 2010 | NetGear WIRELESS-G WGR614 802.11G WIRELESS...
Internet disconnection
I think the problem would be the over use of the modem, try turning it off when noone is using.
May 07, 2009 | Buffalo Technology AirStation Nfiniti...
Allied telesyn at wa1104g router lags
is it possible that someone else is using your bandwidth? try changing your security settings.
Feb 25, 2009 | Allied Telesyn AT WA1104G Wireless Router...
Router has stopped routing
Hi, Check to fix with the router's warranty.
Somethings that you could try yourselves are:
- Disconnect the router and power it down. wait for 30 secs and switch it on.
- Go into the router settings and change the transmitting channel to either 1,6 or 11.
These steps are to avoid air traffic congestions.
Feb 24, 2009 | Linksys Wireless-G WRT54GS Router...
Netgear
There are two things involved in getting disconnected either your comp is getting disconnected or your router.
Instance 1
Computer getting disconnected connect your comp and router with ethernet cable if using wireless. Because at times it's not router but the wireless connectivity that gets loost.
Instance 2
Router getting disconnected...
Reset your router by holding the reset pin at the back of your router for 15 secs and lights will start flashing on router wait for 1 min you'll have router reset to default settings and now check that dsl or internet light on your router is flashing or static if flashing contact your isp issue with the line if static run the disc for router installation again and it'll remain connected after successful installation.
Apr 22, 2008 | NetGear WGR614 Wireless Router
Media access crontrol (MAC) address
Hi Stevetabor9,
Finding and Registering Your Xbox Console's MAC Address
  1. Turn on your Xbox console with no game disc in the disc tray.
  2. From the Xbox Dashboard, choose Settings, and then Network Settings.
  3. The 12-digit number at the bottom-right corner of theNetwork Settings screen is the MAC address of your Xbox console. Do not change your Xbox console MAC address; just write it down so that you can use it later.
  4. If you have a direct connection from your Xbox to your modem, you'll have to disconnect it and reconnect your PC to access the Internet.
  5. From your PC, open the following page:
    British Columbia: http://oca.bc.hsia.telus.net
    Alberta: http://oca.ab.hsia.telus.net.
  6. Log in using your Telus Velocity Internet Service account.
  7. Select Manual Registration and Administration of PC's and Devices.
  8. In an available slot, enter the MAC address of your Xbox console, then select Update.
  9. Follow the steps in Direct Connection with Telus to try to connect to Xbox Live again.
Registering Your Router MAC Address
  1. See your router documentation to find your router MAC address.
  2. Before disconnecting your PC from the Internet to set up a router connection, open the following page:
  3. Log in using your Telus Velocity Internet Service account.
  4. Select Manual Registration and Administration of PC's and Devices.
  5. In an available slot, enter the MAC address of your router, then select Update.
  6. Set up a router connection to Telus and try to connect to Xbox Live again.
take care
Mar 15, 2008 | 2wire 2700HG-B Router (2700HGB)
U.S. Robotics 1 x 10/100Base-TX WAN, 4 x 10/100Base-TX LAN - Broadband Router Get everyone online at the same time... Logo
178 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
