Question about Fisher and Paykel GWL11 Top Load Washer
Problem with F&P MW511
Hi team,
After filling the water our MW511 stops with lights #1 and #7 on (both orange) and beeping.
After turning off, lights 1-5 flash on and off.
Any suggestions?
  • Anonymous Mar 22, 2014
    mw 511 stops and comes up withn the above error code which is lights 1 and 8 ?
  • Anonymous Mar 30, 2014
    light number 3, 6 and 8 are flashing, how can I fix this?
  • 639 Answers
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
BUY SPEED QUEEN NEXT TIME AND HAVE IT FOR 25 YEARS! THAT'S WHAT I HAVE!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Aug 26, 2008
Help F&P MW511 beeping and not draining
You have Error code 37,
37.
(00100101) Pump Blocked Error (No change in the water level)
While draining, the water level reading from the pressure sensor has not changed for over 3 minutes. There are three likely reasons for this fault. One is that the drain hose or the pressure switch hose has been squashed or kinked and the pump out rate has been dramatically reduced. The second possibility is that the pump is partially or fully blocked. The third is that the pump is not operating due to Motor Control Module, wiring or pump failure. This fault could also appear if the machine is pumping to an unusually high head of drain hose or into an extended length of drain hose. The fourth possibility is a diverter valve fault or blockage, water level is not altering as the diverter is stuck in the recirculation mode, giving the module the appearance the pump is not lowering the water level.
Primary Source:
Action:1)
Pump System.
Check that the drain hose has not been kinked.
2) Check the length of the drain hose and try to reduce the length if
excessively long. A 39.36in / 1 metre extension hose of the same diameter fitted to the existing drain hose is the maximum allowable length.
3) Check for open circuit windings in the pump. (Note: Pumps are
fitted with a thermal cut-out, which will reset on cooling.)
4) If the basket is empty of water, remove the pump from the pump
housing and check that it is not blocked. Also check the drain hose is not blocked.
5) If the basket contains water, then service the pump from the top of
the machine by removing the top deck and inner basket. Bail out the water, remove the pump cap and hood and clear the restriction.
Secondary Source: Wiring.
Action:
Tertiary Source:
Action:
1) Check the pump harness is connected correctly to the pump. 2) Check continuity of the pump harness.
Motor Control Module module.
Activate the pump by operating the machine in spin mode. Check the pump is rotating. If it is not operating, and Primary and Secondary checks have been performed, then replace the Motor Control Module.
Jun 10, 2013 | Fisher and Paykel GWL11 Top Load Washer
MW511. 2 & 7 lights flash, beeping. No agitate or spin?
Fault code 66 is pressure sensor is faulty
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
Apr 20, 2012 | Fisher and Paykel Washing Machines
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hi, i have an MW511. All of a sudden it keeps stopping mid cycle with 2 red lights coming on and beeping like crazy. I have re packed the machine, a few times, so its not un balanced, also reduced the...
Hi just read your posting.Now the lights that are on when the machine beeps will be in a row of 8 lights.Starting from the left to right which lights are lit when the machine stops and beeps,Is it the 2nd and 5th or the 3rd and 7th ---etc---?Now to fix the water coming out of the hot hose as the machine is filling just fold the hot hose in half and tape it in this position.This will stop the water coming out of the hose.Please reply with additional information on the lights and I am sure I can help you rectify this fault.Looking forward to your reply.
Oct 14, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a Fisher & Paykel washing machine. Model MW512NZ. It has stopped working properly. The water is stopping and starting when the machine is filling and although the machine will pump out it will...
Hi just read your posting.Now the lights that are flashing will be in a row of 8 lights.Starting from the left to right which lights are lit,Is it the 2nd and 4th or the 3rd and 6th ---etc---?Please reply with the additional information and I can help you rectify this fault.Looking forward to your reply.
Aug 01, 2010 | Fisher and Paykel Washing Machines
Starts and stops
A failed inlet valve is not uncommon in F&P machines. The hot valve is different to the cold one, so don't exchange them. Not a big job for a tech to do in-laundry. Good luck....Nomess
Jun 11, 2010 | Fisher and Paykel Fisher & Paykel Washer
Have kelvinator smart drive 503, water won't run
I have exactly the same issue, which first appeared yesterday. Following your advice, the lights that are lit are 3rd, 5th, 7th and 8th. The SLOW & HOLD spin speed lights are lit, along with constant beeping :)
Jun 16, 2009 | Fisher and Paykel GWL11 Top Load Washer
GLW10US won't do anything but beep
well i don't have any experience with this brand but i would say you need to change the fill switch it senses how much water is in the tub shuts the water off then starts the washer its also called the pressure switch
Feb 16, 2008 | Washing Machines
Problem with Fisher & Paykel MW511 toploader washing machine
Having the same problem. Any ideas at all? It's really frustrating.
noavatar_s.gif nwesthamz
Rank: Apprentice
Rating: 75%, 1 votes
mw511 fills with water but cylinder isnt spinnig and when it stops filling nothing happens. However sometimes it will go complete cycle ans a noise can be heard on spin cycle even though it is not spinning. As thoiugh the motor is not engaging with the cylinder
Was this helpful? Yes No
Jan 12, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
639 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
