You will need a USB 2.0 Type B Printer Cable to connect a printer to the Acer Aspire 3610 notebook. An older style printer is not able to connect to the your notebook because there is no parallel port installed to connect to.
Try using external USB HUB (POWERED) Adapter. It might fix this issue. Use an other USB cable and see. If the problem still exist do not plug in the printer again, you may damage your USB port or even burn your laptop motherboard. hope this helped
Sounds like a hardware issue. I would guess that there is a bad connection between the usb's and the motherboard. If you are comfortable dismanteling the laptop and re-soldering the usb's than give that a try, but I would recomend you give it to a pro.
Here is a link that explains the process.
http://www.insidemylaptop.com/taking-apart-acer-aspire-5100-laptop/
