Question about Acoustic Research UltimateRemote Remote Control
Acoustic solutions ctvl32w3hd
I have recently bought the above model tv and can not find a sky+ code to workon my remote V6 please help
  • Anonymous Jul 26, 2008
    ive got same tv,ctvl32w3hd,sick of using 2 remotes ,is there a code under another name
The sky remote code for acoustic solutions ctvl32w3hd 1239 (its a goodmans code ) works fine on mine
Posted on Oct 20, 2008
  • adam958 Nov 22, 2010
    Hi for some reason this isn't working for me and i have the exact same model, how did you go about inputting the code, there are so many different ways
    thanks
Search the web, there is a code, its for an LG tv though as the screen is and LG set.
Posted on Aug 31, 2008
SOURCE:
Hi can you help me please , ive bought a polaroid lcd tv model no p40lcd12 . ive looked everywhere on the net for the remote code for my sky + remote. sky dont have it listed .has anyone got it .would...
I bought the same TV yesterday and I've used code 1065 to program my sky remote, which worked fine. It's thanks to the answer relating to Mitsubishi and TiVo cos I used a Mitsubishi code!! Hope it works for you.
Sep 23, 2012 | Televison & Video
I need a code for my Samsung tv model LE37A456C2DXXU, to connect my Sky remote to the television. Thankyou.
Please rate this solution if you find it helpful. Thanks.
It really depends which version of Sky remote you have. You can check this by looking inside the battery compartment. If you have a sticker with RC1600/00 then it probably wont work your TV. If it says Rev 4, or Rev 6, it might work with this code: 0646
If you have a Rev 8, then try these 3 codes: 1340, 0840 or 0646
Sky's information is a little bit contradictory regarding your particular model of TV, so I don't guarantee success. However, 0840 and 0646 seem to be generic Samsung codes, so I think these would probably control the power and volume functions on you TV if nothing else.
Try the codes above and report back.
Oct 16, 2010 | Samsung TV Set Top Box Remote Control
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Sky remote control code
Hi!
You can follow the instructions given in the link---
Codes for Sky Digibox
You can also see for reference the instructions manual on the link---
Sky Digibox
You need to just click on the above links and will be able to get the sky remote control code.
Please accept this solution and do rate it as FixYa if found useful.
Thanks
Rylee
Apr 26, 2009 | Televison & Video
Sky remote code
You will need to go to Sky's website and order a new remote if this doesn't work.
Press tv on the remote
press and hold Select and red until the remote LED blinks twice
type in 0 0 6 0
press power button on the remote, if the tv goes off press select and it should control all the tv functions.
if the tv does not go off press tv then power buttons on the remote and keep doing this until the tv goes off, then press select once the tv goes off.
Like I said earlier, if this doesn't work you will need to order a new/replacement remote via Sky's website then put the code listed above in.
Jul 18, 2008 | RCA RCR660 Remote Control
Acoustic Research UltimateRemote Remote Control Logo
885 people viewed this question
Top Acoustic Research Televison & Video Experts
Ekse
Are you an Acoustic Research Televison and Video Expert? Answer questions, earn points and help others
