Samsung PS42Q97HD plasma tv 42" problem: can not power up. It was everything fine and working when sudenlly audio and video gone. There was a loud crack from the back of tv shortly afterwards. Now when you connect the power cord you can hear regular clicks (same cklicks you could hear when powering up the tv b4) and nothing happening. Blue light stays on and tv can not started. Thank you for you help
  • thesaintdeko Sep 10, 2008
    tv turns itself off and then cliks on and off as if powering up
  • safehands Jan 23, 2009
    I have exactly the same issue and Samsung are quoting £300 to fix it, half the price of the TV.
techman
  • 3130 Answers
SOURCE: JVC AV-56WP74
sounds like a power supply7 problem such as a power regulator is bad or maybe the Horizonbtal deflection cu8rcuity is defective. sounds like something if you ask me? should be taken care of by the pros??? Im sorry not being able to assist you better but these sets have hundreds of volts nin them and shoulnt be played with by an unauthoized service company.. Good Luck
Posted on May 19, 2006
bluenadas
  • 203 Answers
SOURCE: Rca 52in Projector
Most likely the issue in on the large signal board. The TV is going in to shutdown. Repair might run $200.00 or so.
Posted on Jun 08, 2007
SOURCE: tv wont turn on the timer/standby light lickers
Open up the tv. On the boards that have connectors, de-attach all of them, one by one. Use a can of "duster" to clean out each receptical, then re-attach each piece. Do this to each and every connector on the boards inside. This should solve the problem.
Posted on Dec 22, 2007
ctf1800
  • 4402 Answers
SOURCE: blinking red power light - set will not turn on
heres your fix
http://www.riddledtv.com/repair/journal/Toshiba51H84/index.html
Posted on Jan 24, 2008
electronick
  • 505 Answers
SOURCE: LG Plasma TV has speakers fizzing in short bursts, cant hear any audio
Yes I believe you have a hardware failure in your audio amp IC. In some cases, a speaker will cause all the audio to distort, but its very rare for a speaker to cause this issue. If you just got it, you can return for a quick resolution, or contact a local repair center for a new main board replacement.
Posted on Dec 07, 2008
How do I get rid of vertical black bars on a plasma television
Fix Panasonic Plasma TV Vertical or Horizontal Bars ...
? 10:21
https://www.youtube.com/watch?v=CpWZTnAXbLg
Dec 30, 2013 - Uploaded by Pet Rock's Garage
This video covers how to fix a Panasonic 42" Plasma TV model TH-42PX600U that has vertical distorted ...
Horizontal black lines on Samsung 50" plasma tv - Forums - CNET ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - This past spring, a thin black horizontal line appeared across the screen, everything else is working fine. Next day ... In reply to: Horizontal black lineson Samsung 50" plasma tv .... I tried a white wash on the TV, but that didn't removethe line. Plasma TV has 3 thin black lines
Jun 11, 2015
Black Line across Samsung 50" Plasma has appeared?
Jun 11, 2015
Vertical black line on Sony PFM-50C1 Plasma Display
Jan 28, 2007
More results from www.cnet.com
Jan 05, 2016 | Samsung Televison & Video
Samsung plasma 42 inchs with sound no picture
Most likely your Y Sustain panel has gone bad. I would have a qualified service center evaluate it to be sure.
Nov 07, 2009 | Samsung PS42P2S 42 in. Plasma Television
How do i connect speakers to my samsung ps42q97hd plasma tv
The model in question does not have standard speaker outputs, so there is no way to "directly" wire the speakers up.
Presumably because the TV has built in speakers.
However, you can use the audio outputs on the rear of the TV, Red RCA plug and White RCA plug to drive the speakers connected to a hi-fi system, Surround amp or similar?
The cables are very cheap, available from Argos and the like.
You will notice the improvement in sound.
Does that help?
Sep 04, 2009 | Samsung PS42P2S 42 in. Plasma Television
No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
May 26, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
Blank Screen
the power supply board has gone bad. part number
BN96-00249A
Oct 19, 2007 | Samsung SPN4235 42 in. Plasma HDTV
I have suddenly lost the picture on T.V. but still hear audio of program...
sounds like your input board went out. I had the same problem on the ILO version of this panel. Got a replacement part off of Ebay. Search for Ilo plasma on ebay and it will come up
Sep 08, 2007 | Tatung P42BSKT 42 in. HD-Ready Plasma...
Televison & Video Logo
160 people viewed this question
Top Televison & Video Experts
Electro Med Services...
