The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
"No SD memory card inserted" messages appears when using digital cameras,
"A media card hard been inserted that contains errors. Do you wish to repair the Media Card now?"
You can read the files on SD memory card, but you cannot write new files or you cannot edit files on SD memory card,
"Access denied", when SD card is corrupted or broken,
you can fix sd memory card errors first and them format you sd card.
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
