Question about Crown MA-5002VZ 2-Channel Amplifier
My amp doesn't turn on
The trouble of my amp it doesn't turn on the power cord it's seems ok, it work at first but then nothing
  • 682 Answers
Take off all your speakers cables from amp and test if it is fixed you will have a problem in your cables or speakers itself-if not you have a problem in amp itself and needs to repair in service center.
Posted on Jul 17, 2008
Nothing happens when I push the foot pedal
Please check the Stitch regulator & Presser foot lifter.
Jan 03, 2014 | Singer 7442 Mechanical Sewing Machine
Control panel buttons no longer work.
Hello ...
I tried to look up your model numbers here (usa)...
with no success... (Kenmore 13742 / 13744 / 13749)
I rarely (ever) suggest owners go direct to Sears...
but this would seem to be.. appropriate...
(I my opinion they are rude & pushy to sell parts
(good news ... here... their guaranteed fit/fix)).
Before doing so...
Check your water, drain & power at the appliance.
With the breaker turned of...
open the appliance cord JUNCTION BOX and assure the
wiring devices (usually "wire nuts") are still tight and secure.
Finding nothing... you are at the UNHAPPY JUNCTURE
where you need to use SEARS PARTS DIRECT...
http://searspartsdirect.com/dishwasher
Aug 01, 2017 | Kenmore 13742 / 13744 / 13749 Built-in...
SAMSUNG Le32b450 DOESN'T TURN ON
check or have checked the power supply in this set, if not able to do it yourself have a tech or a shop examine it.
Dec 21, 2012 | Samsung LE32B450 32 in. LCD TV
I have a lenovo thinkpad T420 and three days ago I lost my power cord now that I got a new one my laptop screen doesn't seem to turn on I tried a lot of solutions and nothing seems to work. When I turn...
Hi, try removing the battery pack then use the AC adapter or power cord alone. If still the same. Eject the battery and also remove from outlet hang on for 10 minutes. Then try to turn it on again with AC adapter alone
Oct 06, 2012 | Computers & Internet
Benina foot pedal doesn't work
type in browser sewing machine parts in panama central america & see what comes up
or if you have a phone directory check for sewing machine shop & see if they can order one
Mar 09, 2012 | Bernina Artista 180
I have a Fimco 2100 model sprayer that keeps blowing the fuse. Wiring is all ok. Pump doesn't even attempt to turn on. Fuse blows almost 1 second after pump switch is turned on. Pressure gauge never...
The breaker is too small, the cord is too small, the starter motor on that thing draws 18 amps. It will trip any 15 amp breaker and any 20 amp breaker with something else running, any cord will drop the amp below the starter winding min. make sure nothing is running, separate circuit if you can find one, no extension cord, and a 20 amp breaker in the fuse box. if that is not the problem , then something is shorting out when you hit the switch. Check the wiring on the pump and make sure all is secure, no loose wires, no sparks. My compressor won't run on any old plug, has to be 20 amp, has to be without a cord or with a heavy cord, and has to be hot out, if it is cold, forget it!. We have to keep the compressors in a heated room so they will run in the winter. Hope this helps.
Jul 08, 2011 | Garden
I've put in new batteries and it doesn't turn on.
some P touch series had trouble with the lid not closing, or seating, and some may not have the batteries inserted the way that is logical. check the battery polarity one by one and make sure that they are going in in the right position and order. then make sure the tape is in right and seated and that the lid closes. if all these don' t solve it take it back and get a new one as there is not a reset that I am aware of. Check your specific model for a small reset round hole on the bottom just in case and try the manual. http://www.ptouchdirect.com/ptouch/manual/PT1880.pdf
Jun 13, 2011 | Brother P-Touch PT-1880 Printer
I have two Behringer Eurolive B415DSP speaker, one of them stopped working out of no where. To my best knowledge, the problem is that it doesn't turn on. I had the Fuse check already and thats not the...
This is alimentation fault of the amplifier inside the box. Dismount the amplifier block and take a look first if there are some burned pieces. If it seems all ok, better bring it to a electronics/ tv service center.
May 18, 2011 | Behringer Eurolive B415dsp 600w 15" PA...
Treo 650 won't turn on
Could be a dodgy power connection this seems to be happening a lot at the momentif you look at other threads here.
Kevan
Oct 20, 2007 | Palm Treo 650 Handheld
Crown MA-5002VZ 2-Channel Amplifier Logo
606 people viewed this question
Top Crown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Crown Audio Player and Recorder Expert? Answer questions, earn points and help others
