Question about Toshiba Computers & Internet
Toshiba Laptop overheating
I have a SatA215-S4757 that is overheating. The keyboard gets so hot that it is uncomfortable to type. After 2-3 hours of use the computer puts out fumes which are causing me headaches and nausea. Toshiba has repaired the problems 3 times in 2 months. Each time there was evidence of burnt components. Now, I am afraid to use the repaired computer fearing that I may get sick again.
Has anyone else had this problem? Is there a fix for this problem? I do use the computer on a cooling fan.
    Novelist:
    Champion:
  • 256 Answers
The blockage of air vents can lead to overheating of Toshiba Satellite A500 laptop. It happens when the air vents get blocked by dust particles. Clean the exhaust vents of the Toshiba Satellite A500 laptop weekly with compressed air. Always place your laptop on harder surface rather than placing it on soft surfaces like bed, blanket, pillow, etc. to maintain proper air flow.
Get more information to fix toshiba overheating problem :
http://supportfortoshiba.iyogi.com/a500/toshiba-a500-overheating.html
Hope this information helps you.
Posted on Jul 27, 2011
  • 115 Answers
Your Problem is of overheating the unit.
Pls check the Air exhaust of the Laptop. The fan may be blocking air and may be causing the processor hot. It's better to
service the Laptop if problem still persists.
Viren
Posted on Jul 17, 2008
My laptop shut down after powering out with no warning and will not restart.... Toshiba L550 screen stays black but when I hit the enter key it beeps........any suggestions
“My Toshiba laptop suddenly shuts down by itself without any warning. Sometimes it works fine for hours, sometimes it shuts down in 10-15 minutes.” This complaint we hear from our customers over and over again. About 15-20% of all Toshiba laptops we get for repair, suffer from an overheating problem. Yep, OVERHEATING!
This is one of the most common problems with Toshiba laptops we deal with.
Indications of laptop overheating problem:
  1. The keyboard and the bottom of your laptop are very hot when the laptop is working.
  2. The CPU fans are working all the time at maximum rotation speed and operate much louder than before.
  3. The laptop suddenly shuts down by itself without warning. When it just started, the laptop was shutting down after 1-2 hours and how it shuts down after 5-10 minutes of operation.
  4. The laptop works fine when it runs idle, but shuts down as soon as you start using any memory demanding applications (DVD player, image editing software, video editing software, etc.).
Solution:
If the CPU heatsink is not clogged with dust and lint completely, you can use canned air and just blow it inside the laptop through the openings on the bottom and on the sides. It’s nice as a precaution measure, but it might not work if your laptop already has a problem and the heatsink is completely clogged.
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A70/A75) you have to open the laptop case all the way down.
  2. Carefully disconnect the fan cables on the system board and remove the fan. If the fan makes unusual sound when it spins (grinding sound), I would recommend to replace the fan.
  3. Clean the fan and the heatsink with compressed air.
  4. I would also recommend removing old thermal grease from the CPU and applying new grease for better heat conductivity.
May 04, 2010 | Toshiba Computers & Internet
Tip
Fix OVERHEATING Notebook
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes (for example Toshiba Satellite A135) you have to open the laptop case all the way down.
on Mar 15, 2008 | Toshiba Satellite A135-S2276 Notebook
My laptop gets heat and shutdown
Solution:
  1. Open the laptop case, so you can access the CPU fan and the heatsink. In some cases you can access the heatsink through the latch on the bottom of the laptop. Sometimes you have to open the laptop case all the way down.
Feb 27, 2010 | Compaq Evo N610C Notebook
My Toshiba laptop TECRA A9 shuts down on second attempt only, not the first time. What can I do?
Hi..
Laptop shuts down? Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot. The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down. Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning. Hot spot, fan always runs? Many laptop brands and models have characteristic hot spots, like a particular corner of the keyboard or over the battery compartment. Before proceeding with the more invasive cleaning techniques that involve opening up the laptop (and potentially breaking something), spend some time searching the web for user feedback on your make and model. The bothersome hot spot on your laptop that none of your friends or colleagues have ever hear of may be a characteristic issue with your particular model and not worth a major panic.Similarly, if the fan always runs, or almost always runs, it may be a characteristic of the particular model that it simply gets hot in normal operation, or the fan control software might be poorly conceived. As long as the laptop isn’t overheating, I’d probably learn to live with a fan that seems to run too much if it’s typical for the model, and only get worried when I don’t hear it anymore.
Regards
PCmania
Aug 15, 2009 | Toshiba Tecra A9-S9021V Notebook
Advent overheating
you'll need a laptop cooler pad
Jan 24, 2009 | Toshiba Satellite A25-S207 Notebook
My Toshiba Satellite A215-S4757
you may try:
1) fortunately case is your windows system files damage to have to restore your laptop system(ghost),
2) hard disk sector damage too much so change a new HD test
3) the worst case is hardware trouble on the motherboard.
Dec 10, 2008 | Toshiba Satellite A135-S2276 Notebook
Keyboard and overheating
Your problem is an issue with the system board. Just update your BIOS and the typing and overheating issue should be resolved. Go to the acer support site and select your model. check if you can see a BIOS update available and update your laptop.
Hope this helps.
Oct 03, 2008 | Acer Aspire 3000 Notebook
WEBCAM
Use the following link and download utility for your lap.
Try this
Thanks
Iqbal
Mar 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Computers & Internet Logo
604 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
