Question about Cell Phones
It is stuck on the option 'Headset' and won't let me select any other option there.
  • Anonymous Oct 25, 2008
    same ****, & this thing is only 2-3 mos. old! :(
    Sergeant:
  • 234 Answers
Hi! format your mobile once!
Posted on Jul 18, 2008
  • asdsadsadsaa Dec 13, 2010
    What an intelligent answer. That really helped me. I'm so glad you took the time to share your wonderful intellect. The world is now a better place.
My straight talk LGL55C powers up and goes to the blue tracphone blue screen and won't power off with power button or anything
Take the Battery out.
Place it back in.
Press and hold the Vol down : Home : Power buttons simultaneously for 10 sec.
Using the volume buttons navigate to the reset to factory settings option.
press select (left of home on L55C).
Confirm to reset.
Select to reboot.
You should be good.
Oct 30, 2012 | Cell Phones
While i connect my wire less headset it ask passcode
1 Set your Bluetooth phone to discover the headset by following your phone's guide. Typically, the steps involve going to the Settings, Connection, or Bluetooth menu on your phone and then selecting the option to discover Bluetooth devices. Your phone will find the Samsung WEP200 headset. 2 Select Samsung WEP200. 3 When the phone asks if you want to pair with it, confirm by selecting Yes or OK. 4 Enter the headset passkey or PIN, 0000.
Regards MaTi_FleSh
Jul 03, 2011 | Samsung WEP200 Wireless Headset
How do i connect my Motorola Bluetooth to my Nokia 6350
Hi
Please follow the Instruction and set your motorola bluetooth in Nokia Phone
    • 1 Press the Menu button on your Nokia phone and select "Settings" from the available options.
    • 2 Select "Connectivity" from the Settings menu and then "Bluetooth" from the menu that appears.
    • 3 Ensure that the first line on the Bluetooth menu says "Bluetooth On." If the line reads "Bluetooth Off," select the line and change the setting to have the Bluetooth powered on.
    • 4 Power on your Motorola headset and put it in discovery mode. Discovery mode is indicated by a solid (non-blinking) blue light on the back of the headset. You can put your headset in discoverable mode by pressing and holding down the "On" button for eight seconds. In the case of a headset with a sliding on/off switch, simply slide the button to the "On" position and hold it there for eight seconds.
    • 5 Select "Search for audio enhanc" from the available options on your Bluetooth menu.
    • 6 Select your Motorola headset from the list of items that appear. Your Nokia phone will list all of the Bluetooth-enabled devices powered on nearby.
    • 7 Enter the passkey for your Motorola headset when prompted. The default passkey for all Motorola headsets is 0000.
    • 8 Start using your headset with your Nokia phone. The two will be permanently connected, with no need to repeat the pairing process in the future.
Read more: How to Connect a Nokia Cell Phone to Motorola Bluetooth ' eHow.com
Jun 07, 2011 | Nokia Cell Phones
How to connect the plantronics explorer 233 ?
  • Make sure your Plantronics Explorer headset is fully charged and turned off.
  • Press and hold the call control button (the button on the face of the headset opposite the earbud) for six seconds. When the light begins flashing blue and red, the headset is now ready for pairing with your phone.
    Select the Menu on your cell phone. Once the menu is displayed, select Settings, then Bluetooth Menu.
  • Select the option to add a new device. This will both turn on Bluetooth capabilities in your phone and put it into a setting known as "Discovery mode." The phone should discover your Plantronics headset automatically and display "XXXPlantronics." ("XXX" represents the model series number, such as "320Plantronics.")
  • Select the Plantronics option on your phone. In many cases, the phone will automatically recognize the headset, but if you are prompted to enter a passkey, proceed to the next step.
  • Enter "0000" if you are prompted for a passkey. Your headset will flash blue once it is successfully paired with your phone. Once paired, the Bluetooth headset will automatically recognize your cell phone each time it is turned on
  • Feb 01, 2011 | Nokia E63 Cell Phone
    How do I get the headsets to work when using system link on xbox 360?
    Hit the ceneter button on your controler, go to the settings blade (to the left), sellect preferences, then voice. Make sure the volume is all the way up and the mute microphone option is not selected, then at the bottom select play through headset.
    Also make sure your headset is on and if it has a volume control on it turn that up.
    If that doesn't work clean the plug on the headset and make sure nothing got stuck in the controler port.
    If none of that works for you, then either your headset is broken/defective or the game you are playing doesn't support voice comunication.
    Good luck.
    Mar 05, 2010 | Microsoft Xbox 360 Console
    Nokia 6085 is stuck on headset-mode. How can I
    try this: get a headset connect it then disconnect it go to settings - profiles - and select another profile. If it doesnt work try to restore factory settings if you dont know the sercurity code it should be 12345 by default
    NB: pls vote
    Oct 24, 2009 | Nokia 6085 Cellular Phone
    I have a Jabra set, but my Motorola Krazer can not find it
    Follow the steps below:
    • Setting the headset into pairing mode
    1) Ensure the headset is fully charged
    2) The headset must be switch off
    3) Press and hold the on button for around 8 seconds until the light flashes red-blue
    4) The headset is now in pairing mode
    • Searching for the headset on the phone
    1) Go to “settings” or “connections”
    2) Select Bluetooth, then options
    3) Select Devices and click add
    4) The phone should search for any available Bluetooth devices and display what was found
    5) Select the Jabra device and click add
    6) You will be required to enter in a pass code which is standard ‘0000’
    7) If successful then the headset will start flashing BLUE every few seconds.
    • The headset is now paired with the phone
    Hope this helps
    Chris (ziraffa)
    Jan 16, 2009 | Jabra BT350 Bluetooth Headset Headset
    HOW TO PAIR MY MOTOROLA H500 TO SAMSUNG CELL PHONE?
    If you have lost the pairing on your phone with the headset follow these simple steps below:
    3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
    5) Select the Motorola device and click add
    6) You will be required to enter in a pass code which is standard ‘0000’.
    8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
    Hope this helps
    Chris (ziraffa)
    Dec 26, 2008 | Motorola Mobility Bluetooth Hands Free...
    Bluetooth pairing
    Try the following:
    a) Options->Bluetooth->Enable Bluetooth
    b) switched on the Moto headset (blue light blinking)
    c) options->bluetooth->add device
    d) searching for devices....---> here it should find the headset and pair....
    If it does not work do the following
    After doing the above, do the following:
    e). Start the headset. Start with the headset powered off, and hold the Call button for 10 seconds or so, until the light stays on. (Initially, the light will flash a few times before getting steady.) If the light is flashing, or if the light starts flashing anytime during steps f) through g), the headset is not in pairing mode, and this step (step e) must be repeated, again starting with headset powered off.
    Select the Headset:
    f.) Go back to phone, and select "[Look for Devices]." The phone starts searching for Bluetooth devices.
    g). Once phone is finished searching, you get a list of one or more devices under the heading "Scan Results." Select the headset.
    h). The next screen will read "Bond With ..headset." Select "Yes."
    i). The next screen will be "Enter Bluetooth Passkey." Enter 0000 and select "OK." A screen will confirm pairing and connection. When the pairing is complete, the light on the headset will flash.
    Sep 13, 2008 | Cell Phones
    Phone
    more info needed
    Mar 23, 2008 | Motorola Mobility RAZR V3
    Cell Phones Logo
    180 people viewed this question
    Top Cell Phones Experts
    Computer Repairing
    Computer Repairing
    William Alequin
    Are you a Cell Phone Expert? Answer questions, earn points and help others
