Is your washer plugged into a groundfault receptacle if it is and the ground fault receptacle is tripping you need to use less soap in your washing machine or change the receptacle to a non ground fault like a regular 120 V receptacle. the suds are coming down the side of the washer inside and getting some of the electronics Damp and that is tripping out the ground fault receptacle.
most I have ever seen have slots in the sheet metal that tabs fit into like slide loc tabs.. this requires sliding the face up or down on the sides.. that may help..these are locked by internal screws that you can take out from tne inside ..
Yes your washing machine is trying to tell you something-somethings wrong-are there any flashing lights while the beeps are happening-also do you have the owners manual-this is always a good place to start-cheers Denny
Remove rear panel completely from washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic filter inside the hose.
Hi Friend,
welcome to fixya....
may be the drum belt is the fault, Here are some possible causes of a washing machine belt coming off :-
1.The drum pulley is loose
2.The drum bearings have gone (collapsed) causing the drum pulley to wobble
3.The drive belt was to slack
4.A motor fixing bolt or bracket securing the motor to the tub has broken or come loose
5.Water has got onto the belt causing slippage
6.An obstruction or item of clothing temporarily jammed the drum causing the belt to spin off ,,,,,,,,,,,,
first check whether it is hard to turn the drum if not then check the above situations,,,ok
if you think that i helped you please rate it\\\\\\\\
