Question about HP DesignJet 100 Plus InkJet Printer
Hp designjet 100plus
I have a hp designjet 100plus that has no display but I can see that there is power as there is a green LED on from the main logic board
Paste this address in your browser, you should get some help there.
http://welcome.hp.com/country/us/en/support.html?pageDisplay=support
Posted on Jul 17, 2008
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
0B0007
The error code means the vacuum fan is not detected.
Replace the vacuum fan. If that does not fix the problem, replace the Main Logic board. The fan can be ordered from: Designjet 5000 5500 Vacuum Fan and the PCA from: HP Designjet 5000 5500 parts
Jun 26, 2014 | HP DesignJet 1050c plus InkJet Printer
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
Why my printer hp designjet 100plus can't printed or not responding..
Firstly take test print from the printer test print button, if it is okay, then check your USB cable which is connected to your Pc.
Aug 19, 2011 | HP DesignJet 100 Plus InkJet Printer
My Hp Designjet T1120 fails to initialize. When mains is switched ON the Front Display Panel in the plooter illuminate without any display and the Power switch in the display panel flickers with green...
Reset the formatter & check,,
Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part.. 11_19_2011_3_40_14_pm.jpg
Oct 11, 2010 | HP DESIGNJET T1120 44 Printer
Won't initialize, leds on blank display
No led lights mean no 5 volts. 5 volts run all the logic. Check power from the wall, replace the power supply.
Jun 26, 2009 | HP Designjet 1050 Printer
Designjet 110 plus not turn on
do you change formater board ?or try use firmware utilit you can find it here
http://h10088.www1.hp.com/cda/gap/display/main/gap_home.jsp?cp=1_4011_100&zn=gap
Sep 22, 2008 | HP Designjet 110plus nr InkJet Printer
My philips 42PF 7320A/37 has not been working for the past year. it will work for a few months, then the picture will go black and the light on the tv will blink about 7times. this plasma is only 2yrs. old...
This what to do measure from the logic board which is located under the small signal board and have the AV jacks connected to it. If the voltage is 3.1 or close the problem is with the power supply or a board connected to the power supply. Unplug the set. Disconnect the Y main board first that will be on the left side of the set facing the back. Plug the set back in if the led is solid replace the Y main and the Y upper lower. If still blinking plug the Y main back in and unplug the X main which is on the right side facing the back. If the led is green replace the X main. If the led is still blinking replace the power supply.
But if the volts are 0 the problem is the SSB or the logic board. In that case take the (SSB) small signal board out the set and place 1 jumper on J8003 and another jumper J8004 of the left side of the power supply. Then place 1 jumper on CN2072 of the lower left part of the logic board. Plug the set back in if the set displays a white, blue et c screen replace the SSB. If not and on the logic board you don't have 1 solid blue led and 1 blinking led data is not flowing and change the logic board.
Jan 04, 2018 | Philips Televison & Video
Philips 42PF7320A/37 won't power up Led blinks 7 times
This what to do measure from the logic board which is located under the small signal board and have the AV jacks connected to it. If the voltage is 3.1 or close the problem is with the power supply or a boar connected to the power supply. Unplug the set. Disconnect the Y main board first that will be on the left side of the set facing the back. Plug the set back in if the led is solid replace the Y main and the Y upper lower. If still blinking plug the Y main back in and unplug the X main which is on the right side facing the back. If the led is green replace the X main. If the led is still blinking replace the power supply.
But if the volts are 0 the problem is the SSB or the logic board. In that case take the (SSB) small signal board out the set and place 1 jumper on J8003 and another jumper J8004 of the left side of the power supply. Then place 1 jumper on CN2072 of the lower left part of the logic board. Plug the set back in if the set displays a white, blue ect screen replace the SSB. If not and on the logic board you don't have 1 solid blue led and 1 blinking led data is not flowing and change the logic board.
Dec 13, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
HP DesignJet 100 Plus InkJet Printer Logo
386 people viewed this question
Ben Johnson
