Question about Sharp AR-M160 Laser Printer
Ch error Sharp ar-m160: its indicator screen displays "ch" what does it mean?
  • mobin728 Nov 01, 2008
    Hi
    thank you
    it was helpful
  • Anonymous Apr 14, 2009
    ch on display
    New Friend:
  • 4 Answers
CH ON = Side door open
CH Blink = Developing cartridge not installed
Posted on Jan 01, 2013
Some of the covers of the machine might be open.
Regards,
Cäppärs
Posted on Oct 30, 2008
HOW DO I CORRECT "CH"ERROR ON MY AR-M160?
may be Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality
Feb 23, 2015 | Sharp AR-M160 Laser Printer
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
Jun 01, 2011 | Sharp AR-M160 Laser Printer
I have 3 sharp printers arm160 and have 2 errors. Ch & L1 adn anyone tell me what they mean? Thanks
ch-
1.side door open
2.developing cartridge not installed
L1-
scanner feed trouble
May 15, 2010 | Sharp AR-M160 Laser Printer
My printer blanking "ch"
Check the correct instalation of the developing unit.
Jan 28, 2010 | Sharp AR-M160 Laser Printer
Ar-5316 showing error ch
CH steady means cover is open. Close either front or right cover well.
CH blinking means developer unit or toner cartridge not installed. Remove and return well and firmly.
Nov 22, 2009 | Sharp AR-5316 Advanced Digital Imager...
Our Sharp AR-N275 copier is displaying error code "CH" (steady, not blinking). What does it mean?
Hello sir; CH it means somewhere the door is open, check it out all the door inside and outside.
Sep 30, 2009 | Sharp AR-N275 Copier
Sharp AR-M160 H4 error code
Clearing a trouble code on a AR-M160 is a little different than the AR160.
Try "#" "interrupt" "clear" "interupt" "1" "4" "start key"
This should clear the error. Even if you replace the fusion unit you will need this code to clear the error
Oct 26, 2008 | Sharp AR-M160 Laser Printer
L 6
L6 error on AR-M160 - Polygon motor problem.
I would suggest repairman service for this one as it requires stripping the unit down.
Try reseting the error first though.
"#" "interupt" "clear" "interupt" "1" "4" "start key"
Jul 02, 2008 | Sharp AR-M160 Laser Printer
U 2 error on my Sharp AR M160 copier
U2 is normally a user error (hence U) check that all the doors are closed fully and just recheck the toner installation. If this is all correct it might be a slight possibility that the toner cart is faulty.
Thanks J
Feb 20, 2008 | Sharp AR-M160 Laser Printer
Sharp AR-M160 Laser Printer Logo
604 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
