Convergence Have a Sony KP-48S70, and the convergence is off and will not autofocus/autoalign. Appears as a red "ghost" image approximately 2.5" off to the right horizontally. I have tried to enter service mode with remote, but I do not have the original remote, I have a GE universal learning remote. Can this be adjusted manually, and do I need the original remote??
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 140 Answers
You need a remote that can produce the "DISPLAY" button on the Sony remote in order to get in service mode....(you could also carefully move the centering rings on the red CRT to line it up with the green CRT)
Posted on Jul 18, 2008
Double image red ghosting
Thats a common problem caused by failed convergence ICs and pico fuses. Your model uses the Sony type 1 convergence repair kit which is available from www.tvrepairworld.com which contains the parts and the CD with detailed repair instructions.
Aug 27, 2011 | Sony KP-51WS500 51" Rear Projection...
I have a 48" sony projection with a rainbow comming down from the top
You have convergence circuit failure. Convergence IC's have to be replaced and probably some PICO fuses that soldered on the same board. This repair require good soldering skills.
Mar 09, 2010 | Sony KP-48S70 48" Rear Projection...
My sony KP-51WS500 is having ghosting problems with kind of 3D image with the three colors showing seperate image lines. How do I fix this and what is the cost.
Shop cost u about $300.Ur convergence is dead,U know how to solders.?Buy a convergence kit to repair.Tries websites. Tv repair World.com,Tv repair Kits.
Dec 12, 2009 | Sony KP-51WS500 51" Rear Projection...
Green projection light not alligning with red and blue. Flash focus will not bring them back. Sony Rear Projection KP-48S70
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Note:The convergence/defletion/power board (the one the IC's are on) of this model is on the left hand side (when facing the back of set) also check for blown pico fuses when replacing the convergence IC's The best way to replace the IC's resistors and possibly fuses is to remove the entire board.
Oct 19, 2009 | Sony KP-48S70 48" Rear Projection...
Red horizontal lines on the screen
do these appear around the images on the screen? look like a horizontal ghost around the image. if so you have lost horiz.convergence on the red. you might try a auto convergence setup in the menu on most rear proj. tv's if this dosent work then you need to try and find a shop.
Jun 27, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
My colors wont stay converged
put a convergence repair kit in the set that will usually repair the Issue. You can get the Sony convergence repair kit which works with your model at the following link. The kits contain the replacement parts and complete instructions www.tvrepairkits.net
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Ghost shadows on the Sony KP-46WT500TV
you can get the KP46WT510 convergence repair kit at the following link under convergence repair kits category which will also work for your model.
http://servicemanuals.vstore.ca/
Apr 12, 2009 | Sony KP-46WT500 46" Rear Projection...
Red line convergence problem on KP-57WS510
Yes replacing the ic's should solve it. It worth a try if you want to spend the money
Jun 02, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
The red convergence is off
replace the convergence ICs post your model and I will post a link where you can get the parts and they include step by step instructions with pictures so you can do the repair yourself takes an hour and will save you about a 400 dollar repair bill.
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Televison & Video Logo
101 people viewed this question
Top Televison & Video Experts
Electro Med Services...
