Question about Symphonic SL260A S-VHS VCR
Video got stuck
My video got stuck. so i opened up the vcr and found this??? where does it go?
I'm not sure where this goes, but try this website....they have troubleshooting tips and a schematic for the inner workings of various VCR's. It might be able to help you identify the part. Categories are even sorted in a database by Brand and Model Number.
Hope this helps.
Posted on Jul 17, 2008
How to remove a VHS that is stuck in the VCR?
You really have to open the VCR. But you have to know how to turn and move things, so the damaged tape can come out, without damaging the tape mechanism. It is not even in a user manual, but once you know how to do it, you can use the same trick innermost any VCR. To complicated to explain in words, Check if you can find a Youtube video or something on
Dec 31, 2014 | Televison & Video
Videotape dubbing deck dead
1. Check to see if a tape is jammed inside (see 284 Extract a Jammed Videotape).
2. Try changing the video input and/or output source. Many VCRs have two ways to receive and send a video signal (coaxial and video direct). If that works, try changing the cable for the other method to see whether you need a new cable.
3. Clean tape heads (see How to Clean VCR Heads).
4. Open VCR and inspect any belts that are accessible (see 284 Extract a Jammed Videotape). A drive belt may be broken or loose.
If tapes are getting stuck / enmeshed inside the machine, itis 90% probability) a mechanical problem. Change the Belts, clean all rollers, idlers, and braking pads.
I would suggest that you also replace the Capstan Pinch Roller.
Feb 17, 2008 | Rio Go Video DDV9556 Dual Deck VCR
Put in tape and vcr fast forwards
something maybe broken on the inside for it to say play but fast forward. the botton could be stuck as well. maybe open the vcr and clean it all up in side. that might help
May 11, 2012 | Panasonic Pv-9661 Omnivision 4-head Hi-fi...
I have a vhs video cassette stuck inside my vhs. Is their any way I can get it out without breaking the vcr. It is an older vcr, but I would like to get my tape out.
You might be able to unbolt the two halves of the VCR to remove the tape, but it depends on the VCR type and how it's stuck. You might end up having to get it serviced, or just getting a new VCR, as I can almost guarantee the tape is probably damaged beyond recovery, unfortunately.
Mar 16, 2011 | Video Game Consoles & Games
How can I get my DVD to get unstuck out of my VCR/DVD player?
I can't get any support from sansui. I think your DVD player is trying to read the disk. It can't and its stuck in DVD mode. This is just something I would try I don't know if it will work. Unplug the power source hold down the eject button and plug it back in. The objective is to try to get it to spit that disk out before it has a chance to try to read it.I hope this helps. If it does give me a vote and I'll know it worked.
Mar 04, 2010 | Sansui VRDVD4001 DVD Player/VCR
Diamond Multimedia ( VC500) Video Capture After I installed the program files from the disc and set up all the three cables for the audio and video, everything is hooked on right and tight but once I plug...
I was having this problem also. I originally plugged my 3 video cables into the VCR outlets in the front of the vcr. I finally turned the vcr around and found two other sets of video out plugs. One was to a dvd/dvr and the other was a vcr out. I took the plugs from the front of the vcr and plugged it into the dvd/dvr out and it worked! Good luck with your problem. Hope the resolution is just as simple.
Mar 16, 2009 | Diamond Multimedia ( VC500) Video Capture
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
Neither deck will open to insert tapes in my dual deck vcr
It seems they didnt refirbish it, you should return it..
If for some reason you cant return it.
The problem is your carriage unit is damaged
The carriage unit is the parts that load the tape into the vcr
If you think you are able you can open it up and look if any springs have fallen out. If not then change the unit.
If you cant fix it your self a technician can easily do it for you since it isnt that hard and somplicated to repair, you just need good retainence
Dec 01, 2007 | JVC SR-V10U S-VHS VCR
VCR stops, ejects, eats tapes
clean the heads and retime the gears.
Nov 24, 2007 | Symphonic WF802
Cassette stuck in video
I am a sanyo VCR technician and i will share to you what i had encountered. the problem of your VCR is in the mechanism "slide front" unable to push out the ejector portion of the tape. If you can locate this part just push it so that the tape will eject.
Aug 28, 2006 | Philips VR630 VHS VCR
Symphonic SL260A S-VHS VCR Logo
98 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
