Question about HP Office Equipment & Supplies
I can not print and the empty sign stays on my printer when still loaded A4 paper. I keep getting PRINT CARTRIDGE ERROR on my PC. My printer HP PSC 1400
  • 477 Answers
Is the Print Cartridge in right place? I think you should contact HP service. It can help to change the cartridge.
Posted on Jul 17, 2008
My HP psc1315 will not turn on. Some of the
To be able to understand the problem, you should give extra info about the lights.
Please find the information below about the status lights that provide information about error conditions of your printer. But first you need to install the driver for your operating system. The drivers are necessary to print documents and scan images. These drivers must be installed to use the print and scan features.
If the On light, Check Print Cartridge light, Check Paper light, and Start Copy, Black and Start Copy, Color lights are all flashing, do the following:
1 Verify that the front-panel overlay is attached to the HP PSC.
2 Turn your HP PSC off and on by disconnecting the power cord and reconnecting.
Problem 1: “ON” light is on, “check paper” light is blinking and “check print cartridge light” is off .
Explanation 1: The paper tray is empty, the HP psc has a paper jam, or the paper size setting and paper in paper tray are not the same.
Solution 1:
• Load paper, or remove thepaper jam.
• Change paper in paper tray to correct size.
• Change paper size on the computer software.
Then press On/ Resume to continue.
NOT : PLS SEE THE NEXT MESSAGE. CONTINUED AS THE COMMENTS BELOW:
Mar 31, 2010 | HP PSC 1315 All-In-One InkJet Printer
My printer HP PCS 1400 All-in.one The E sign stays on the printer is loaded with A4 paper and I keep getting print cartridge error.
E sign on the printer lcd? Can you be more spesific as to what else the display is showing then E, e and a error code?
Thanks.
Jul 17, 2008 | HP Office Equipment & Supplies
Have error message saying paper is to narrow, load wider paper and press enter, A4 is loaded print options are set to upper tray A4, paper is loaded, cannot clear message
Hello.
That message is indicating that there is a problem with the cartridge alignment.
From HP:There are several reasons why the HP All-in-One may fail to align the cartridges. The most common reason is an ink cartridge that has one of the following problems:
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • The paper has already been printed on or is colored paper.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The ink cartridge is defective.
Also, use a fresh piece of paper that has never been printed on for the alignment process or the alignment will fail.
Hope this helps.
Dec 01, 2009 | HP PSC 950 All-In-One InkJet Printer
The print cartridges are not moving correctly, the sound "rough" "bumpy" and the error "print cartridge jam" keeps coming up. Nothing appears to be wrong when I look at them... and the print keeps saying...
Greetings,
Before you making any assumptions about whether or not a cartridge is good or bad, always clean the cartridge and carriage electrical contacts with a cotton swab and alcohol.
HP holds the patents on their cartridge technology. They are not about to share their cash-cow with anyone. All non HP branded cartridges are remanufactured unless someone is counterfeiting them in China.
Regards,
TechSup1
May 01, 2009 | HP PSC 1600 InkJet Printer
Hp2210 message ''press enter to align cartridges'',
from user manual::
To align newly installed print cartridges
1. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
The HP All-in-One prints a print cartridge alignment sheet.
NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
If the alignment fails again, you might have a defective sensor or print cartridge.
Contact HP Support. Go to www.hp.com/support. ....
2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left.
3. Press the Scan button.
The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet
Score the solution and download the manual if you need it
Mar 24, 2009 | HP PSC 2210 All-In-One InkJet Printer
Check ink cartridge
Your ink cartridges could be dried up or empty, even if they are new.
Jan 20, 2009 | HP PSC 1210 All-In-One InkJet Printer
Hp psc 1219
dear szaszy
as per your information your printer paper jam sensor is having problem.Please get it serviced
Apr 04, 2008 | Office Equipment & Supplies
HP2355 PSC
printer will not copy or print but takes in paper - it shoots it straight out but stops half way - we then have to press OK for the paper to be ejected.
The size of the paper makes no difference and it continues to take in pages even after the print has been cancelled - help
Feb 03, 2008 | HP PSC 2355 All-In-One InkJet Printer
Hp psc 1219
try pressing repeatitivly the red cancel button
Apr 16, 2007 | HP PSC 1210v All-In-One InkJet Printer
Problem with ink cartridge
There is something broke with the piece that keeps it in place. You need to take it out and look real close to how it works. Look at how the color works and compare the two.
Sep 23, 2006 | HP PSC 1610v All-in-One Printer
129 people viewed this question
Ben Johnson
