Question about Asrock K7VM4 Motherboard
Startup Issues with K7VM4
I've been asked to look at a PC (with the K7VM4 motherboard) which wouldn't start up. Numerous attempts failed and I eventually reinstalled Windows after swapping the memory for some known working DIMMS (same spec) from a different PC.. All is then fine at this point. All Windows updates were installed fine etc. However, I swapped the memory back to confirm that it was at fault and the PC either got halfway through startup and restarted or came up with the blank screen everyone else describes. My query is that when I put the known working memory back in, the problem persists until I reinstall Windows again. If this is the case, I can't nail it down to a memory fault can I? Any other suggestions before I replace the M/B?
  • Kevin Shafer
    Kevin Shafer May 11, 2010
    Yes, it is true. Rare, but true. Probably moreso on older systems though as it was an older system I had that happen to me on once.
  • Filip Eastman May 11, 2010
    before you change m/b I think you should try this memtest.
    download it, unzip it and burn the iso file to a cd. then boot the computer with the CD and a test of your memory will appear. if you dont get any error in a half, to an hour your memory is fine.
    http://www.memtest86.com/memtest86-3.4a....
  • 477 Answers
I have seen alot of computer with fault ram that messed up the OS.
Posted on Jul 17, 2008
    Sergeant:
  • 287 Answers
Yep ... memtest would be a good place to start. never seen faulty RAM corrupt the OS before though!
  • Dave Jul 17, 2008
    learn something every day :-)
Message on screen: Windows failed to start. A recent hardware... It then cuts to startup repair and attempting repairs. Have gone through this a dozen times only to end up where I started. What do I...
I assume you've already tried pressing F8 on startup to get into the start-up options screen (from there you can attempt "Restore System to a previous date.").
If you can't get anywhere with the F8 options, try starting up your system from a Windows Install disk. (Unfortunately, few computers come with this. Some have a Restore mode using either a special startup hot key or a set of optical disks, but this usually involves formatting C: and wiping out everything before setting it back to factory original state.) Once you have the Windows Install disk going, watch for the Automatic System Repair option to come up. This is different for each version of Windows, so I can't give you more than that other than to follow the on-screen instructions.
Note: virus infections can disrupt the hardware registry and produce the symptoms you have. By now, your backup registry is corrupted (that is why the automatic repair fails). I've found the easiest virus fix for a desktop computer is to remove the hard drive and install it as a second drive in a known-good computer, then have that system scan the problem drive for virus infections and file system corruption. If you have a 2.5" - 3.5" drive adapter and can remove the drive easily, you can also use this tactic on laptop hard drives. You will probably still need to repair the operating system damage.
Nov 14, 2011 | Computers & Internet
What is U16 on K7VM4 Rev. 1.03 MoBo?
Changing the CD54/74HCT365. M is rated 25 on quality and MT is 100 and M96 is 2500 and probably cost a little more too. But, what bothers me is that something else could be wrong and driving it to burn up? Asrock k7vm4 Rev. 1.03 16 Ghz and K7VM4 is the BIOS
Sep 16, 2009 | Asrock K7VM4 Motherboard
When i burn cd or copy paste something or during playing games a blue screen comes saying physical dump of memory?plzzzzzzzz anyone give me solution.
There seems to be a memory problem on your PC, you might need to replace your memory modules, please check if you have low latency memory since that type of memory needs a voltage adjustment made in the motherboard startup Bios to work correctly.
But first you can try opening windows CONTROL PANEL / SYSTEM look at the ADVANCED tab and click on the SETTINGS button at the STARTUP and RECOVERY section, a new window will pop up and select (NONE) at the WRITE DEBUGGING section in that window. And see if it gets better, if not try deselecting the 3 options above this write debugging section. All this is safe to do, if it works it works, if it doesn't nothing happens.
Jan 03, 2009 | Asrock K7VM4 Motherboard
Video failure
hi.....
you will face this kind of display problem if the video adapter IC(integrated circuit ) is dead or if it is getting over heated in the short time in the motherboard ...
you just have to do is you must replace that video adapter IC ...
just contact the motherboard technician and get that IC replaced ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 11, 2008 | Asrock K7VM4 Motherboard
ASRock K7VM4
Your list of suspects:
1. Processor is cold dead.
2. Power Supply has got a problem. Just powering a fan is not a guarantee that it is powering everything normaly. Try a different one as you test agai.
3. I suspect your MoBo is good, but try a different video card also with your new DDR.
4. Do you hear the HDD cranking or whining when you turn on the PC? Keep ear near HDD and listen. It it whine-starts, it's a fair sign.
5. Try a different monitor while you test these.
Let us know what you find in clear detail.
Mar 03, 2008 | Asrock K7VM4 Motherboard
Cpu fan error
POST troubleshooting steps. If a fan has failed (especially the heat sink fan for the CPU)
Good Luck, Please dont for get to Vote.Thank you.
Dec 16, 2007 | HP Pavilion dv1000 Notebook
LG RH1999H DVD Recorder
I did try removing the Hard Disk from the recorder and did a diagnostic and fix-disk using Ontrack software. Ontrack showed no structural and physical defects on the hard disk. I replaced the hard disk in the recorded and guess what! Please wait, please wait, please wait, please wait...................................
Nov 06, 2007 | Televison & Video
Graphics proble wihle working in 3D modeling software
in BIOS recheck your graphics MB capability. In windows, recheck everything in performance, let's be real that's an old board. try updating your graphics driver.
Sep 07, 2007 | Asrock K7VM4 Motherboard
Graphics problem
Hi, could you please give us more information. Are you using onboard graphics or a graphics card and if a card what type and capacity? Regards mistyman
Asrock K7VM4 Motherboard Logo
78 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
