Televison & Video Logo
Anonymous Posted on Jul 17, 2008
System error found Divio Fusion hdtv Software dvb-t version 3.68
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
58
Points
Solution:- Re set drivers off the Divio Web Site,the installation disk that came with the product was out of date being an earlier version.
Two attempts were made to install new up dated drivers,incorrect product description was selected from off the list at first before correct description in the 3.68 version was selected
globalpage
tip
SELF DIAGNOSING SERVICE MODE AND POWER SUPPLY CIRCUIT
SONY KDL-32EX302 SELF DIAGNOSING SERVICE MODE AND POWER SUPPLY CIRCUIT
SELF DIAGNOSTIC SOFTWARE
The identification of errors within the AZ1-N chassis is triggered in one of two ways :- 1: Busy or 2: Device failure to respond to IIC. In the event of one of these situations arising the software will fist try to release the bus if busy (Failure to do so will report with a continuous flashing LED) and then communicate with each device in turn to establish if a device is faulty. If a device is found to be faulty the relevant device number will be displayed through the LED.
For more check the following link. Use the search tab on the top right corner to find your product .
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
How to install ubuntu linux apple macbook pro notebook
Safest option would be to purchase a specialised virtualisation software product like paralleles Parallels Desktop 9 for Mac The 1 choice of customers worldwide to run. OR Fusion http://www.vmware.com/au/products/fusion
then download an .iso which is a cd image of Ubuntu
http://www.ubuntu.com/download/desktop/burn-a-dvd-on-mac-osx
the LTS version of Ubuntu stands for long term support, the version that
will most likely work on your mac will be the 64bit version.
I would suggest using a virtualisation program rather than replacing the
mac operating system so that you can be running both mac os and ubuntu
at the same time, without having to shutdown one to access the other.
Hopr this helps.
Webcam drivers
You can get the drivers from the disc that came with your computer or you can go to the website of the manufacturer. If you want to update the driver, then I suggest that you use RadarSync so that you can make sure that you will get the correct driver update.
I hope this helps!
David
2helpful
Location/ 0n the xp kundali-2009 software show Run-time error '53':
"Runtime error '53': File not found (your file.dll)".
It means that one or more files expected by windows to be in place in a specific location and needed to run the application is either missing, not installed or corrupted.
To solve Runtime Error 53 to ensure that your software or hardware runs smoothly as planned.
The easiest method would uninstall of the relevant software or hardware followed by a reinstallation.
Go to the "Control Panel" menu found on your Windows "Start" menu. Click on "Control Panel" before clicking on the "Add/Remove Program" options found there.
Clean up your PC with the free cleaner ie CCleaner before reinstalling your software.
Check out the version of your installed software before going over the product's homepage to see if that particular version is the latest.
However, in the event that such a method does not work, it would be a good idea to contact the company from which you purchased our hardware or software for technical assistance.
Hope it helps.
When I try to open design enhancer I get an error
This error can appear when you attempt to start 4D software. This will happen if you have installed any version 8.0 4D software, and the 4D Embroidery System software that is already installed has a later version than your 4D software.
If you have a CD (or DVD) containing 4D Embroidery System Software for version 8.1 or later, install the update for the 4D Embroidery System found in the Patch folder on the CD (or DVD).
If you have updated your 4D Embroidery System to version 8.1 or later using an update obtained with Smart Update, find the update you have already downloaded and run it again.
If you are unable to find the update, or you are not sure if you have the latest update, use Smart Update to obtain the latest update, as described in CC007.
When you run the update, you may be asked to choose between Modify, Repair and Remove. This selection appears because you have updated on a previous occasion. Choose the Repair option, and this will ensure all your 4D Embroidery System software is updated.
BOOT CAMP SEEMS TO BE UNSTABLE WITH MY APPLICATIONS
This is a not a Boot Camp - but a cheap way to get Fusion V.2 which is the best run-XP-and-OSX-both-at-one-time program.
1.  Do NOT use Parallels software b/c it is slow, clunky, and a memory hog - this is experience speaking :)
2.  get a USED copy of VMWare Fusion VERSION 1 (this is not the newest version - but hold on!) from ebay/Amazon whatever - but don't pay over 20.00 (I paid 17.95 shipping included)!
3.  Install the older (version 1)  VMWare Fusion and then go to the VMWare Fusion website to get a free download of Version 2.  They offered this free to all owners of version 1.
Now something to think about.  When I had VMWare Fusion 1 on my machine, it literally took 3 seconds to load Windows XP (and some people wonder why I have a Mac!).  Upon installing version 2, it takes 10 seconds - and I do not know why!
BTW - make sure this free update is still available http://www.vmware.com/products/fusion/
This works b/c a lot of surplus V1's are being sold cheap.  It is s totally legit option b/c the company is offering to any legit owners of version 1.
Bought DVB-T& Analog tv USB stick and it is now asking fpr Windows Vista software version to run.
Which operating system are you using?
Which Digital TV USB stick are you using?
It may be that you need to download an updated driver.
4helpful
4answers
Dvb-s 100 problem
salut
prodlem de dvb-s 100 avec win xp
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
