Question about JVC Car Audio & Video
Radio blue tooth drops out after 10 min. reset and same thing happens after 10 min
  • 109 Answers
What kind of phone, headset or radio, etc are you using. If you send me more info I may be able to help you with your problem.
Posted on Jul 17, 2008
The radio in my 2012 Toyota Sienna XLE stopped playing and will not start back up. It gives a flash of sound when you turn on the key and then goes silent.
I, feel sorry for you, after reading your problem, but don't worry you visit the Reliable-Store they will help you for sure.
Best Manuals
Sep 30, 2016 | Toyota Sienna Cars & Trucks
How can hooked my cell to radio
you cant. Buy a cobra 29 cb radio with blue tooth. This radio will allow you to interface your cell to the radio via the blue tooth.
Jul 21, 2015 | Radio Communications
WHY DIESNT MY RADIO LINK UP TO MY BLUE TOOTH PHOEN IN MY CAR?
obvious question , sorry , have you got the radio hand book to follow the set up procedure , sometimes the bluetooth will only accept a certain amount of connections and then needs to be reset , otherwise might be a question for I phone
Jun 11, 2015 | 2008 Toyota Tundra Double
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
Can i use my plantronics 230 bluetooth for my blackberry phone?
Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
How to pair a phone to a blue tooth device?
Instructions
Pair Your Blackberry with a Blue-tooth Headset
Turn on Blue-tooth headset and Blackberry hand-held.
Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
Use your Blue-tooth Headset with your Blackberry
Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
Press the on/off button on your headset to end a call or use the end button on the hand held.
Tips & Warnings
Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
What happens when it says network unavailable when im tryin to send a multimedia text, but i am able to send texts though.
your blue tooth device must be the problem. reset blue tooth device settings if still not possible have to change.
Jul 26, 2009 | Motorola Mobility RAZR V3
Bluetooth setup
are you in USA?
if yes, why use such and old device here.
its mostly useless now. with no support.
my guess is out of memory , remove programs to free up memory.
or it needs larger memory,, buy more?
why not ask in a REAL HP forum ?
id love to hear what good this thing can do in 2017....
https://h30434.www3.hp.com/
Jun 07, 2017 | HP iPAQ H2210 Pocket PC
Wireless radio adapter or card
Try:
G1S - This laptop supports multimodal switching of the wireless and Blue Tooth radios via the key command Fn+F2:
1st press: On both Blue Tooth & WiFi
2nd press: Off Blue Tooth / On WiFi
3rd press: On Blue Tooth / Off WiFi
4th press: Off both Blue Tooth & WiFi
Sep 14, 2008 | ASUS (wifibralinkuay) 802.11b Wireless...
GES050
unplus the radio and take out the batteries for like 10 min...once the machine resets the alarm will stop going off. The same thing happened to mine and this solved it.
May 01, 2008 | Audio Players & Recorders
Car Audio & Video Logo
21 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
