How to insert printer cartridge? - Office Equipment & Supplies
  • scohen53 Aug 05, 2008
    My cartridge will not stay in slot
  • Anonymous Feb 24, 2009
    How to insert an HP 2840 printer caridge?
HP Deskjet 3920
Posted on Jul 17, 2008
I disconnect the USB cable and remove the cartridges but I don't receive the message for inserting cartridges!
Remove both cartridges in power off condition, power on it chk for the message, once printer detects both cartridges are missing, lift cartridge access door insert one cartridge, close the door & allow printer to detect the inserted cartridge, do the same for the second one also..
USB cable no way related with hard ware issues..
May 12, 2014 | HP OfficeJet 6210 All-In-One InkJet...
Hi, there is a toner cartridge inserted on my prin...
Either toner cartridge faulty or printer detected non-genuine toner cartridge.
May 21, 2010 | Canon LASER SHOT LBP-2900 Printer
How do i insert cadrige
Turn the orinter off and follow these steps:
1) Remove the top cover by opening the top of the printer
2) Pull the older tone cartrige out, taking care of noticing how it is inserted into the printer.
3) Insert the NEW cartridge
4) Close the printer cover
Mar 31, 2010 | Samsung ML 2010 Laser Printer
Ink cartrridge
its very siple.lift the front cover of the printer.then insert the cartyridges in the printer a carriage will automatically come into the position where you can insert the cartridge.just keep the printer ON.AND LIFT THE COVER.ALSO where black is inserted there it will be written B.and where colour is inserted there it will be written C.as the circuit of the cartridge should nmatch the circuit in the printer.and slowly push the cartridge in the cartridge holder the carriage.as when it gets fitted you will hear a noise click.
Feb 26, 2009 | Canon PIXMA MP190 All-In-One InkJet...
Cartridge error - printer doesn't recognise cartridge inserted.
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 24, 2009 | HP Officejet 6310 All-In-One InkJet...
Where does the ink cartridge go?
u just have to ON the printer.
and then just lift the printer cover and the cartridge carriage will move automatically and will stop at the position where u can replace the cartridges.u just have to insert the cartridges in proper place as the old cartridges r already inserted.do not remove all the cartridges together just remove 1 and insert 1.
thanks.
Oct 26, 2008 | Canon MP610 Photo All-In-One Printer
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Error check ink cartridge
Hi ,
As per the information provided by you it seems to be a hardware issue however u cvan try these steps .
Steps >
Take out the ink cartridges from the printer > without turning off the printer unplug the power cord > press # and 6 key together , now without releasing the keys plug in the power cord .
keep on holding the keys down until the machine turns off automatically .
after the unit turns on again it would do the allignment give a msg for insert ink cartridges . insert the cartridges at that time . and see how it works out .
Thanks
MAC.
May 24, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Remove and check colour cartridge HP 23, HpPSC500 error
Did you trying cleaning the cartridge contacts on your machine?
Jun 23, 2007 | HP PSC 500 All-In-One Printer
1,034 people viewed this question
