Question about AOpen (O35G)
AOPen O35g to usb port
I have purchased a new computer, running Windows XP-Pro, SP3, that accepts only USB mouse input. I have purchased a PS2-USB adapter to plug in my old O35g mouse, but when I install the driver, the AOpen Wheelworks software will not run. I like the mouse, and would like to have the 4-button, 2-wheel functionality. Is this a function of the USB port, and if so, is there any way around it?
  • 781 Answers
Sometimes adapters do not work.
this might work
start computer without mouse. you may have to work with keyboard tab key as you press tab key you should see the icons highlighted install drivers plug in mouse to usb if lucky O/S will recognize mouse and setup
Posted on Jul 17, 2008
How do I connect a usb mouse and keyboard to ps2 kvm switch?
usb to ps2 converter, the sell them for like 30$ but you can go to radioshack and buy a keyboard for that with the little adapter
Mar 30, 2013 | Belkin F1DL102P 2-port KVM Switch
Tip
USB devices not recognised or not working properly?
Try these steps to reinitialize your usb ports on your pc
1. Unplug ALL USB devices connected to the computer. If you are using a USB mouse and keyboard, temporarily use the older type PS/2 devices if you have them, if you don't then just leave them connected.
2. Hold down the windows key and press r
3. Type devmgmt.msc into the run menu and press ok
4. Click on the + sign next to the Universal Serial Bus Controllers
5. You might need another mouse to do this if you have a usb mouse.. I recommend you get a ps2 connector mouse which goes into the green round connector in the back of your pc.
6. Right click and uninstall first the usb root hubs. all of them then uninstall the rest of the devices you see under Universal serial bus controllers
7. Ones you have uninstalled everything you should see the Universal serial bus controllers there at all.
8. Now go ahead and restart your pc.
9. Ones you have restarted the pc your usb ports will reinstall in a moment stand by while it installs all of them. If you get warning messages click ok or continue installation.
10. Now go ahead and plug the usb devices back in. Install software if required, all usb devices if not faulty or broken should work now. Also note the error code if you get one?
This solution doesn't fix all usb problems so if you have a yellow ! mark there and device status reports a error code. Then it might not be a problem with your usb ports.
Thank you for reading, do leave suggestions, comments, feedback below.
Ekse
usb mouse drivers for windows xp mouse trackball mouse drivers bluetooth mouse computer problems 2.0 usb driver microsoft windows scanner driver usb 2.0 air mouse computer service usb hubs update drivers fix windows computer services computers hub usb usb drivers usb 2.0 hub laptop mouse usb switch 4 port usb 2.0 hub wireless mouse usb driver fix computer windows xp pro usb optical mouse computer support computer repairs update driver 4 port usb hub usb security usb cable windows xp microsoft windows xp computer repair windows xp professional upgrade windows
on May 04, 2008 | Microsoft Windows XP Home Edition
My cursor is stuck in the middle of my screen on my computer, my mouse is wireless so i tried changing the batteries and using every USB port and still nothing. I then got a wired mouse and tried that in...
Sounds like USB stopped working(maybe driver related). Try booting into safe mode by pressing f8 at startup before the logo screen for windows appears. If it is working in safe mode then it is not hardware but rather driver related. This also sounds like an older computer that might have a ps2 mouse port. If you have an old ps2 mouse you can try that.
Aug 14, 2017 | Microsoft Comfort Optical Mouse 3000...
Ps2 port doesn't recognize Microsoft Optical mouse
You might think about a USB hub for all your USB devices. ps2 port is more or less dedicated for mouse, which is why your mouse pointer is stuck in the middle of the screen. Go ahead and get an externally powered USB Hub to power other USB devices. To answer, ps2 for mouse needs just a mouse, not USB device.
Sep 28, 2009 | Microsoft Windows XP Professional
Installing Windows XP on a pc I have just assembled myself. All was going well until during setup Windows said it was going to 'adjust the monitor for better resolution' and asked for an 'OK' response....
When you boot your computer, just after the BIOS finish checking, press F8 key. Run windows in Safe mode. When the machine boots and gives you the screen, set the display to the lowest and reboot. On the next reboot adjust display one notch at a time and when you get a blurred display press Esc to come out as it does not suit your monitor. Adjust display one notch lower and accept it as final optimum display.
Jul 26, 2009 | Computers & Internet
Mouse works fine but cant get keyboard to sync
Might be a defective keyboard. Check and make sure its compatible for windows vista but all keyboards should work with any system.. As well maybe the port on the computer is bad..
Jul 26, 2009 | Sakar 62150 Keyboard
Mouse Doesn't Work in PS/2 port
CHECK BIOS TO MAKE SURE IT DID NOT TURN ITSELF OFF WHEN YOU PLUGGED IT INTO THE USB.BIOS MAY HAVE TURNED IT OFF TO PREVENT A CONFLICT.RICHARDM69
Dec 07, 2008 | Foxconn 6100K8MA-RS Motherboard
CL51-15 USB Port Problem
I have the same problem with the USB's not working. Suppliers say Motherboard problem. solved it by purchasing a PCMCIA to USB port. at least i now have 2 USB ports. you could probably get one with 3 ports.
Kevin S.A.
Sep 26, 2008 | ASI CL51-15 Notebook
My computer does not accept the new mouse model no. M00117-MB. Can you help me?
If your computer does not have a USB port on the front or back, you will need to purchase a USB-to-PS2 adapter. This is an example of one:
http://sewelldirect.com/ps2tousb.asp
That may not be the best price or only place to get it, only an example. This will connect the USB cable of your mouse to the PS/2 port on the back of your computer.
Jun 10, 2008 | Computers & Internet
Fixing optical mouse problem
try a diff mouse. try a diff usb port
Jul 31, 2017 | HP OPTICAL SCROLL MOUSE (8131)
AOpen (O35G) Logo
130 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
