Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
Posted on Jan 23, 2011
My washer will not fill with water or do any functions when i turn the dial
  • Anonymous Jan 23, 2011
    need more information is it plugged in if u advace timer to spin does it do anything...
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 23, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
165
Points
My Hoover 7700l ...on "fill" cycle, the water dribbles in. Takes hours to fill so we use buckets to reach the required level.
Tried: Swapping cold and hot water inlet hoses, making sure that dial is in "hot". This solved the problem for filling, BUT when "rinse cycle appoars, it's back to the dribble again.
any ideas?
5 Related Answers
Anonymous
  • 1122 Answers
  • Posted on Dec 02, 2008
SOURCE: the washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Anonymous
  • 51 Answers
  • Posted on Mar 13, 2009
SOURCE: Lower washing machine function inoperative in Maytag stackable
This is very odd, and probably isn't going to be any help,,,, but i know that most top loading washers have motors that spin in 2 directions. 1 direction engages the transmission/gearbox which than makes the agitator go back and forth while also turning the water pump in a direction that actually sucks in air, or water. When the motor spins in the other direction the transmission/gearbox engages so that only the drum spins and the water pump now does its job and pumps out any water in the drum before and while its spinning. With this in mind, and the fact that you say the washer only spins,,,, its possible that the motor is only spinning in one direction allowing the washer to drain and spin,,,, but not agitate.
Anonymous
  • 1136 Answers
  • Posted on May 30, 2009
SOURCE: water won't stop filling washing machine.
Hi, Will the water shut off if you turn the timer off or unplug the washer?
If it shuts off when power is turned off to the washer, you need to look into the water level switch. If turning off power to the washer will not stop the water, you need to change the inlet valve.
Please let me know so I can assist you further.
Thanks
Vic
Anonymous
  • 64 Answers
  • Posted on Jun 10, 2009
SOURCE: Maytag Washer MAV7000AWW Washer fills as it
Sounds like a bad timer motor.
Try watching the timer motor and see if you can see it moving .
honeymokey
honeymokey
  • 3113 Answers
  • Posted on Jun 18, 2009
SOURCE: Whirlpool Ultimate Care II washer fills with water and stops
Lid switch. Push down on lid.
Washer will not fill in the wash or rinse cycle.
Ck.to see if water is turned on,if OK,could need new control switch,the large dial that controls all functions.
Washing Machine fills and then just stops. Won't agitate,drain, or spin.
There is a magnet that makes the washer work. The magnet is located on the lid. Defeating this safety feature will cause the washing mashing to not work properly. In order for the washing machine to function properly, a relatively strong magnet must be affixed to the lid so that it pulls the contacts together and allows the washer to run normally.
Won't spin fills and drains water if i manually turn dial
Direct drive or belt drive? If belt drive then thats easy, motor belt or pulley. Direct drive? motor, ,,, maybe.
Washer continues to fill with water, no matter what function is set on the dial and will not spin water out of machine. Door will not unlock
The soleniod valve is bad.... here is a tip that will help...the problem you have is with the same part but the opposite problem...
Washing Machine2_bing.gif Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
heatman101
Asker's Testimonial " Thank you, I was also told that it may be the fill valve?? " - dsmith1695
5helpful
Washer stopped at the drain cycle Model LSR8233JQ1
Could be either a bad lid switch or a bad water valve.
Set the timer dial to SPIN and turn the machine on.
If it spins the lid switch is OK. If it does not spin the lid switch must be replaced.
Next,set the timer dial on a wash cycle and set the water temperature knob to COLD water. If it fills,the lid switch is bad. If it does not fill the water valve is bad or the cold screen filter is clogged.
If the COLD does not fill,turn off the cold water faucet. Remove the cold water hose from the machine water valve and check for a clooged screen.
If it does not fill with COLD water and the screen is clear,replace the water valve.
1helpful
1helpful
2answers
rclasky check this one
http://www.fixya.com/support/t827165-maytag_model_lsg7806aae
1helpful
Washer won't fill with hot water
If you hear a humming, the coil on the water valve is probably OK. On warm, you are getting cold fill only. (hot + cold = warm) Take the hot water supply hose off the machine and look inside where the hose attached to the washer. There should be a screen inside. Remove it and clean it out. Also, check both ends of the supply hose, as sometimes you will find a screened washer in there too.
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
