Question about Whirlpool Duet GHW9150P Front Load Washer
Control Panel eagle338. How do I get one & what do they cost? Regards, R Navarro
  • 4,889 Answers
You can try partselect.com. Or you can also remove the back panel and get me the part number of the Controlpanel and post it here. I think its PS989063 for your model but i'm not sure. Should cost you around 35$.
Posted on Jul 17, 2008
How do I reconnect the control panel wiring harness in a Frigidaire affinity dryer
Good Morning Friend,
I understand you want to know how to reconnect the control panel wiring harness on your Frigidaire Affinity dryer. Typically, this is not a do it yourself repair, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to reconnect the control panel wiring harness with ease. Hope this is helpful.
-Best Regards-
WP
Jul 09, 2014 | Frigidaire 134436600 Wiring Harness
Machien wont start, fill up or anything please help
just had same problem, washer was working and when new load was started it would not start. circuit breaker popped and reset it. no lights on panel and circuit breaker good in house. pulled power panel off and opened circuit card and notice black burn spots between cards which looks like the control panel is fried now. Cost about 200 to order, not knowing other costs if repairman fixes it.
Oct 02, 2010 | Washing Machines
My Fridgidare washer Model #GLTF2940ES3 keeps flashing an "E70" error code. Could someone please tell me what this means?
Hello there :
this 70 code has 2 possible causes
(1) a control board which might be in need of replacement. (costly to replace )
(2) the door lock assembly which could be bad. (fairly cheep and simple to replace ).
I would first shoot for the lesser (least costly of the two) and go with the door lock and this will be the problem if not this controle board can be costly to replace ok ?
I hope that this has helped you out
best regards michael
Oct 22, 2009 | Frigidaire Washing Machines
Machine won't start - is it the control panel
Geez
Thats an expensive part http://www.repairclinic.com/SSPartDetail.aspx?s=t-Kenmore+Elite+45986+Front+Load+Washer%3f-%3d%3dc212i1060952&PartID=1060952
This site has it for $105 and you could probably get a local repair person to do it for around $100
Oct 04, 2009 | Kenmore Elite 45986 Front Load Washer
TROUBLESHOOTING KENMORE ELITE HE3T FRONTLOAD WASHER WITH THE ERROR CODE F70
The F70 and F71 error codes on this model of washer indicates a communication problem between the user interface control board and the central control unit (main control board). These error codes can sometimes be caused by a power surge or glitch through the electrical lines. Try unplugging the washer to completely disconnect electrical power. Wait 1 minute and then plug the washer back in to the see if the fault code clears. If it does, then the washer may work normally.
If the code reappears, then you could have a wire harness connection problem, a failed user interface control board or a failed central control unit. I recommend calling a service technician to properly diagnose and repair this type of problem so that the correct component can be replaced.
Be sure your unit is plugged into a 3 prong grounded outlet as well.
F71 is a "heatbeat failure" which means that your front interface control board is shorted and will need to be replaced. it's actually fairly easy to replace and can definitely be done by yourself. To access the part, just pull the unit forward and remove the 3 screws coming in from the back of the top panel. Remove the top panel by pulling it back, up, and off. Then remove all the screws going into the top of the control panel. Remove the dispenser drawer and remove the screws coming in through the dispenser. Remove the screws coming from the inside of the dryer going forward into the control panel, then remove the control panel (it's just clipped in on the bottom. After that you can disconnect the wire harnesses to the front interface control board and replace that part.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 26, 2009 | Kenmore Washing Machines
Timer gets stuck on frigidaire front load washer
It appears that your timer is failing. The process to remove and replace the faulty timer is relatively easy to do with just some simple hand tools.
You should unplug the washer from the wall outlet before taking the top backsplash (control panel) apart. There are screws on the backside of the control panel, that you need to remove the back panel. Doing this will let you get to the wiring plug connector on the timer motor.
You'll also need to remove the timer/cycle knob on the front of the panel so you can use a socket (or a adjustable wrench) to remove the mounting nut and lock washer that holds the timer to the metal panel.
Once you have everything loose and accessible, all you need to do is unplug the connectors on the old timer and out them on the new timer and reinstall the lock nut and washer and button up the panel.
That shoud be all that's needed to get things working again.
Here's link showing a drawing of your washer along wtih the parts list (and prices) for parts.
The timer is part #134378400 and costs about $89.00
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FTF530ES1&productCategoryId=0153200&brandId=1428&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROL%20PANEL&documentId=R0509003&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Aug 21, 2009 | Washing Machines
Whirlpool Top-Load Washer gvw9959kq
Yes. I replaced the control panel (the panel with all the cycle buttons on it). I downloaded the technician's manual from whirlpool and went through the troubleshooting to find the problem. Th part costs around $106.00. Just make sure you order the right color.
Jul 27, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Amana control panel sparks
your panel shorted out
replace control panel and wire harness is my recommendation
Although depending on age, these two parts are quite costly the panel alone is 272$ retail
if you decide to buy it you can call amana 866-616-2664
to purchase them, or local dealer normally can sell you the parts
but with a major short like that id recommend replace, if you buy parts bring model, serial, and MFG manufacturing number starting PALW
May 02, 2008 | Washing Machines
Affinity washer not wanting to spin!
My Affinity washer quit spinning during the rinse cycle 14 months after we purchased the machine. We checked to make sure ithe drain was clear, and we tried changing the size of the loads. Nothing we tried worked. I was not getting any error codes on the control panel. We called a technician out to our house to see if it could be fixed. He diagnosed the problem as the control panel. We called Frigidaire to see if they would help us out with the cost of the repair since the machine was only 14 months old, even though our one year warranty had expired. They stated that they would not cover the replacement of the control panel. After the technician replaced the control panel and tried the machine, it still did not work. He called the Frigidaire tech support to find out why, and they told him that he needed to replace the door latch system, not the control panel. After he replaced the door latch the machine worked fine. When researching this problem online, I discovered that Frigidaire has had several problems with the door latch system on their front loading washing machines. They previously had a class action lawsuit due to this problem. When I found this out, I called Frigidaire to see if they would pay the repair bill we had incurred, even though our warranty had expired 2 months ago. After they contacted the technician that worked on our machine, Frigidaire decided that they would pay the cost of the replacement door latch and the labor fee. We had to pay for the cost of the initial service call. If you are having this problem, I would suggest that you contact Frigidaire. They will require that you have a diagnosis made by a certified technician. According to our technician, the flow chart for the Frigidaire front loading machines is inaccurate, so if they make an initital diagnosis of a faulty control panel you may want to have them contact Frigidaire tech support to double check the diagnosis. Frigidaire may help cover the cost of repair if your machine has a problem with the door latch.
Dec 18, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Code 51
Saw this in other area of blog (see below). I had same problem and Whirlpool service replaced RPS control board...fixed problem. Best Solution posted on Oct 20, 2007 2%20stars.png
446a518.jpg By wizard_s.gif eagle338
Rank: Wiz
Rating: 75%, 482 votes
there is a motor rotor position sensor(RPS) failure.
Refer page 10 of the manual below
http://www.servicematters.com/docs/wiring/Tech%20Sheet%20-%208567036.pdf
If you still cant fix it come back here..and ask i will help you out..
And please dont forget to rate if its solved..
Aug 19, 2007 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
