Question about HP Photosmart 3210 Printer
Smearing problems When I copy an item, black ink is smearing onto the paper. It does not do this when I print regularly.
    Problem Solver:
  • 12 Answers
Let me tell you!!!! your printer is dead man!!go get a new one!!!
Posted on Aug 03, 2008
How to set my printer to print black ink only
Option 1 - when printing, go to printer settings and select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black. The pigment black ink will only be used when printing on plain paper. Check the box for 'Grayscale Printing'. If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
I tried this once myself, but the result seemed to be useless for printing photographs.
Option 2 - Using quadtone inks may be the solution. http://www.completedigitalphotography.com/?p=32
Jun 14, 2010 | Canon PIXMA MP540 All-In-One InkJet...
Ink from smearing all over my papers
Using original cartridges won happen like this.
May 30, 2010 | Canon Pixma MP450 All-In-One InkJet...
Repair on Hp laserjet 4250. Printing but smearing black ink on paper
the fuser roller needs to be checked/ replaced. this is in the fuser unit which is availale in the maintenace kit from hp. all instructions in the manuals and on hp website
May 11, 2010 | Office Equipment & Supplies
Ink keeps smearing on the paper. What do I need to do and stop this from happening.
Remove the inks and if there's a printhead, remove it and check underneath, paper fibers and pet hair can cling to the printhead smearing ink everywhere. When the inks are in the center check on the right side for any paper scraps caught over there. Check your paper too, plastic coated paper doesn't let the ink sink in and you can't print on a CD unless it has a paper label.
Jan 21, 2010 | Canon PIXMA MX300 All-in-One Printer
Black ink smears everything.
you may have to clean the print head. since the jam cause the smear, and there still have some ink left on the print head.
you wouldn't get aclean copy till all of the ink trace are gone.
May 20, 2009 | Canon Office Equipment & Supplies
All ink cartridges leak onto to copies
I think you need to change the tranfer belt assm.
If all the colors are smearing .
Or all of your toners are bad and leaking,
Hope this helps
Mar 28, 2009 | HP LaserJet 4650 Color Printer
Phaser 8200 Smears on Linen Paper
Your maintenance kit is running low on oil and needs to be replaced. Since the image drum is not getting enough lubrication, some of the ink from the previous page is sticking to the drum and carried over onto the next page. Also, try to match the printer paper type to the paper you are using. It will adjust speed, temperature, etc. to optimize print.
Mar 24, 2009 | Xerox Phaser 8200 Laser Printer
Smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Nov 16, 2008 | Canon MultiPASS MP390 All-In-One InkJet...
Black line on back of page
It sounds like you have a black ink leak and it is smearing onto the paper when you print. I don't know any reasons for this except if you topped the black ink up yourself, and didn't re-block the hole you made. Then I guess the ink would gravity drip onto the paper tray while you weren't printing. Otherwise I would suggest changing the print head, but this might be expensive.
Dec 28, 2007 | Canon Pixma MP500 All-In-One InkJet...
Gestetner DSc332 streaks and smears when printing in color
Check to see if you have a paper jammed near the drum near the color ink cartridge interface.
Nov 28, 2007 | Gestetner DSc332 Copier
HP Photosmart 3210 Printer Logo
90 people viewed this question
Seeker5211
Seeker5211
