Question about Philips DSR708 DirecTV DTV Receiver / 70-Hours Video Recorder
Phillips DSR Receiver to 2nd or remote TV
Can I use the RF Output to connect to a 2nd TV?
  • Anonymous Mar 16, 2014
    Only one television controlled by 2nd remote.The reciever will not respond please help than you
If you are asking if you can use yellow-red-white to one tv and rf coaxial to another tv at the same time to watch the same show, the answer is yes.
Posted on Aug 08, 2008
How do i run my cable to other TV's in my home
Cheapest, simplest way is to buy an RF Power Splitter, available in Radio Shack and elsewhere, and connect 2nd TV to free output. May not need 2nd cable box if 2nd TV is relatively new or if you're willing to give up some channels and features. Otherwise, call service provider to install 2nd cable box and they will also provide the RF Power Splitter.
Sep 17, 2014 | Televison & Video
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
How do I connect my Sansui 6010B VCR with an analog TV and a DTV tuner?
two ways of connecting VCR with Analog TV with DTV tuner.
DTV tuner (RF) output to VCR (RF) input,VCR (RF) output to analog TV (RF) input.
turn DTV tuner on (VCR should have a TV\VCR switch that makes signal coming from tuner BYPASS VHS right into TV) note:: change channel FROM tuner.You should be able to record by placing a blank tape and pressing RECORD.
2ND. DTV tuner, VCR, should have a RCA in\out connections...Audio & video.You need a RF\RCA bypass switch. It has a INput with RCA connections to a RF signal out that goes to the RF Input of analog TV
Jun 21, 2011 | Sansui VHF6010 VHS VCR
I have a Direct TV box and just bought a Direct TV remote with RF antenna. I have attempted to program the remote to work in RF mode, but for some reason it's not accepting the programming. The remote...
Connect the supplied anttena on the reciever. Once you have done that, then:
1. dtv symbol device
2. press and hold MUTE & SELECT for two blinks
3. enter 9 6 1
4. press CH UP
5. enter the last 6 digits of the Receiver ID #, found on a sticker in the access card compartment
6. press SELECT
Now the receiver will accept both IR and RF, but the directv device on the RC32RF remote will only emit RF signals. The av1, av2, and tv are all still IR only.
Jun 22, 2009 | Televison & Video
No TV signal
If it's hooked to Dish network, you have a receiver to connect to the TV. If you're using the receiver's RF output on channel 3 or 4 to the TV's antenna jack, you need to have the receiver on while the TV is scanning or it won't add the receiver's output channel. You can rescan channels after you turn the receiver on. If the TV has AV input jacks and you're connecting the receiver that way, you need to switch the TV to the AV input. That may be difficult or even impossible without the TV remote.
May 04, 2009 | Televison & Video
RF module related to Direct TV.
yes you can but the 2nd tv wont be in HD. The modulator can be purchased for any electronics store. what it does is turns a composite video signal (yellow, red, white cables) into a coax (screw in cable). it has an composite input that you would connect from the receiver and a coax output that you would connect to the other bedroom tv.
Oct 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Unable to connect to Digital satellite receiver
I threw the mitsubishi VHS recorder under a bus, just like ' YOU CHANGE , CHANGE ,CHANGE FOR MY SAKE'S' grandma, and invested in a new DVD recorder, 2 yr g'tee and latest tech. GODDAM A--- well old grandma and anyone or anything else that gets in my manical lust for power. CHANGE EVERYTHING FOR ME, ME ME, ER UM US US US.
THANKS FOR YOUR TIME GUYS.
Aug 20, 2008 | Mitsubishi Televison & Video
DVD input with signal access
IF I understand you correctly, the VCR, Satellite, etc is connected using an RF modulator/coaxial cable wire going into Antenna in
IF this is true, then you have an AV IN port (red, yellow, white) free on the back. Just connect the red, yellow, white from the out of the DVD - you can use 1 or 2 - just remember which one you used; and connect it to the AV IN on the back of the TV.
THEN press ch down on the TV remote until you get to "AV1" - it is below channel 2; double check DVD player to make DVD is playing and voila!
Jun 22, 2008 | Philips Magnavox 27MS343S 27" TV
Can't get picture after connecting to receiver nad speakers
Sounds like something got confused in the re-wiring...if the TV signal from cable doesn't involve a box, then the co-ax should go straight to the "cable in" or "RF in" on the TV, and the sound equipment gets connected to output ports on the TV. Otherwise, try bypassing the video connections on receiver or whatever and go directly to TV...My surround sound has video in and out, but I've never used them, it doesn't matter.
Feb 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
Philips DSR708 DirecTV DTV Receiver / 70-Hours Video Recorder Logo
95 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
