I have purchased 2 x samsung chip 1 GB ddr-400 PC3200 184 pin chips to up grade my ram on my hp pavallion t680a. I installed these and my system seemed to reconigise the fact that the ram had been increased to 2 GB - but I had a number of problems where my system closed down (giving a blue warning screen with various codes each time). I also ran a PC Doctor Diagnostic and an error came up "memory advanced patern test = me516-5". It appears that the Samsung chips are the correct type - but do not seem to be compatatable. Is there some sort of BIOS patch I need to install for the ram upgrade to work or are the Samsung Chips not compatatable with the HP machine? THANKS!!!!!
  • sreeradh p.r
    sreeradh p.r May 11, 2010
    samsung chips compatatable with HP machine
    please same chip two memory
    Problem Solver:
  • 63 Answers
Hello. Looks like your PC requires specific (somtimes known as proprietary) RAM. Go ahead and update your BIOS from HP's Site. Probably won't do you much good. Found this on a website: "Your HP Memory Pavilion t680a only supports modules made with a specific type of chip build. If you come across a website and find what seems to be the exact same memory for a lower price, it is likely that the cheaper memory will not work in your system. By ordering under your model from Upgrade Computer Memory, your selected memory modules are Guaranteed To Work or your money back!"
Posted on Jul 17, 2008
  • 87 Answers
Please use same chip memory
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Chip up grade options!
That
is a socket 754 motherboard. It will support AMD Athlon processors up to Athlon64 3400+. It is a bit long in the tooth by today's standards, and only uses DDR memory, not DDR2. You may get more of a bang for your buck by buying a "barebones" system, which can consist of a motherboard with processor and memory, depending on how much you want in the barebones package.
Typically you use the case, power supply you already have with the new motherboard and processor and ram (memory).
At any rate, if you only want to upgrade your processor, keep in mind that your board only supports up to the Athlon64 3400+. It will support up to DDR 400 ram. You would probably benefit more by buying 2 sticks of 400 DDR ram at 2 gigs each, if you don't have much ram now. If your processor is close to the 3400+, then another processor in that board isn't going to change things much.
Good luck, and write back if you'd like more help.
Sirwriter
Socket754 Supports AMD Athlon64 upto 3400+;
Nov 02, 2009 | Computers & Internet
RAM is installed, but lap top does not read it
The 6735s requires DDR2 SODIMM chips clocked at 800 MHz and they must be installed two at a time (so a 2 Gb chip won't work - you need 2 1 Gb chips. Installing 2 + 1 Gbs will give you 2 Gbs only, (1+1), that is if the PC even boots at all; and so on).
Also, not all operative systems will read the full amount of RAM installed.
Oct 24, 2009 | HP Compaq 6735s Notebook
Dell optiplex p4 1.8ghz: RAM
Best and easiest thing to do is go to www.crucial.com and run a scan of your computer. It will tell you what you have, how much it will hold, and what kind of modules.
Yes, it's safe.
Thanks for using Fixya!
If you have any trouble, comment back.
Jan 28, 2009 | Dell OPTIPLEX GX240 P4 1.8GHz 512MB 20GB...
Hp system board
the machine uses ddr 1 memory and hold a max of 2 gb of ram
RAM 128/2700 MB DDR SDRAM
Maximum 2 GB (2x1024MB DDR SDRAM)
Sockets Two 184-pin DDR DIMMs
Size 128, 256, 512 and 1024 MB DDR DIMMs
the motherboard is a socket 478 board , the Dual-Core chips are socket 775 so you couldnt use them unless you change the motherboard
Dec 08, 2008 | HP Computers & Internet
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
Ram card
Hi giovanni2,
Sorry but you're board does not support DDR2 memory.
Only 2 x 184-pin DIMM sockets support two 2.5V DDR SDRAMs (DDR400/333/266). There are two PC Chips M871G.
One is M871G (V1.5) & the other is M871G (V3.1). Neither support DDR2 memory. DDR2 memory used DIMM slots with 240-pin. The memory slots on you're board uses 184-pin. The board will not function with 240-pin memory.
PC Chips M871G (V1.5) link.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=340&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
PC Chips M871G (V3.1) link.
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=368&CategoryID=1&DetailName=Specification&MenuID=7&LanID=2
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 22, 2008 | PC Chips M871G Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
